Extended lines like collectable minifigs, magnets and keychains are made in China by a 3rd party and tend to be rubbish but with proper, boxed, sets, you're safe.
There has never been any 'cheap Chinese plastic' the issue was with colour quality and mold polishing, the phrase annoys me, why link 'cheap' and 'Chinese', no one says cheap Mexican, or cheap Danish when there is an issue with plastic parts from those locations. The reason LEGO has a factory in China is capacity, we needed more, they had more, cost was never the reason.
As for Alien Conquest, yes some parts are China made, try to pick out which ones.
Chinese does not automatically mean cheap and nasty, of course, I agree, as it's all down to the quality control and materials used which can be the same wherever in the world things are made.
From my observations, the parts made in China are those with -B01 underlined (or some other letter/number) at the end of the mould number. Mabye B=Broadway? The only AC ones I've noticed so far are the alien heads (J01) which are perfectly fine, but then they do not appear to be ABS.
^^I guess this would fall under the label of a color quality issue. I hadn't noticed the difference in color when looking only at my CMFs but mixed in with regular LEGO parts the difference in color screams at you.
Apparently this is being realigned but we produced tens of millions of yellow hands and it’ll take some time to use them all up.
The translucency of parts is normally not due to the plastic (which is identical) but the amount of colourant added, I’m not sure if a better colourant is being used that requires less to be added and produces the translucency, if the mix is not right, or something else. I’ll ask next time I get a chance, though unless it’s made public like the stuff above was I might not be able to post anything about it!
When I get a chance, I'll do a bit more scientific comparison, like take a picture of all three heads next to each other in natural light. (if the sun ever comes out while I'm not at work)
Here's the setup:
And the composite image:
From Left to right, the heads are as follows:
Solid Stud head: http://www.bricklink.com/catalogItem.asp?P=3626ap01
Unitron Head: http://www.bricklink.com/catalogItem.asp?P=3626bpx157
SP3 Head: http://www.bricklink.com/catalogItem.asp?P=3626bpb358
CMF Cyborg Head: http://www.bricklink.com/catalogItem.asp?P=3626bpb506
I've used the GIMP color picker tool to take the average RGB values for a 50px by 50px square, directly under the bevel on each head.
I can't see much, if any, variation in the yellow. Certainly no more than the variation I've seen in yellow bricks.
As for the printing on the torso, if they printed red over the yellow, then she'd have nothing holding her outfit on at the sides.
I don't recall seeing minifigs with printing on the sides of the torso, except for the coating on the chromed versions, and we know how well that works.
Example, take a photo under florescent lighting and you'll often get a very yellow looking picture, even if the colors in the room when you take the picture appear mostly normal to you.
@jwsmart Although your pictures provide a rough measure of the color differences, unless you corrected for the color cast of the light source and the color cast of your camera, you did not capture actual color values of the objects. This is what controlling for color spaces and color calibration are all about, in order to get accurate color information.
Also, as humans we're more sensitive to certain colors in context. Green casts on skin make you look sickly and unnatural. Red casts on skin make you look blushed, but still rather natural. I'm not surprised that the orange shift would be less noticed than the green shift on a minifig.
@madforlegos - after taking the photos, I didn't see much of a difference either, which is why I broke out my favorite (least expensive) photoshop replacement to see if my eyes were playing tricks on me.
Also, I hate to point this out but not all of your conclusions are completely supported by your measurements. You say both of them have diverged from the solid stud heads from 1991. However, your data seems to indicate that only the Broadway head has. The other measurements are pretty much in agreement with one another.
Also, are you reading the same numbers I am?
I mean, you could say that 90 is pretty much the same number as 91. I wouldn't, but you're more than welcome to - that's why I posted my data and analysis, so that if someone thought my conclusion was bogus, they could come to their own.
I would love to see someone who has some known heads from different time periods do the same comparison, as would I like to see someone trying to recreate my little experiment and seeing if their data supported the same conclusions about relative color. (You couldn't directly compare my photos with someone else' stuff, because of the already-discussed-to-death accuracy issue, but a repeat of the side-by-side comparison might be interesting.)
Considering all these potential sources of error, I'd say values within such a close range do not indicate significant differences thus indicating the color of the heads have not changed.
So until someone breaks out some real color calibration equipment, I think we should realize the intent of jwsmart's photo, that is to examine color differences on an amateur level, and not make real scientific conclusions.
Anyways, if I have some time on my hands anytime soon I'll take you up on your offer for another side-by-side test in my own setup. I'd be more inclined to make an opinion if we had more than one image to compare, as you pointed out.
Uh, that's a bad assumption. I did correct for white levels in the photo - which is why the white background is white. We can add that to the list of potential sources for error.
Hey @brickmatic, would you just give it a rest? We disagree. I get that. You may be right. I get that too. Or it could be that the big pile of potential sources for error you supplied adds up to less than 1% on the silly color picker. In which case, I'm right.
The best way forward would be to take more pictures. It sounds like you could do a much better job of this than I could, so stop talking about what and awful job I've done and go do!
I applaud your effort in trying to get a measured difference in color. I think two improvements are needed in the experimental design. 1) The camera needs to be color calibrated: "The camera calibration needs a known calibration target to be photographed and the resulting output from the camera to be converted to color values. A correction profile can then be built using the difference between the camera result values and the known reference values." 2) The sample size need to be greater: "The sample size is an important feature of any empirical study in which the goal is to make inferences about a population from a sample." Just to be clear, originally there was one sample (head) per test condition (production year).
That said, I'm not in a position to do the experiment. Despite my grasp of the theoretical considerations, I don't have the equipment or the practical experience to properly set up the experimental conditions I outlined above.
Minifigs from left to right:
2009 Male Surfer from 7639
1999 Dutch Vander from 7150
2010 Cheerleader from CM1
All the minifigs are new and have been kept out of sunlight or extended indoor light. RGB was taken using the color sampler tool for a 25 pixel area square in between the eyes of the heads.
In brief, my setup was a Canon DSLR mounted on a tripod with a bounced speedlite, a Tamron macro lens, and two diffused fluorescent lights on either side. I've spared the real details since, as we have mentioned, I'm not writing a lab report here.
No post-processing (except for crop)
209 172 22 - Male Surfer
208 173 21 - Dutch Vander
199 170 27 - Cheerleader
Post-processing (Photoshop CS5)
255 210 13 - Male Surfer
255 213 12 - Dutch Vander
253 207 17 - Cheerleader
My numbers varied more but the results were similar to jwsmart, the collectible minifig was more blue and less red. I similarly don't have older minifig heads, but I still think it's interesting that we have similar results.
I won't bother listing sources of error, I think we've covered that. If I had more time, I would mix up the position of the figs, because in both mine and jwsmart's trials the CF was on the left...
No processing
Processing
Clearly none of us have the equipment to "do so properly." I don't see a real need to measure the differences, I don't really care what color my cheerleader is as long as it's pretty much yellow, which it is. However, it's still hard for me to say it isn't interesting that two people conducting the experiment differently came across similar ends.
As for whether those similar ends have any meaning to a kid or an adult collector, the answer is no.
And that's not to say I disagree with the fact that more trials and more gear would be required for anything to really be said, but whose really saying anything anyway. I've done plenty of lab reports and I have no intention of writing another on this.
I don't mean to argue and I don't want to either, take whatever you want from the pictures. If they don't mean anything to you, that's fine. They don't mean much to me, either.
I think I did that, and @Enbric did too. I've satisfied my curiosity.
Besides, I've always liked rubber rulers. I tend to injure myself much less whilst using them.
