1103104106108109
  • Knighthawk215Knighthawk215 Member Posts: 3
    I’m hoping someone can maybe help me identify what set this is from. It doesn’t really have any unique pieces, but has a little cubby where like a box or something might slide in. It came in a bin of loose bricks, most of which were from sets from the mid 2010s. There’s a second chunk of bricks of similar construction that I’m guessing is from the same set.  Reverse image search hasn’t been of much help. Thanks!
  • andheandhe Member Posts: 3,916
    @Knighthawk215 I think its #70808 Supercycle chase judging by the 1x2 grille brick, the 1x6 light blusih grey tile and the 3x1 curved slope.
    Bumblepantslessjunkfood
    Ah yeah, I think you are right. How did you figure that out? Is there a way to search by multiple parts at once?
    Also sorry, I thought I was in that thread. I hit create new from that thread, but apparently that doesn’t work?
    andhe
  • AstrobricksAstrobricks Member Posts: 5,450
    To reply to an existing thread, use the Leave a Comment edit box at the bottom of the thread.
    andhe
    Yes it's in the search function under a 'Appears in' tab. You can search three parts (I couldn't seem to add any more that that) and their specific colour.
    I did have a look at the instructions (linked in the Brickset database) but couldn't immediately see that part of the build.
  • AJRDLawrenceAJRDLawrence Member Posts: 72
    So I have worked my way through the entire job lot box and identified pretty much everything apart from one minifigures.
    It was in a mixed lot of DC/Marvel sets (the three star Wars sets were missing...) and I can't place it.
    Presumably someone will recognise it. I think they also had some Harry Potter sets too so that yellow bolt, if it does indeed belong with the minifigure, could also be magic.
    bandit778 said:
    So I was almost right... Both Marvel AND magic haha. Cheers. Unfortunately there was nothing else in the job lot box relating to that set. Thanks again.
    bandit778
  • sonofrich2sonofrich2 Member Posts: 18
    As there isn't a design I'd number stamped, is this from sets #6162 / #6163, with element number of #4497482 ? Or is from set released prior to 2007?
    ^ The only other set that came in according to BrickLink was #852676.
    rd1899
    Thanks.  I had thought a part this size by 2007 would have the design number on it.  As this does not, I was thinking it was from the 70's or 80's
  • Brickfan50Brickfan50 Member Posts: 469
    Anyone know what this piece is?
    It look likes Body part, right Leg.
    560HeliportBumblepantsandheAstrobricksSwitchfoot55LegoPosigelkster
    edited July 2022
    Har de har har har ;-)
  • BumblepantsBumblepants Member Posts: 7,540
    One of those custom bits originally made for the Cars theme I think.
    edited July 2022
    Usually there should be a serial number underneath on these large parts.
    rd1899
    Hehe! I almost fell for it too :D
    Sorry didn't realise this had already been answered.
    560Heliport
  • gelkstergelkster Member Posts: 926
    not sure of the best keyword to use
    Bush? shrub? Monster hair?
  • WesterBricksWesterBricks Member Posts: 787
    You have a 15068pb010 - a reindeer back from #10245 Santa’s Workshop.
    gelksterAstrobricksrd1899
    edited July 2022
    Thank you! Keyword was "fur" 🙄🙄🙄
    Found in a $10 bulk lot. Several sets in there but too much missing from each. However, most of the sleigh is there (partially seen in pic 2) & many dk green parts; I may try to build & see how close I can get on it.
    If you find a couple of those reindeer, their backs and eyes will triple your money.  If you find most/all of the Workshop, that's $$$.  Either way, $10 is a fantastic deal.
    gelksterSwitchfoot55
    edited July 2022
    I got hold of it earlier this afternoon & only had a couple hrs to scan thru & see what jumped out- Friends sets, stickered parts from Freeco Speeder & Hulkbuster, ONE orange part from #60036, etc. But fingers crossed for the Workshop!
    560Heliport
  • Switchfoot55Switchfoot55 Member Posts: 3,280
    @gelkster If it's complete and you're not intensely interested in the Workshop and maybe want to consider a trade of some sort, I might be in the market.
    edited August 2022
    Unfortunately this was a total mix of at least a dozen sets; none of which were even remotely complete. I got most of the sleigh & about half a reindeer was present. I didnt even bother trying to make the Shop.
    My guess is the original owner sold similar bulk totes & the involved sets sadly got separated & dispersed.
    It breaks my heart when this happens.
    Fizyxrd1899gelkster
  • ModeltrainmanModeltrainman Member Posts: 1,191
    Based on the molding around the “base” I’d say no.
    Modeltrainman
    Figured, thanks! it doesn't seem to fit LEGO.
  • LegoDude72LegoDude72 Member Posts: 4
    This Darth Vader torso has a grey button on top of the red and I cannot seem to find a torso like it.
    This Darth Vader Torso has a small grey button above the red instead of blue or green. Can you help identify what version this is? Thanks
    The only Vader torso I can't fully see is sw0117. So, in theory, it's possible it's that one? Is it possible the blue or green faded a bit on that button?
  • 560Heliport560Heliport Member Posts: 3,736
    Or maybe the blue or green didn't get printed? (If the blue or green would get printed over grey.)
    Switchfoot55
    I think this is most likely. The blue and red are overprinted on light gray or white, so either the blue has worn away or wasn't printed in the first place.
    560Heliportandhe
    The torso does not look worn at all so I'm guessing its a misprint. Is there any way to tell what set it came from, I bought it in one of those bags from a flea market.
    edited August 2022
    There are only a handful of torso prints that match the other design layouts. You can review them here:
    https://www.bricklink.com/catalogItemIn.asp?P=973ps7c01&in=S
    Looks to be about 11 potential sets it could be from. (Though there are some additional "gear" items that it could also be related to)
    LegoDude72
  • CCCCCC Member Posts: 20,526
    It looks like the original one just missing the blue print.
    Switchfoot55andhe
    Thank you guys for all your help!
    Switchfoot55
  • HuwHuw Administrator Posts: 7,076
    It's certainly old because they don't have neck prints for head alignment any more.
  • flordflord Member Posts: 797
    Any help identifying these would be appreciated. I searched Bricklink and I have major eye strain.
  • vanvonfullvanvonfull Member Posts: 263
    5 is the scientist from monster fighters. #9466
    gelkster
  • jason1976jason1976 Member Posts: 309
    1 is https://www.bricklink.com/v2/catalog/catalogitem.page?P=973pb2704c01&ccName=6185330#T=I&C=11 from https://www.bricklink.com/v2/catalog/catalogitem.page?S=col17-16#T=I
    @flord if you haven't already tried, Google may help - I searched for that for ages on bricklink, trying frill, tie, suit etc as key words, then typed "Lego torso with frills" into Google and it was first image!
  • The_RancorThe_Rancor Member Posts: 2,534
    6 is an Imperial Security/Immigration Officer from the Solo Imperial Patrol Battle Pack  #75207. Just missing the helmet
  • NOTWNOTW Member Posts: 1
    Looking to build these battle droids from YouTube user hachiroku24, he has given a parts list as a photo.  I am new to Lego so I am not familiar with all the part names. Does anyone have this in a list with part numbers so I can order the pieces or is willing to help me find the part numbers?  Thank you!!
    andhe
    I remember a thread a while back about a camera / scanner system that was able to id minifig parts.  If I remember correctly it was only available for Windows or Mac & was about 170 EU.  It may have been posted pre-pandemic.  If you think its worth the investment.
    You're probably thinking of Instabrick. Instabrick: Part identification system — Brickset Forum
    I have it and use it frequently. Not as good at identifying minifigures as the Brickset users who post in this thread, but very useful if you have hundreds of jumbled minifigure parts.
    FizyxAstrobricksWesterBricksandheBrickfan50
    I'm trying to determine if I have some fake Lego. One torso has a neck marking and not the other. Had the procedure for printing figs changed during this era? These Kai torsos both have "Lego" printed on the neck. Both have "Lego" printed on the legs.
    I also have a hood that does not have a Lego stamp inside like other ones I have. Instead, there's a "2". Not sure if you can see it in the photo. Is this hood genuine Lego?
    Thanks for you help.
    @flord short answer - yes. Not exactly sure when printing methods changed, and likely these figs were made in different factories hence the different manufacturing methods. Not every lego part will have lego printed on it, depends on the space available.
    rd1899
