#8884 - IR Receiver
#88000 - AAA Battery Box
#88002 - Train Motor
#8879 - IR Speed Remote Control
You will need all of these items to motorise the train and an iPhone will not work in place of the Remote Control for these Power Functions parts.
You may be able to substitute "Powered Up" components, which do allow Smartphone control, but they are not likely to be a 1-for-1 replacement, due to size differences etc.
https://brickset.com/sets/theme-Powered-Up
You can buy one of the train sets that contain the Power Functions motors etc.
https://brickset.com/sets/containing-part-4584375
Finally, for train tracks, you can use any of the following, plus any track contained within current train sets:
#60205 Tracks
#60238 Switch Tracks
Putting a "#" in front of the set numbers will link to the entries in the BrickSet DB:
#8884 - IR Receiver
All of the most recent train sets use the new "Powered Up" motors and not "Power Functions". Again, you should be able to use these, but it won't be a straight 1-for-1 swap.
https://brickset.com/sets/containing-part-6214559
#60205 Tracks
So just seen on YouTube someone used the train #60197 to power up #10254, getting the power, extra track as well (which I presume is compatible). Also he used iPhone to control.
The #60197 is around £100 and so that’s motor functions and extra track maybe worth doing it this way?
Thanks
Yes, Powered Up is the newer system. I don't have any experience with it, so can't make any claims about its suitability for what you want it to do but, as you say, there are people who have done, so I am sure it's entirely possible with a little work.
It's very much possible, but you may want to add the motor to a extra carriage, one which contains both the motor and the batterybox - because due to too little weight in the locomotive. When just putting the motor in the loc (and the battery box in the tender), the motor (which will be at the front of the loc) has little grip. If you put them both in an extra wagon, the grip is better (like in #60197 and #60198) due to the weight of the battery box being over the driven wheels.
However, if you go to fast (and that's pretty quickly in my experience), the "pushing" carriage often derails the locomotive... If you find an optimal solution, please let me know!
Do you think it’s best I just get the original power function set instead then?
This is just so I can put around my Xmas tree this year.
With the new Powered Up, the train motor JudgeChuck listed isn't available any more (on Lego.com) but they do have #88011 but that doesn't come with the wheels as far as I can see. The other problem is the battery box #88000 is also retired on the website so you'd have to go with the "hub" #88009 but that is $50. Not sure how that is controlled though, if you just need those two and connect with your phone or if you'd need the remote too (#88010). Someone who knows more about Powered Up might be more help.
I’d like to hear from anyone else who has used the newer powered up for the #10254 please, and if everything works well and fits ok.
I know I took a lot of inspiration from other's modifications of the train to motorize it (old or new systems). So, definitely worth a look!
Could you post some details and/or pics to show me please? Was it easy?
I’m not bothered about speed, as it’s for a decoration to just go around the Xmas tree that’s all on a simple track (maybe expand from original tracks with ones from #60197 if get)
So with you doing it do you think it’s better to just get say City train to use that and extra track, as the powers up on own is quite expensive.
Thanks
