It doesn't play nicely with CMF minifig base plates, but the shelves are easily removable which makes it simple to rearrange.
I think it looks pretty decent in situ, with the bonus that big-figs fit at the top.
There is also a window which will keep the dust out but I think (again - no instructions!) I need to attach magnets to my expedit unit so I need to decide a final resting spot for these guys.
https://www.etsy.com/uk/shop/MazingaAcrylic
Unfortunately they aren't cheap and they are shipped from South Korea.
This is a shop where overseas delivery is possible.
https://smartstore.naver.com/mazingacrylic
https://www.instagram.com/mazinga_case_official/
It's frustrating they don't ship overseas.
Is the frame made from wood? I assume it has a perspex front, it's hard to tell?
https://digsforfigs.com/store/
And also a few “humanized” Vidiyo figs.
https://www.michaels.com/default/10147365.html
The Spder-verse is on my work desk.
Other than the obvious issue of dust, what does the hive collective think of this type of a solution for the brackets?
Bracket 1 x 2 - 2 x 2 Inverted
Slope, Curved 2 x 2 x 2/3
In this arrangement, each baseplate would fit 40 standard sized figures max.
I think this is a legal assembly for the brackets, but I was going to check if there was actually any interference between the studs after I got back home.
However, they include a white 2x2 plate underneath. My guess is that it's due to stud interference as you suggested. That said, with one more part per perch, I think you could easily anticipate fitting that many figs.
I will say that the 2x2 space to plant their feet on is rather limiting to any figure that has any sort of item protruding from their back or even larger hats. In a few cases, I've used a larger plate to get them another stud or two away from the back baseplate in order to fit them.
I'd post pictures, but my stuff remains in storage (t-minus 4 weeks until I can get it out!)
Another option I considered was this bracket:
Bracket 2 x 2 - 2 x 2 with 2 Holes
That would bring it from 3 pieces per fig for the bracket down to just one.
Looking at costing on PAB, the three part bracket is $0.10 + $0.13 + $0.09 = $.032 each.
The other 1 piece bracket option is $0.31 each...
I'll be curious what you end up leaning toward. I've had a wanted list with the 3 parts from the LEGO display for a couple of years and have never pulled the trigger. But I have two of those Display Frames that need filling...so maybe I need to finally pull the trigger.
I like this idea: I have a bookcase that's in just the right place for this, and a bunch of nom-Lego baseplates I got at 5 Below for $3 apiece.
Plus an impending winter storm that has the potential to be our worst in 30 years! :)
Intrinsically I like the idea of the single piece bracket, however the 3 piece option perhaps has some more configurability to it and maybe looks a little smoother/nicer depending on your aesthetics. Both options by default place the minifigure the same distance from the baseplate. A 2x2 brick could be added behind either for a greater offset. With both, I could mount a 3x4 CMF tile to the top of the bracket if desired, or a 2x4 jumper. So lots of options really. Big figs would be a little bit more challenging, but surely a platform could be built for them.
For those not seeing the image, what browser are you using? I'm using Edge, and can see the image in the reply from @pxchris
Jokes aside not working in chrome for me either.
