New parts discussion
1202123252634
  • AanchirAanchir Member Posts: 3,037
    edited November 2020
    This looks like a new tile separator in the Dots sets. It has an end like the crowbar.
    Besides separating tiles, I suspect it will also be used as a key in the two Secret Box sets. At least one of them features what looks to be a keyhole.
    Another part that really excited me is in the new LEGO Friends play cubes — a combination half-arch and SNOT bracket! It's used to attach the ears of the Pug and Cat cubes ( #41664 and #41665 ).
    Astrobricks560Heliportrd1899BumblepantsLyichir
  • rd1899rd1899 Member Posts: 211
    CCC said:
    rd1899 said:
    And, from 41926, mini wooden clothespins? And, felt "pom poms" (the round plush balls)?
    Are they included though, as there is also a load of ribbon. And other sets are displayed with painted rocks / pebbles. So I assume these are things the kid already has rather than included.
    You're right.  I'm not used to see non-Lego items in the promotional studio images.
    (Applying a desaturation/gray filter or a transparency filter to the non-Lego items would make it less confusing.)
  • CymbelineCymbeline Member Posts: 563
    The new pink frog element is used for the flowers in the alternate build of the Bonsai Tree set. The Brick Fan has good pictures of this set as well as of the Flower Bouquet set. Of the two, The Flower Bouquet is a must buy for me.
    KungFuKenny
  • BrainsluggedBrainslugged Member Posts: 2,245
    Also, the bonsai tree has little pebbles. I assume those aren't included, but I cant imagine it would look as good without them.
  • TheOriginalSimonBTheOriginalSimonB Member Posts: 1,780
    They look like a mix of 1x1 round tiles to me.
    stluxLyichirPaperballparkCymbelineMr_CrossKungFuKennygmonkey76MinifigInSpace
    Good eye!
    Promobricks has pics of some Disney sets with interesting new pieces!
    • #43189 has several parts recolored for the first time in Tr. Blue Opal (including the LEGO Elves diamond piece with 3.18mm bar, and the new LEGO City 1x4 "wall of fire" piece). It also has a new minidoll-style foal piece with a 1x1x2/3 cutout in its back which can be filled in using 49307.
    • #43192 has a new minidoll-style horse piece with an articulated neck like classic LEGO horses, and also a new mouse piece patterned to resemble Cinderella's mouse friend Gus!
    BumblepantsLyichirMr_CrossCymbeline
  • LyichirLyichir Member Posts: 1,017
    Like previous mini-doll sets I can't help but imagine what these new parts might've seen use in if Elves had continued. I'd been hoping for an update to the foal piece in particular for a while, since better attachment points could potentially allow for wings to be attached for a baby pegasus! Still not sure that this on its own would suffice for that, though—ideally, it'd need a 1x1 plate with clips on both sides as a finishing touch.
    Aanchir
  • veyniacveyniac Member Posts: 312
    Looks like some new 3x3 engine pieces on the new x-wing. They will definitely be a lot easier to work with than the old piece...
    LyichirBumblepantsMr_Crossgmonkey76Aanchir
  • wardmwardm Member Posts: 886
    ^ Isn’t that a piece introduced with the minions sets?
    No. The Minions sets introduced a 4x4 piece and a 5x5x2 piece, both with a 1/2 module thick rim. This seems to be 3x3x2 with a thinner rim, sort of like the front of the piece used on the earliest X-Wing sets.
    rd1899stluxAanchir
  • AstrobricksAstrobricks Member Posts: 5,478
    Is that a new part in the new TIE fighter #75300 that connects the wings to the body?
    Mr_Crossomnium
  • Mr_CrossMr_Cross Member Posts: 1,688
    Yes. I'm intrigued to see what the top side looks like, I think it's covered on the front.
    Astrobricks
  • CCCCCC Member Posts: 20,526
    A shiv with love.
    BumblepantsKungFuKennypxchrisAstrobrickspanchox1
    edited December 2020
    There are several more new parts in the latest Star Wars sets that we couldn't see. You can see them in the Brothers Brick review: https://www.brothers-brick.com/2020/12/03/lego-star-wars-75301-luke-skywalkers-x-wing-fighter-75300-imperial-tie-fighter-review/ I think the most interesting one is the 1x1 brick with an axle hole. Why didn't anyone think of that sooner?
    omniumFizyxAstrobricks560HeliportAanchirgmonkey76wardm
  • iwybsiwybs Member Posts: 391
    My guess is that it's been considered before, but rejected due to the possibility of stress concentrations.  Perhaps something changed in the material, the molding process, or (more likely) the new part approval process to allow it to be made.  The version with a pin hole isn't as vulnerable to stress concentrations at the narrowest points, and the 2x1 version has more material to accommodate the stress concentrations.
    560HeliportMr_Crossgmonkey76BumblepantsAanchir
  • BumblepantsBumblepants Member Posts: 7,624
    Newly leaked City street set has a magenta bicycle which is most welcome. Tired of med. Azure bikes.
    KungFuKennyJudgeChuckmadforLEGOFizyxrd1899andhe
    Interestng. I'm not sure they are really needed, but interesting shape nonetheless.
    560HeliportFizyxTkattAstrobricksMynattgmonkey76Aanchir
    Nice that they come in multiple colors :)
    560HeliportAanchir
  • ClassicsmileyClassicsmiley Member Posts: 77
    I'd love to hear the discussions in Design Lab when they're coming up with new parts like this...
    560HeliportAstrobricksiwybsMinifigInSpacerd1899Mynatt
  • PaperballparkPaperballpark Member Posts: 4,268
    What slightly confuses me is that I don't see that any of the blind bag builds are big enough to need/use them...
    Edit: Actually, I think they're all in just the Fly Guy one.
    rd1899560HeliportLyichirAstrobricksomnium
    Seems weird they didn’t just use a 1x3 and two 1x1 plates.
    560Heliport
    I assume the propeller on his head is new.
    It's a new color of https://brickset.com/parts/design-54568.
    AstrobricksAanchirandhe
  • Switchfoot55Switchfoot55 Member Posts: 3,351
    ^I think the propeller is part 54568 on top of part 20482? Looks to have come out last year and is in 11 sets.
    Astrobricks
  • TkattTkatt Member Posts: 472
    Another recolor.
    AanchirLyichirmak0137
  • andheandhe Member Posts: 3,940
    Perhaps they are needed elsewhere, and the Mario team just got to use them and were released first. Wouldn't be the first time.
    rd1899Bumblepants560HeliportFizyxiwybs
  • gmonkey76gmonkey76 Member Posts: 1,828
    That or put a fan/grill piece on top, and you have a good A/C unit.
    560HeliportAstrobricksmadforLEGOAanchir
    Or the bottom part of a turntable.
    Astrobricks
    We need that in white for the new bee keeper.
  • timmeyhtimmeyh Member Posts: 20
    That would be awesome, AFAIK they are only in tan and black. (Black is also used in the same set for the engine part). But I assume TLG will make the best of this mold and use it wherever they see fit?
    @Paperballpark that would be rather expensive (blockwise) to make colums out of 2/3 stud bricks but indeed not impossible (like they did with the 2x2 rounded  profile bricks in Brick Bank (92947) )
    Aanchir
  • jmupton2000jmupton2000 Member Posts: 2
    The 2021 set 60284 has two of these black 2/3x2x2 profile bricks at the back, just built one having found it in The Entertainer this morning.  The printed with a grill 2x2 slope is rather nice too.
    There’s a leak of a new mermaid tail mold, but it’s weird because it looks like it’s supposed to represent an ice cream cone with dripping ice cream on the sides...
    In the new Ninjago City Gardens set, it looks like the skirt of the Trolls set used as a plantpot?
    AanchirLyichir
    So it’s not a new part.
    Can someone identify the sand blue part supporting the right side of the Gardens model? My attempts to figure it out on BL went nowhere.
  • ^ I think it’s a recoloured #18940.
    BumblepantsLyichirKungFuKennyAanchir
    Hey looks like dark green masonry bricks in the Ideas Blacksmith set. That is exciting
    madforLEGOwardmgmonkey76CymbelineflordmsandersKungFuKenny
  • 560Heliport560Heliport Member Posts: 3,871
    I haven't seen this mentioned: a new part in #41692 Vet Clinic Rescue Helicopter. It's similar to a 4-wide radar dish, but with four studs on top and tubes underneath. In Vibrant Coral in this set, I haven't noticed it elsewhere. It doesn't appear in the set inventory (yet), but I downloaded the instructions and it's 6317512.
    7BSBumblepantsLyichirAstrobricksrd1899KungFuKenny
    ^ design number 65138, sphere 4x4, w/4 knobs.
  • DadsAFOL2DadsAFOL2 Member Posts: 23
    Bumblepants560HeliportLyichir
    Having just looked through the 883 on the front page, there are loads I just want to own and have in the parts collection with absolutely no purpose in mind.
    Bumblepantsgmonkey76560Heliportpvp3020flordmsandersKungFuKenny
    How is that a sphere?
    560Heliportandhe
    edited January 2021
    And they’re calling this (6337530) a “double sphere”. Does lego not know what a sphere is?
    560HeliportFizyxMynattflordpxchrisKungFuKenny
