Please use our links:
LEGO.com •
Amazon
Importing Database to Excel issues
Apologies if this has been answered before. I just spent the last week updating my collection into the Brickset database. Then I attempted to export it to Excel.
I found an unusual anomaly that I do not know how to fix...
Any set with a 4 digit number came out as a date under the SetNumber column:
eg: 4195 appeared as Jan-95
3 digit number and 5 digit numbers were no problem:
eg: 628 appeared as 628-1 and 10194 appeared as 10194-1
I'd like to get the 4 digit numbers reading correctly...
Any Excel experts out there that could help?
Additional information:
The 5 digit numbers appear as 10194-1 in the input box when the cell is highlighted
The 3 digit numbers also appear similarly: 628-1
The 4 digit numbers have an extra bit that is probably causing the issue: 4195-01-01
Many thanks in advance!
0
Recent discussions •
Categories •
Privacy Policy •
Brickset.com
I did try that at first and it seems to 'mutate' the number
eg:
Airport Set#3182 imports as Jan-82 to a clean new Excel sheet.
If I highlight the cell the input box shows 3182-01-01
If I change the formatting to 'Text' (or any other format not a date) the result is: 468243
So I am not sure what is happening there - for reference I am clicking the "Export" button and then "As CSV" on the following page (I get the same result if I use "Tab Separated" )
The file is downloaded as a .csv
I then open it directly in Excel with all the anomalies
In case it makes a difference I am running Windows 10 Pro on a PC and downloading from a Microsoft Edge Browser and opening into MS Office/Excel Home and Student 2016
Do you think a different Browser might help?
I could change all the set numbers manually but I have close to 230 4 digit sets...
Open to any suggestions...
Again thanks for your help so far.
Thanks benbacardi - much appreciated!
Although its not a one click import it sure beats manually changing over 200 of those set numbers one-by-one.
I appreciate it.
Cheers
