2. Clone Trooper Sergeant torso from #75000
3. Jek-14 with Stormtrooper Helmet torso with legs and missing arm from #75051
4. TIE Pilot torso with legs - could be from a number of pre-2012 TIE sets but #4479 and #7146 are good examples
5. Light up lightsaber Darth Vader from #7263
https://www.bricklink.com/v2/catalog/catalogitem.page?M=sw0436#T=S&O={"iconly":0}
3. Is a bomb squad trooper
https://www.bricklink.com/catalogItemIn.asp?M=sw0299&in=S
4. Looks like this
https://www.bricklink.com/catalogItemIn.asp?P=973px58c01&in=M
5. Isn't star wars but is space
https://www.bricklink.com/catalogItemIn.asp?P=973p61&in=M
Knew that last one looked 90s and ended up searching 'gold torso'.
Nothing will help your searching skills like ploughing through pages on the Brickset main page and Bricklink and following a theme looking at the names.
I will freely admit it requires a lot of esoteric knowledge and educated guesses.
Clone troopers usually have that kind of torso with the curves underneath the breastplate.
2 is definitely a Sith Trooper, but with the red ones released with Episode IX this can make things a little confusing because the one you have is an Old Republic one.
Always happy to give some Star Wars context
Sorry, I was one my phone so linked the wrong figure. It's the other sith trooper from the same set https://www.bricklink.com/v2/catalog/catalogitem.page?M=sw0443#T=S&O={"iconly":0}
3 looks like a coastguard torso from City
can you tell any specific sets from this picture? I was only good enough to identify an 48x48 baseplate. Cheers!
Unusually, it also looks like you have an exclusive DBG wall piece in there which only appeared in #4194 Whitecap Bay. If you had the rest of Whitecap Bay in there that would be very nice!
Everything else is pretty samey but you could look up that large brown curvy piece too.
I think some of the links aren’t working but you can use the numbers to find the pieces or sets!
Although if it's trans bright-green, more likely to be an Atlantis set in there!
I would call that a design a harness or a gun belt before I hit upon utility...
FYI. I knew it was Star Wars (too many results) but actually found it by searching "dark tan torso" (only 8 pages) followed to top of page three... I should have started with "resistance" there's only 33 minifigs and this torso features three times on the first page!
I generally find a broader search term will net the item I'm looking for, but I need to look through more pages (sometimes unsuccessfully), the advantage of this approach for me however, is that I always, always find other interesting things I wasn't aware of! Onto the old wants list they go!
Machete - http://www.brickarms.com/Machete.php
"ARC - Advanced Recon Carbine" - http://www.brickarms.com/ARC.php
Bear claw collar - https://playmodb.org/cgi-bin/showpart.pl?partnum=30-09-8040
I'm a pretty big fan of Space LEGO, but I'm not sure I recall something that closely resembles the kind of thing you've described, certainly within the era you mention at least.
Bricklink lists all the sets with those extending/bendable arms here.
Failing that, was it definitely LEGO? Tente and Tyco both had a space range in the 80s too.
Hope that helps. Please let us know if you find it!
