EDIT: If it does end up being a hoax, I have to give the person who did it credit for thoroughness.
I hope someone finds it soon and puts me out of my misery!
Still stuck?
https://www.bricklink.com/v2/catalog/catalogitem.page?P=48128#T=C
Not very fair since it is a component of a larger piece (Duplo Semi Chassis)... I’ll try not to post any more “parts of parts” :-)
How about this one? (Should be easier...)
https://www.bricklink.com/v2/catalog/catalogitem.page?P=32221
Found it by searching "Belville" and narrowing to white parts in the more options drop down.
So, perhaps an extra challenge here would be: could you find it without searching for the sets you know it's in?
I think it might be troublesome to find because IMO it is in a weird category... and things I would have searched might not include this part as a result.
I think one thing this challenge shows is how few Lego pieces I actually own - I assumed it was a technic piece as it looked like it had pin connectors so was totally down the wrong track....
This a great challenge though (and a good way to learn about unusual parts)
And it was a bit troublesome to find - searches for "plate 1x2 modified", "curve", "angle" gave me nothing, even going for "space" didn't bring it back, but after trying "steer" and "yoke" I tried "control" and that found it!
To keep the game going, have a crack at this:
I thought the top holes looked like the holes you get in parts that go on top of legs, so I looked in the 'Minifig Body Wear' category and searched for 'leg' :)
What about this:
How about
https://www.bricklink.com/v2/catalog/catalogitem.page?P=44534&name=Duplo%20Plant%20Flower%20Gear%208%20Tooth%20(Little%20Robots)&category=%5BDuplo,%20Plant%5D#T=C
bb0093cover
That would be this jack lift arm, had a bunch of these as a kid.
I searched in red for Pivot. Initially I'd searched the Duplo categories but with no luck.
Try this one. I'm afraid the picture is a bit small.
"They are used in the Xalax Racers from 2001. A feature is that they have a slightly movable bumper. When the bumper is pressed the driver is thrown off. 30597 is the part on which the driver sits."
Your turn :)
Maybe Stormchaser could be reminded to give that vehicle base a “part inventory” that links to the tilting piece, and give it a more descriptive name?
Have a quick look, if you can't see it or it's different on your phone I'm sure no-one will disqualify you - honestly, posting the item number should suffice!
For your turn, you really only need to post a picture (you can zoom in, screen grab that and crop it if necessary - that's if saving the image from Bricklink is giving you problems too).
I think it's effectively still your go unless you'd like to defer in which case, I suggest it's open to whoever posts first!?
Some sort of whistle? Kinda reminds me of the Acme 636 clipped to the sternum strap of my pack.
