New parts discussion
1181921232430
  • wardmwardm BelgiumMember Posts: 849
    Are these parts from the new disney princess sets new? (The cloud/smoke part from Aurora’s cottage and the swing from Rapunzels tower)
  • 560Heliport560Heliport Twin Cities, MN, USAMember Posts: 3,158
    The cloud piece is in #80015 Monkie Kid's Cloud Roadster (not released yet).
    Lyichir
  • AstrobricksAstrobricks Minnesota, USMember Posts: 5,225
    edited July 2020
    ^^ Also, are the tan 1x2 bricks to which the swing is attached new?
  • PaperballparkPaperballpark Near ManchesterMember Posts: 4,226
    Hard to say as the photo is terrible quality, but I suspect they're the 1x2 brick with integrated technic pin. Makes sense as it's likely a 4+ set.
    MynattKungFuKenny
    I found a better photo. I looks like I thought.
    560HeliportAstrobricks
    The original crappy image made me think it was a 1x1 brick initially, until I saw the two 1x8 arches.
    560Heliport
    It's 6+ according to the box art that's leaked.
  • BumblepantsBumblepants DFW/BGMember Posts: 7,334
    That swing looks straight outta Fabuland
    KungFuKennyMr_Crossgmonkey76andhe
    The Art sets have this new part, presumably for enabling them to be hung on the wall:
    AstrobricksGothamConstructionCoKungFuKennyBumblepantsstluxgmonkey76560Heliport
  • KungFuKennyKungFuKenny Somewhere between Ice Station Odyssey and FabulandMember Posts: 2,364
    Looks like the new Bespin set has the pitchfork in Light Blue Grey for the first time...
    560Heliportandhe
    They used this in #75222 as well!
    560Heliportandheomnium
    Which, if I recall, they specifically mentioned in the designer video as being a perfect part and were surprised it had never been made in light gray - either old light gray or Medium Stone Gray. It's an old part, too, that's been around for years....early '80s maybe?
    560Heliportandhe
    The new City set has the forestmen hat in light gray too for a statue which is pretty cool.
    gmonkey76560HeliportandheKungFuKennypxchris
  • andheandhe UKMember Posts: 3,741
    edited August 2020
    Yes was just about to mention that. Will look good with the classic peasant torso I reckon. Cue 'new castle theme' rumour mill...
    Crazy when the most exciting part of a $200 lego set (to me) is a recoloured hat... 😆
    Bumblepants560Heliportpxchris
    Interesting!  There are 2 part numbers - I looked at 4496 (the older pitchfork) which only showed brown and reddish brown...
    while the part used in Cloud City and now the Bespin Duel is 95345, which also comes in red in a few Monkie Kid sets this year...
    madforLEGOomnium
  • LyichirLyichir United StatesMember Posts: 975
    Yup. Like updates of several other older parts (the 1x1x4 antenna and the classic minifig spear as just a few examples), the newer version squares off the end so that it can connect to an open stud more effectively.
    gmonkey76AstrobricksKungFuKennyomnium
  • madforLEGOmadforLEGO Chicagoland USMember Posts: 10,520
    edited August 2020
    I thought the grey pitchfork looked familiar, but not due to SW sets, it was also in #70840
    gmonkey76
  • FodderFodder AustraliaMember Posts: 343
    Does anyone know what this bird might be?
    From #60271
    Looks like the seagull to me. #21310 for instance.
    madforLEGOgmonkey76andhe
    Was hoping for a new bird..
    gmonkey76
    I'm always hoping for more Lego animals...
    gmonkey76Fodder
    They need to reprint the newish white/blue bird in grey for some city pigeons. Or even a way to get those white birds in large quantities would be nice.
    Lyichirgmonkey76
    #30412 has two birds.
    LyichirCymbeline
    BnP also now has the white ones available (finally, as they used to be considered 'licensed').
    andhe
    edited August 2020
    Good thing BirdCorp finally went bankrupt ;-)
    madforLEGO560Heliportgmonkey76andheAanchir
    The bird is the word
    edited August 2020
    EDIT: 94p...oof! Think I'll be hanging on a while longer.
  • CCCCCC UKMember Posts: 20,362
    From #60271
    It's funny what you see in new sets. I look at 60271 and see the light bluish grey forestman's hat in the statue. Nothing else.
    andhe
    CCC said:
    From #60271
    I saw the bird almost straight away, but had no idea what the comments were referring to when discussing the (not)monorail
    edited August 2020
    Tkatt said:
    There are 478 new parts in the database today. Lots of recolors but there are few parts I'd never seen before. Most seem to be from the NES set and the Mario Bros sets. This one stood out to me.
    The most exciting thing for me is that the new brick separator from the Art sets is available from Bricks&Pieces.
    I just noticed this in that new list:
    omniumAanchir
    The new parts list that you link to doesn't seem to be working. It says 478 parts, but none are listed. @Huw a bug somewhere?
    I've worked out the problem. For some reason there was no default view! Once I selected 'gallery' they all appeared.
    ^^ I could swear I looked through all 478 parts in that list and never found the SNOT plate with two friction pins on the back.
    @Astrobricks If you choose Medium Stone Grey, there are 36, and it's roughly in the middle.
    Astrobricks
    If I recall correctly the old pitchfork mold was lost at some point, and had to be redesigned.
    edited August 2020
    Seems to have been flattened off at the end. They did that with the spear and the antenna as well.
    @Lyichir explained that above (Aug 1)
    andhemadforLEGO
  • AanchirAanchir United StatesMember Posts: 2,980
    edited August 2020
    To those asking about the swing, it's already showing up in white in #41398! I definitely understand the Fabuland comparisons, especially with it making its debut appearance in a 4+ set. But I feel like it's a step up in versatility from its Fabuland equivalents, since the shape is kept pretty basic/utilitarian rather than overly detailed or decorative, and this new swing piece doesn't need an equally-specialized "frame".
    LEGO is definitely getting pretty good at redesigning a lot of that type of stuff a little more customization friendly. Certainly, slide and stair pieces like https://brickset.com/parts/design-27976 and https://brickset.com/parts/design-28466 might rub some folks the wrong way — I myself remain frustrated the stair piece's top and bottom steps are visibly longer than the intermediate ones! But I definitely find them way more tolerable than stuff like the Fabuland slide and Fabuland spiral stairs. Likewise, I love how neatly the window, door, and wall panel elements in 4+ sets fit in neatly with the existing system of panel and window/door frame pieces. Growing up in the 90s, I encountered a frustrating number of sets where different sorts of windows and doors could be wildly inconsistent in scale due to using molds that had been introduced for specific use in radically different themes.
    KungFuKennyLyichirstlux
  • CymbelineCymbeline CanadaMember Posts: 513
    Does anyone know what the statue in the new CITY set #60271 is supposed to represent?
    Robin Hood? In one of the images I think I see a pair of handcuffs clipped to his wrists, which would explain the arms being bent back.
    Cymbelineandhe
  • BrainsluggedBrainslugged England (the grim North)Member Posts: 2,098
    I just looked it up on the Lego website to see if that gave any clues... and saw the price. £170 for that pile of randomness??????
    gelkster
    Are the big Juniors-y tram ends in #60271 new?
  • ClassicsmileyClassicsmiley USAMember Posts: 55
    They look pretty similar to the one in #60197
    rd1899
    The set is based on the Lego City Adventures cartoon, so their may be some clue their. Apparently that also explains why the Mayor is in a corn costume... 🤷‍♂️
    Cymbelinegmonkey76
    There* there*
    (sorry, autocorrect...)
    Astrobricks
    Don't you just love when "autocorrect" "corrects" a correct word?
    You don’t know what he originally typed :)
    To be fair, I have noticed autocorrect make proper sense of some complete gobbledygook, but also it will change a perfectly spelled actual word, correct in its context, into something insane.
    I just assumed @andhe typed "there" and autocorrect changed it to "their".
