How I break the link between my Brickset and my Rebrickable database?
LebosteinLebostein GermanyMember Posts: 53
If I delete Sets on Brickset then on Rebrickable these Sets sets are also removed.
How do I disconnect this database link?
  • LebosteinLebostein GermanyMember Posts: 53
    Can anybody help me? This is strange!
  • HuwHuw Brickset Towers, Hampshire, UKAdministrator Posts: 7,017
    Change your rebrickable password, that's the only way I can think to do it at the moment.
  • RecceRecce Tiny Little Red DotMember Posts: 923
    edited January 2020
    I'm on the opposite end, I added some new sets in Brickset yesterday but till now it is not reflected in Rebrickable.
    Any idea how long it takes to replicate the data to Rebrickable? I remembered previously it was almost instantaneous, i.e. I add set at Brickset, go to Rebrickable refresh page and it's updated.
    Could it be I have too many sets and it break the limit at Rebrickable? I notice I can't manually add new sets at Rebrickable due to exceeded the account limit, but I think if new sets added in Brickset it should sync through?
    It should be instantaneous. I'll check things when get home tomorrow.
    New sets added still did not appear at Rebrickable.
    Once I did a manual push sync within Brickset to Rebrickable and somehow they added more sets in Rebrickable than what I had, and I had to check through all the sets to correct the data.
    Then last year I instead did a manual pull sync from Rebrickable to grab data from Brickset (which had most of the data correctly sync'ed except for quite a number of unrecognized part IDs for non conventional items), could this be the reason why now Brickset didn't auto sync to Rebrickable?
  • izxizx USAMember Posts: 36
    I've set up Rebrickable to pull sync from Brickset. The only issues I've occasionally had is when sets are imported via CSV, which requires a manual pull/resync for those sets/quantities to show up on Rebrickable.
    @Recce I suspect you are hitting Rebrickable free's 500-sets-per-list limit. Unless you've heard otherwise, I doubt there's a loophole that allows you to bypass that by adding excess sets via sync. You can ask in their forums---from what I've seen, their admins are a friendly bunch.
    I have over 3000 items, and have not had any issue previously with the auto sync.
    Even if I sync (from Brickset or Rebrickable), all the sets will get updated to Rebrickable. Of course, I understand that I cannot manually add individual new sets at Rebrickable due to the 500 sets limit.
    It's only about 2 years back or so that I noticed the sync issue as noted above.
    I stand corrected. Did you exceed the 500 limit around the time you noticed the sync issue? I'm just wondering if Rebrickable's auto-sync obeys the limit while manually syncing allows an override.
    It was already 2500+ then.
