17677798182107
    edited May 2019
    Is 4 Lego? Closest I can think of is https://brickset.com/parts/design-30223 but both sides look the same with the studs on it. I can't find a version that has the second side your door has.
    If 3 was Lego, it looks like a piece that might go to a line like Bionicle, Hero Factory or Galidor. Unfortunately I didn't see any sets that look like they have a part like that.
  • 560Heliport560Heliport Member Posts: 3,370
    Part 9 is indeed from the AT-ST- it's on the front of the, um, pelvis.
  • TheWebExpert1TheWebExpert1 Member Posts: 35
    #4 is definitely Lego; once the part had been identified, it was pretty clear that this particular one is just like the ones in the Harry Potter Hogwarts set.  Ok; I'm pretty sure that #3A/3B may not be Lego after all.  Yes, it does have the connection on the bottom - but there's no markings ANYWHERE.  And although there ARE legit Lego pieces that don't have any markings, on a piece THIS big I'm sure there would be.
    What I wish for is a site where I could enter part numbers on a list, and then hit a button & have it find any set with those pieces.
  • PJ76ukPJ76uk Member Posts: 860
    Try http://www.spoofdata.com/setfinder/
    Ok, thanks for that link; I really needed that.  Switchfoot had his numbers wrong for #8; they're actually 4162206, 4211403 and 241926.  However, the problem remains:  There's no set with these.  That makes me think that they're from separate sets.
  • Switchfoot55Switchfoot55 Member Posts: 3,023
    ^I wondered if I had botched the numbers. Thanks for the fix. Sorry it still came up empty!
  • ShibShib Member Posts: 5,453
    Was just looking over the Hidden Side images and noticed this piece on the end of the train track
    I'm not particularly up to date on Train pieces, is this an existing piece and if so what is its function?
  • BumblepantsBumblepants Member Posts: 7,438
    It is new, I think it's just so kids can drive the train onto the floor. Could be fun to try and find other uses though.
    Shib
    Thanks, I was looking at it and that was the only function I could come up with but wondered if it might have some sort of track splitting function or something when used in offset pairs.
    But as I said I'm not really a train guy so couldn't tell if it was new or just new to me.
    Bumblepants
    Pretty useful for Lego themselves I think. They can have a few bits of a track with a smaller train set like this and don't need to double the price with 16 curves just to make it complete. Kids can make their own 'loop' on the carpet.
    ShibSwitchfoot55Aanchir
  • thatoneguythatoneguy Member Posts: 2
    donutboy said:
    Is that true? Because I clicked on your link right there and it seemed like the page is bad. If you can find another link relating to what you said that would be nice.
    Baby_Yoda
    ^I believe the comment was made in jest and was not actually pointing to a very rare, very valuable piece.
    AstrobricksPyrobugBaby_Yoda
  • AstrobricksAstrobricks Member Posts: 5,331
    ^^ SWOOSH!
    Pyrobug
  • morezonemorezone Member Posts: 207
    My daughter accidentally broke my lad's plane.  Can't quite piece it back together and can't find the original instruction booklet.
    Can someone help and identify the set number for this so I can dl the manual.
    Many thanks.
  • mak0137mak0137 Member Posts: 288
    Many thanks.
    #76001 The Bat vs. Bane: Tumbler Chase
    stluxBaby_Yoda
    @mak0137 Thank you
    I have a couple more for you guys. #1 and 2 are the same part, in dark brown; the others are in brown.  I'm reasonably sure that these are actual Lego pieces.
    edited May 2019
    1, 2, 4 & 5 look like megabloks to me...
    oldtodd33Pitfall69datsunrobbiemak0137Switchfoot55Baby_Yodagmonkey76
    @TheWebExpert1 ; I'm wondering how many non-Lego parts you have that you are reasonably sure they are Lego that you haven't posted? ;) Keep em coming though; we enjoy the detective work :)
    Switchfoot55gelkster
    Shib is definitely right on the Megablocks id.  I found two 2 x 8 bricks with the Megablocks stamp on them in the same box.  It's just that when a part fits so well on Lego, and it's in a box with Lego, you naturally assume it's Lego - unless it's DEFINITIVELY a non-Lego part by virtue of markings.
    I have several parts that are stamped "BTR"; as I understand it, these are fake Lego from Russia.  Are they worth anything to anyone?
    ^ Probably not the best way to look at it. If it doesn't have markings, then it's probably not Lego, unless it's a very unusual shape. Those fence railings, ladders etc. are too intricately moulded for Lego - they'd prefer to print the wooden details, if include them at all.
    oldtodd33Astrobricksstlux
    Are these Lego?  This is the top & bottom side of the same piece; they're tan, and I have 10 of them.
    Here's another one I'm not sure is Lego.
  • MalkanMalkan Member Posts: 64
    BTR was by Hasbro if I recall correctly. I find those in bulk lots once in a while. No idea if they're worth anything, but I don't hang on to them.
  • Koolbrix2018Koolbrix2018 Member Posts: 48
    Yeah, I found a bit of BTR in a lot of LEGO I got - I just threw them away as I don’t keep anything non-LEGO (guess I’m kind of a purist!)
    Here are some more for our parts sleuths!  The closest I can find for # 5 is part # 4872, which is wrong; the other I've found is part # 30390, which still isn't right.
    I'm finally getting to the end of this particular box!
    ... and #12:
    ...and a couple more...
    Wow. Okay...
    6 and 9 are definitely Lego - the first is an extremely distinct Bionicle mask, and the latter clearly has the logo on the studs.
    Are 2 and 16 multiple parts joined together? 2 looks like it could be an Astromech body with a pin in it and 16 looks like an axle with a black round thingy attached to the end. Might be hard to separate in both cases, but if it's real it should be possible with a bit of force.
    4, 12 and 13 all look like they could be Lego but I can't see anything definitive on them. Look on the studs of 12 and the inside of the clips or maybe under the sticker of 13 for the logo. I'd need a clearer picture of 4 to be certain.
    3, 7, 14, 15, and 17 are all almost definitely not Lego. If they are, they must be one-off moulds from the 90's or something, because I've never seen anything like them.
    1, 5, 8, 10 and 11 look probably fake, but I don't know enough about them to be conclusive. They're all shapes that aren't outside of what Lego generally produces but I've never seen those particular ones. Furthermore, they lack logos where I'd normally expect to see them.
  • oldtodd33oldtodd33 Member Posts: 2,641
    Number 16 might be https://www.bricklink.com/v2/catalog/catalogitem.page?P=53585#T=C  with a technic axle in it.
    Pitfall69
    I'm not sure if this is lego; it fits on a standard stud, but that doesn't mean anything.
    Well, that takes care of #1, 4, 8, 9, 12, 13 and #16. #2 is a single part; #16 has been properly identified by OldTodd33 as Part #53585.
    That just leaves #2, 3, 5, 6, 7, 10, 11, 14, 15, 17 & 18.  Many thanks to OldTodd33, who is obviously a Lego genius.
    Part #5 is Kre-o.  Dang it!
    I don't believe any of the other parts are Lego but I would like a couple more good pictures of number 2 part. Also, number 8 has been done by other manufacturers so it should say Lego on it somewhere.
    These were the last pieces in this box.  I've identified the rest (except for the ones still missing from above).  Here's a clearer view of #2 as well.
    ^ Yes, 2 is definitely two parts stuck together. https://brickset.com/parts/design-30361 and https://brickset.com/parts/design-6628
    17, 19 and 20 are definitely not Lego. They all look like projectiles for launchers.
    19, I'm about 90% sure is from the Deluxe Brawl from the first Michael Bay Transformers movie line. Unfortunately I can't get at my box of movie figs to verify.
    The other 2 look nothing like I've seen for GI Joe or Transformers projectiles and I'm not sure what toy line would be best to start looking.
    Ok, we're going to assume that #14, 15, 17, 19 & 20 are non-Lego and proceed from there.  Baby Yoda got it right for #2; that pin on the side was driving me nuts.  I just hadn't pulled hard enough.
    So, here's what's left:
  • andheandhe Member Posts: 3,817
    26,27,10,18,3,21 - not lego
    6 - lego bionicle mask
    edited May 2019
    24 - lego, or almost identical to an existing lego piece. Don't know exactly what I'd call it though.
    On both those lego bits you should be able to look for a part number (and a lego mark).
    I had 'loud hailer' in my mind.
    stlux
