On the individual parts, I'm looking for a verbal description and/or part number. On the assembled parts, I'm trying to find out which set(s) they go to. Thanks!
- Row 1, column 1: 53549
- Row 1, column 2: 32175
- Row 1, column 3: non-LEGO
- Row 2, column 1: non-LEGO
- Row 2, column 2: 32551
- Row 2, column 3: 47299
- Row 3, column 1: 41668
- Row 3, column 2: 53543
- Row 4, column 2: 32576
- Row 4, column 3: 57562
- Row 5, column 2: 53543
- Row 6, column 3: non-LEGO
- Row 6, column 4: 44810
- Row 7, columns 2 and 3: non-LEGO
- Row 8, column 1: 32174, 47297, and 47298. This is probably from a MOC since no set had all three of these parts in these particular colors.
- Row 8, columns 2 and 4: non-LEGO
- Row 8, column 3: 47298
- Row 9, column 1: non-LEGO
- Row 9, column 2: 47298
Also, row 5, column 1 is the cannon from set #8106EDIT: Just realized you didn't have stuff broken into separate rows with enter key so it might display differently on your screen… but the order should be roughly correct.
Also, the part at Row 6, col. 3 IS lego (new pic attached). The blue cannon...
It has a screw in it; I'm not sure what's inside.
AFAIK the parts at 7-2, 8-2 and 8-4 are all Bionicle as well. The ball joint is the same size. That's ALL of the first set of parts identified! Thanks SO MUCH!
Now all that's left is pic 2, 3 & 4 from the 2nd set.
03A
04A
05
08
11
This is pretty much what's left; I've numbered them this time to make it easier. Both #3 and #4 are definitively Lego, as they both bear the logo. It might be a long shot identifying the sets on #5 - 9, but I'm hopeful. Thanks in advance!
Picture 4a and 4b is. https://www.bricklink.com/v2/catalog/catalogitem.page?P=87601#T=S&O={%22iconly%22:0}
1: Still searching
2: #6738 Skateboard Challenge
3: Still searching
5: #5616 Mini-Robot
8: I can't find any set with a combination using parts 609121, 4243812, and 4210984
9: Also struggling to find this combination of parts using a variety of mixes
10: Part 32307 seems to be the closest I can find. Is it the same on both sides as far as the finish? Something just seems non-Lego to me with the color/finish.
If 3 was Lego, it looks like a piece that might go to a line like Bionicle, Hero Factory or Galidor. Unfortunately I didn't see any sets that look like they have a part like that.
What I wish for is a site where I could enter part numbers on a list, and then hit a button & have it find any set with those pieces.
I'm not particularly up to date on Train pieces, is this an existing piece and if so what is its function?
