17576788081101
    ^If only I could do the same...
    Baby_YodaLEGOFan2Bumblepants
    edited April 2019
    ^It's got to be from the Indiana Jones set #7621 The Lost Tomb.
    oldtodd33datsunrobbieLEGOFan2AstrobricksBobflipgmonkey76Oldfan
  • AstrobricksAstrobricks Minnesota, USMember Posts: 4,355
    Baby_Yoda said:
    It appears Hex-a-block is the name of some sort of CAD software. It's possible the company hasn't been around for several years, and has thus faded into obscurity.
    What thread is this a part of?
    LEGOFan2
    This is from a thread started by @Chadix, which appears to have since been merged with this one. Oddly, the comment I was referring to, in which someone identified the part as being from a system called "Hex-a-block", has disappeared.
    Astrobricks
  • BrainsluggedBrainslugged England (the grim North)Member Posts: 1,685
    Can someone help me identify these sets please??
    The middle one is #75100 First Order Speeder.
  • BobflipBobflip Member Posts: 611
    That'll be it, cheers! One of those finds where there seems to be literally no other parts of that set in the job lot it came from, hahah
  • AllBrickAllBrick UKMember Posts: 1,477
    Hello.
    Not quite Lego but, a weird oddity with studs on it.
    Two Tomy cars... Plastic...Studs on roof.
    They look like London taxis,  any clues to the origins?
    FowlerBricks
    Not lego. Don’t care.
    Brainsluggedgelksteromnium
  • thatoneguythatoneguy Munich, GermanyMember Posts: 2
    I have this one piece and I have no idea where it is from. Can anyone help me what it is? I think itś something from the ussr.
  • CCCCCC UKMember Posts: 19,664
    It looks like a 2x2 tile. What is on the other side?
    madforLEGOPyrobugFizyxFowlerBricks
  • DeMontesDeMontes North YorkshireMember Posts: 697
    Could be a 2x2 jumper plate tho ;-) oooooo....
    PyrobugFizyxdavetheoxygenman
    TURN IT OVER!
    PyrobugdavetheoxygenmanBrainslugged
  • FizyxFizyx ColoradoMember Posts: 1,119
    The suspense is killing me!
    davetheoxygenmanAstrobricksPyrobugBrainslugged
    There's always @thatoneguy...
    Pitfall69Baby_YodaBumblepantsBrainsluggedMr_Cross
    I'm sorry. I saw your comment; then I looked at the the original post and burst out laughing!!
    FizyxBobflip
  • donutboydonutboy U.K.Member Posts: 762
    There are two images there. What if one's the front side, and one's the back side? If so, that is an interesting piece, though probably not real Lego.
    PyrobugFizyxBobflip
  • FauchFauch FranceMember Posts: 2,543
    it doesn't seem to have the small groove to insert a brick separator. I think very old tiles were like that?
    edited May 2019
    When I zoom in on it, it does seem to have that notch/groove.
  • CharmiefcbCharmiefcb SydneyMember Posts: 387
    AllBrick said:
    Hello.
    Tomy had Lego style studs on their old Tomy Trains range in the 90's. I don't know if they had Lego style studs on any other range. They could be out of a Trains set from back in the day.
    andheAllBrickBaby_Yoda
  • TheWebExpert1TheWebExpert1 Dillon, SCMember Posts: 35
    On the individual parts, I'm looking for a verbal description and/or part number.  On the assembled parts, I'm trying to find out which set(s) they go to.  Thanks!
  • oldtodd33oldtodd33 Denver 4800 miles to BillundMember Posts: 2,591
    There is a dedicated thread for this. The last part on the bottom right is.  https://www.bricklink.com/v2/catalog/catalogitem.page?P=6125#T=C
    Pitfall69pxchris
    Looks like a lot of Bionice. Maybe @Aanchir can help.
    Baby_Yoda
  • 560Heliport560Heliport Twin Cities, MN, USAMember Posts: 2,472
    Third row, first and second pictures, and fifth row, fourth picture: #10174 Imperial AT-ST.
    jason1976
  • pxchrispxchris Oregon, USAMember Posts: 1,387
    I was going to write a nasty reply to the OP above and then stopped myself realizing that it wasn't worth my energy. I'm glad there are cooler heads like @oldtodd33.
    Got a couple more...
    Thanks for the help so far!  Also, thanks for directing me to the right thread - I knew there had to be one, just didn't know where.
    edited May 2019
    The first pic is from the Star Wars Mos Espa Pod Race #7171
  • AanchirAanchir United StatesMember Posts: 2,921
    edited May 2019
    Most of the Bionicle stuff could be from any number of sets, but part numbers I see for the Bionicle and Bionicle-ish stuff include:
    • Row 1, column 1: 53549
    • Row 1, column 2: 32175
    • Row 1, column 3: non-LEGO
    • Row 2, column 1: non-LEGO
    • Row 2, column 2: 32551
    • Row 2, column 3: 47299
    • Row 3, column 1: 41668
    • Row 3, column 2: 53543
    • Row 4, column 2: 32576
    • Row 4, column 3: 57562
    • Row 5, column 2: 53543
    • Row 6, column 3: non-LEGO
    • Row 6, column 4: 44810
    • Row 7, columns 2 and 3: non-LEGO
    • Row 8, column 1: 32174, 47297, and 47298. This is probably from a MOC since no set had all three of these parts in these particular colors.
    • Row 8, columns 2 and 4: non-LEGO
    • Row 8, column 3: 47298
    • Row 9, column 1: non-LEGO
    • Row 9, column 2: 47298
    Also, row 5, column 1 is the cannon from set #8106
    EDIT: Just realized you didn't have stuff broken into separate rows with enter key so it might display differently on your screen… but the order should be roughly correct.
    Pitfall69mak0137
    Thanks Aanchir for the Bionicle id's ... there are a couple of mistakes you made, however:  The part at Row2, col 1 you identified as non-lego very much is; it's some sort of Bionicle part, though clear.  The end looks like it's made to fit in a light connector.
    Also, the part at Row 6, col. 3 IS lego (new pic attached).  The blue cannon...
    It has a screw in it; I'm not sure what's inside.
    AFAIK the parts at 7-2, 8-2 and 8-4 are all Bionicle as well.  The ball joint is the same size.  That's ALL of the first set of parts identified!  Thanks SO MUCH!
    Now all that's left is pic 2, 3 & 4 from the 2nd set.
       You've obviously not read all of my posts:)
    Baby_Yoda560HeliportpxchrisPitfall69
  • gelkstergelkster MN, USAMember Posts: 641
    We need to start gettin paid for this stuff.
    Switchfoot55
    You could look up a few random Bionicles & come up with most of these.
    oldtodd33:  I only saw one post from you, where you identified the horse's head piece; you also mentioned that there's a specific thread for parts identification.  It looks to me like my posts are now inside that thread... unless I'm seeing things wrong...
    Yes, the mods are good about moving such posts here when they stray from home. Which is why I finally learned not to complain about it :)
    01  02
    03A  03B
    04A  04B
    05  06  07
    08  09  10
    11
    This is pretty much what's left; I've numbered them this time to make it easier.  Both #3 and #4 are definitively Lego, as they both bear the logo.  It might be a long shot identifying the sets on #5 - 9, but I'm hopeful.  Thanks in advance!
    Number six is from #7171 Mos Espa Podrace. It's part of Sebulba's podracer.
    Number seven is from #7092 Skeletons' Prison Carriage.
    edited May 2019
    On picture 11, the white base only comes in two sets but neither of those sets came with the black top so you'll have to figure that one out for yourself. https://www.bricklink.com/catalogItemIn.asp?P=30516&in=S
    Picture 4a and 4b is.  https://www.bricklink.com/v2/catalog/catalogitem.page?P=87601#T=S&O={%22iconly%22:0}
    Number eleven: design 30516, element number 4296249; it came in just five sets: #7669, #7697, #7721, #10179, and #7048.
    I don't know why #7669 didn't get "blued". Maybe this time.
    For picture 6, the round tile only comes in 3 sets so that should be easy to figure. https://www.bricklink.com/catalogItemIn.asp?P=4150ps1&in=S
    Thanks for your help - actually, the base is light bluish gray; I found it on BrickLink, part #30516c02, as part of the #10174 AT-ST set - for which I have MANY pieces!
    Also, you were close on the stockade door; it's actually part #30223, from kit #8874 Battle Wagon (I have at least one other part of that as well).
    So we've got #4A, 4B, 6, 7 & 11... that leaves 1, 2, 3, 5, 8, 9 & 10.  I'm almost there!!
  • Switchfoot55Switchfoot55 The Northwest, USAMember Posts: 2,247
    edited May 2019
    Here's my contributions:
    1: Still searching
    2: #6738 Skateboard Challenge
    3: Still searching
    5: #5616 Mini-Robot
    8: I can't find any set with a combination using parts 609121, 4243812, and 4210984
    9: Also struggling to find this combination of parts using a variety of mixes
    10: Part 32307 seems to be the closest I can find. Is it the same on both sides as far as the finish? Something just seems non-Lego to me with the color/finish.
    For parts 1 and 3, they are large enough that it would be reasonable to see some printed LEGO logo (especially #3 on the underside). Can you confirm if they're stamped at all?
    Part 1 is 2516. In white, it is part of the brick-built "Gasgano" figure in set #7171 Mos Espa Podrace. In other sets too, but we know you have other parts of #7171.
    You all are awesome.  Switchfoot, you were right on target with #10.  That's the part.  I was wondering if #9 might also be from the AT-ST.
