17374767879110
  • PaulMPaulM Member Posts: 45
    Any ideas on these please?
    LEGOFan2
    edited February 2019
    The record deck on the left is from #41106
    The brickheadz base on the right could be from any Series 2 Brickheadz.
    Baby_Yoda
  • ScorpioJWScorpioJW Member Posts: 15
    The transbrick with "075" on it belongs to set #41091
    Baby_Yoda
    The DJ set on the left is from set #41106
    Baby_Yoda
  • 560Heliport560Heliport Member Posts: 4,276
    The minifigure is Gorzan the gorilla, from The Legends of Chima; that version of him came in #70130 and #70136. He appears to be holding custom weapon.
    Baby_Yoda
    Thanks all
  • mak0137mak0137 Member Posts: 288
    Heart in heart is from #30204
    Baby_Yoda
    Cheers
  • klintonklinton Member Posts: 1,256
    Am I correct in assuming the brick on the left is the "yellowish orange" used commonly in place of yellow in modern sets? I need the brick in that colour, and not in minifig skin yellow.
    https://www.bricklink.com/catalogColors.asp?itemType=P&itemNo=3039&v=2
    ^Ignore that. I'm an idiot and sorted it out.
    Baby_Yoda
  • TheMaker37TheMaker37 Member Posts: 496
    Does anyone know which set these figures go to?
  • Switchfoot55Switchfoot55 Member Posts: 3,485
    ^The mysterious invisible set. Only available on February 30th each year I believe?
    It may just be me, but I'm not seeing any pictures?
    AstrobricksLEGOFan2BrainsluggedBaby_Yodamak0137
    It's not just you.
    edited March 2019
    edited March 2019
    ^ I never keep chewed pieces, they are just too ugly to look at.
    LEGOFan2Baby_Yoda
    Yeah, but like... they might be worth like $2 in the year 2075...
    oldtodd33andhe
  • CCCCCC Member Posts: 20,556
    Put them in a jar, then add a few drops of acetone per head. Leave for a day or so and add more acetone if necessary, a little at a time. You end up with LEGO paint.
    LEGO Fan said:
    No! never do that! I keep everything Lego. Well I guess my collection is a bit on the small side but it will turn into a Lego apartment after college.
    If it is junk, it is junk. Those toothed heads are worthless. Similarly, heavily toothed bricks make anything you build with them look like crap and also show you don't care about the quality of the display. If it is a common part and new or decent condition used ones are cheap, then replace them and get rid of the junk. If you can reuse them (such as making paint like above) then all the better. I have a vial of fleshie paint made from a few bad quality heads, it is ideal for modifying parts such as the CMF S3 elf hairpiece, to change the ears from yellow to light flesh. A couple of coats and you have a perfect colour match.
    oldtodd33dmcc0BumblepantsstluxMynatt
    @CCC I never thought of doing that. I don't think I'd do it but I guess it would work if that's what you wanted. I don't suppose you'd mind posting a picture of the "painted " Parts?
  • bookmumbookmum Member Posts: 1,512
    I have a Lego Friends Mia set but no instructions. I am guessing it is some sort of basketball set. There is a basketball net, orange ball, Mia (obviously!) and oddly a gold frog. For some reason I can't upload a photo but does anyone know the set number.
    Thanks.
    Oh hang on. I have found it. It's parts from an amusmemt park set but not the whole set. Oh well. Some cool parts though.
    andhe
  • colaycolay Member Posts: 547
    Evening folks,
    Are these guys cobbled together, or actual MiniFigs (just missing hair and maybe accessories)
    Thanks
    The space fig is the closest with the wrong color legs, should be red. the other two aren't figs. A head with printed microphone doesn't belong on a castle fig. The one in the center almost always has a head with sunglasses on.
    mak0137Baby_Yoda
    thank you :)
  • SketchCardsSketchCards Member Posts: 0
    edited March 2019
    Good day;
    This is my 1st post. Thanks for welcoming me.
    My son has collected Star Wars Legos for years, but due to play, many have lost their correct parts/accessories. What is the best/easiest way to identify them, reassemble them, and title them if we go to resale? Thanks!
    https://pbs.twimg.com/media/D05gSn6XgAUPQgE.jpg
    https://pbs.twimg.com/media/D05gSn4X0AAFXU_.jpg
  • LobotLobot Member Posts: 1,030
    @SketchCards - welcome to Brickset!
    Bricklink has a full inventory of all Star Wars Figures:
    https://www.bricklink.com/catalogList.asp?catType=M&catString=65&itemBrand=1000
    Bobflip
  • BobflipBobflip Member Posts: 728
    Also, if you search that page for "storm*", the asterisk wildcard shows you all the Star Wars figures with "storm" in the name.
    https://www.bricklink.com/catalogList.asp?pg=1&q=storm&catLike=W&catString=65&sortBy=N&sortAsc=A&itemBrand=1000&catType=M&v=1
    Switchfoot55
    ^I just learned something new for my searches. Thank you @Bobflip!
    In the case of the photos a few posts up, you may also need to search "clone*" or "trooper*"
    Bobflip
    No probs! Though your second example isn't quite there. The asterisk indicates a stream of characters (including no characters), so "trooper*" would return any figures called, say, "trooper", "troopermatic", "troopersimpson" and "trooper53uoha89roighsre"... but not "stormtrooper". For this, you would need "*trooper".
    Though it turns out my example isn't perfect either. Searching for "stormtrooper" will yield all the same hits as "storm*", but if there were figures called "storm trooper", only the second search term would work. I typed "storm*" because I couldn't remember if it was one word or two.
    The link I posted stripped out the asterisk unfortunately, but it's added easily enough!
    ^Thanks for the correction. I didn't test my suggestion obviously!
    Still, useful feature.
  • spaceinvader1979spaceinvader1979 Member Posts: 50
    Good afternoon!
    for sure you can help me with this two guys...
    LEGOFan2
  • CyberdragonCyberdragon Member Posts: 551
    DB361 said:
    @stlux Many thanks! Just found the Technic gearbox that only came in that set as well, so might have a go at putting it back together if I have enough of the other parts.
    I have that full set if you want any more info (including what's inside the control brick). Though the internet probably has all of it. Note: It does weird things as it ages, such as make crackling noises when turned off. I have yet to find a fix though, so just take out the batteries if it keeps doing it.
    LEGOFan2
    Thanks for the help! if anyone can help me with the other one...
    LEGOFan2
  • FowlerBricksFowlerBricks Member Posts: 1,731
    The torso on the dude on the left looks like the one of Juno Eclipse from the Rogue Shadow set.
    The one on the left is the Death Trooper, but the one on the right is made of parts from various figures- the torso is from SW0294 Imperial Pilot, or SW0208 Imperial Trooper. The head is from several different Imperials, and I can't tell for certain which pilot the helmet is from. But I'm pretty sure that the parts on the right don't go together.
    LEGOFan2Astrobricksandhe
    Found this doohickey in a box of computer cables at a college earlier today. Can't fathom what it's from or what it does.
    The top part and the cable are standard Lego black. The bottom part appears to be old grey, but it could potentially be faded bley. The cable is a USB - I didn't have time to check what type, though I imagine an earlier version. There are studs at the each end all with the Lego logo inside them, which also appears on one end on a square panel. I don't recognise it and can't find it online. Is it from an old Mindstorms set or...?
    LEGOFan2
    edited March 2019
    That is an IR transmitter from early Mindstorms.
    Edit, this one:
    Came with set kits too.
    dmcc0Baby_Yoda
  • thedoctor46thedoctor46 Member Posts: 213
    Purchased by my father in law, it was assembled with some parts possibly missing, he took it apart for cleaning, but only now he decides to find out what it is. Can any suggest which set this was?
  • datsunrobbiedatsunrobbie Member Posts: 1,832
    #8860 - only one I see with the 69c02 Tap 1x2 base and 4 of those tires
    edited March 2019
    Probably #8860
    ^^ yeah, and lots of red 6x6, 6x4 and 6x2 plates.
    It looks like #8860, but the blue hoses and link chain don't belong, and there's an extra steering wheel... I'm gonna guess #8860, with some custom modifications. I'd love to know what it looked like before he took it apart1
    It seems (according to Bricklink) that the blue hose only came in set #8462, which was 18 years later than #8860. Maybe the original black hoses and the rubber band deteriorated, so were replaced with blue hoses and the chain?
    Thanks all.
