Lego is combining their programmable bricks (like Boost) with their motorized parts (like trains) into one family called Powered Up, but the product line is a little under-developed right now. In the future it will be easy to take the colour sensor from the Boost set and attach it to the train (like I did here) but right now that requires third-party software to make it work.
If you're only buying one set, the train set makes a nice train and it goes around the track. You'll probably want to buy more track, and more track, and more track, then more trains - eventually, anyway. But you get a full train and track system from one of the train sets.
If you buy Boost, what you're mainly buying is a toy programming tool that lets you experiment with a little bit of robotics. The set is designed for building certain models with the pieces that come in the box. It's so specific that of all the sets I own, only the Boost set is kept in its own box, because if you want to do any of the activities you need all the Boost parts handy. It does have quite a lot of fun activities and it lets you freestyle a bit, but it doesn't (yet, anyway) let you combine Boost and a Powered Up train together into one program.
They're both great sets but if you want a train better get a train. And track. Lots of track. With switches. Seriously it's a bottomless pit but it's fun all the way down.
A friend of mine built a Boost train but as you can see the Boost brick is already too wide for the track and you can't easily hide the unused ports and motors.
Is there one set that is better than another as far as a first train set? Is it remote controlled?
The downside of Lego trains is they need a lot of space. Nope, more space than that. Here's a link that discusses Lego trains in fairly good detail.
http://montystrains.net/workshop-blog/2018/2/22/track-planning-for-lego-trains-part-2-track-geometry-and-tips-tricks
Set #60197 is the current passenger train set that includes a motor. It's $160 msrp. It includes 3 train cars and track to get you started. You'll definitely want more track, as others have said. The set gives you enough for a decent oval shape layout, but it's pretty basic. You can also take out the motor from this set and use it in another train if you wish, it's not too challenging to do so.
I really like the old style steam engines, and enjoy the Lone Ranger Constitution Train Chase and the Toy Story train. But those are retired sets and also are not motorized. Plus, they can be expensive on the after market, which is how you'd have to buy it. So you should probably stick with a current set to get started. Set #60051 as the above poster mentioned is good too, and was actually my first motorized set. It's a basic passenger train as well, but I don't know how expensive it is nowadays since it's not the current set.
Totally down the rabbit hole now..... (of course we've been down the Lego rabbit hole, just not the train tunnel until now... lol )
Lego brought out #60098 Heavy-Haul Train in 2015
The 2014 releases were:
#60051 High-speed Passenger Train
#60052 Cargo Train.
2011
#3677 Red Cargo Train
2010
#7938 Passenger Train
#7939 Cargo Train
2006
#7897 Passenger Train
#7898 Cargo Train Deluxe
For some reason Lego didn't release a Station in 2018 (well, #75955 Hogwarts Express has platform 9 and three quarters) as they did for their sets in 2014 (#60050), 2010 (#7937) and 2007 (#7997) which is about all you would normally get. 2010 had #7936 Level Crossing as a slight change of pace as well.
2003 had the City World line, which has some nice sets:
I won't get into Creator sets as with those and basically everything that has been retired, they're sort after sets and you have to pay a hefty premium for virtually all of them (I think the 2014 models can be had for near RRP still BNIB, but not the station, that's nigh on double).
I would say, your best bet is probably looking for a cheapish used #60198 or #60052 on eBay or other. They're quite often split which can be helpful. Though some sellers will sell the locomotive with no Power Functions/Powered Up, so make sure on that, for a bit of on and off track variety.
As for switches, out of the box, it's all manual. I've not delved into automation, but believe it to be possible with some 3rd party motors - 4DBrix are probably the most well known.
https://www.instructables.com/id/LEGO-Train-Track-Switch-Automation/
A lot of the YouTubers seem happy enough to run Power Functions/Powered Up trains on 9v track. I don't have any 9v but the gauge is 6 studs on both, if that's what you were thinking?
Flexible track works ok if you just use one or two pieces at a time, in between regular track. Also, despite it being flexible, it works best in a straight formation. I really only use it to bridge the gap between sections if I come up short. I'm able to space things out with a flexible piece here or there to make it work.
But yeah, avoid it if possible ;)
