Please use our links:
LEGO.com •
Amazon
Display Stands for Ships and Flying Minifigures?
Just wondering if anybody has a good source for the Acrylic Clear Stands seen at tradeshows etc. OR something along the lines of the stands included with the UCS star wars ships?
I've built a few custom stands out of my brothers old Lego stash and they've worked out quite well so far, but have had no luck finding the 'black rounded columns' I've found within their stash (imaged below)
The way I'm leaning now is just to go the Pick A Brick route, order a bunch of black technic pieces and plates and make a go of them myself. But I would LOVE to find some of the acrylic stands like the one featured in Battle of Endor for the flying Ewok.
Thanks in advance for any advice.
0
Recent discussions •
Categories •
Privacy Policy •
Brickset.com
http://www.bricklink.com/search.asp?itemID=42589&colorID=12
Cheers,
The image below that I finally got to attach is what I would eventually like to build for all of my ships. The 2x2x10 (?) columns are the parts I am having a hard time finding. They work perfectly for stands.
http://www.bricklink.com/search.asp?colorID=12&itemID=763
To help stand it up, the piece I showed you before can't stand itself up alone.
Here is the piece you seem to be having trouble finding:
You can stack a bunch of these...
http://www.bricklink.com/search.asp?colorID=12&itemID=756
Note all the pieces are trans-clear, which helps with the display to make the ship look more in "flight", rather than having visible black stands.
Cheers,
I actually found the pillars I was looking for (2x2x11 pillar in black found under 'support'). I ordered 30 of them today from bricklink so I should be good for the next little while. I will have to pick up some plates and hinges somewhere soon as well though.
I like the black stands for the ships so I'm going to stick with that for now, but I do like the trans-clear stuff for the minifigures that would look good in flight. I'll have to order those soon. Cheers.
http://www.flickr.com/photos/vagrantbugler/5891880258/in/photostream
Once I get a little more familiar with how Lego produces the UCS stands I'm sure mine will evolve as well. Would love to see a photo with Slave 1 on your stand.
There were some modifications so I could use the bricks I had on hand and also because I didn't know what the heck was going on in some areas. I also extended the base and made it a bit longer which seemed to help with the stability.
Full write up here: http://nubcakes.blogspot.com/2012/03/taking-stand.html
I'm currently waiting on a pick a brick order to arrive for more stand making. Although, as of right now I have no sets that require one. Slave 1 is looking like the next obvious acquisition.
I have 3 UCS sets, all of which have these black stands: the SSD, Darth Vader's TIE, and the Imperial Shuttle. All the stands are a little different and some are taller than others, but they all look nice and really help to display these creations properly.
I recently built the new X-wing (non UCS) and it is amazing how much it needs a black stand of its own, which the kit does not come with. So I will be whipping up my own for that shortly
Hope some of this helps you!
Here are the latest two I made. Had to make do with what bricks I had which were very few when it came time to build the copter stand. Sorry for the crappy cell phone pic.
For a few other sets I use these, minimalist and fairly cheap from bricklink (LEGO part 2861):
My stand complete with black pieces, finally. Kitty is very proud!
Now, to create a stand that shows off the B-Wing properly. Hmmm.
I just purchased my Slave 1 and i'm also waiting for a PAB order to come in. Can't wait to attempt a stand like this for this ship.
I actually purchased 8097 without figs for $39 off bl.com. I looked at the figs and realized I will be getting all of the figs minus Boskk this summer with the Desert Skiff and Jabba's Palace so i took the plunge.
I also expect to snag Boskk this christmas when SSD magically appears under the tree.
Now my other son wants a stand for his new Rattlecopter.
Thanks to all for the ideas and inspiration.
If you'd be interested, I'd offer you the same/similar 'deal' if you'd build a duplicate? Please PM me if this might be something you'd be interested in.
- Black Tile, Round 2 x 2 - Thin Lifting Ring
- Some Clear 10lb test fishing line
- Screw hook
My heaviest set that I've done this with is the Slave I and it has been hanging for 2 months without a problem. I'm pretty confident the test line and hook are safe, but the 4 stud connection of the model and lift ring has some pretty good clutch. I've disconnected the model from the tile several times for handling.
I do this because all my surface space is for land vehicles or anything that is too large to fly.
I started off with the SW Planet sets and now my air space is pretty busy...
As a result of my increasing use of air space, I had to remove a ceiling fan... no big loss.
My Lego Collection - http://www.flickr.com/photos/jadedanc/
Built a stand immediately for display. I am a big fan of the 'banking' look so I tried to get that feel with this stand (as I do with most of the stands I've built). It turned out pretty rad. I love it! Now to see how it holds up over time. So far it's been two days without any incident.
I'd also like to be able to 'bank' Obi - Wan's Starfighter as well. That'll take some enginieering though.
Built a couple of smaller stands recently and finally found a suitable way to put Flying minifigures in the air. Bricklink order placed shortly thereafter.
Now I just have to find more room to display all these sets. Groan.
