Please use our links:
LEGO.com •
Amazon
10254 Winter Holiday Train question
Having been inspired by threads here I'm thinking of getting the Winter Holiday Train but want to power it. There are sets on ebay with the battery box, power unit, control and receiver but would I need different axles too?
Thanks for any help I'm very new to all this .
0
Recent discussions •
Categories •
Privacy Policy •
Brickset.com
Quick Links
You could also explore other trains that already come with those parts. That was recommended to me once upon a time. You may be able to find #60197 Passenger Train on a sale somewhere. You get all the power function parts and an additional set to build/display.
The typical modification is to put the battery and receiving both in an expanded tender car. This frees up space in the engine and doesn't have the wires running between them.
Other's have either used spare/bought new parts to have longer cars behind it. Or some opt for two sets and then pretty much double everything (or at least select things).
https://m.imgur.com/a/D135p
My plan is too extend the Christmas theme more later but think this should be a good start. I'm sure the train will be longer next year.
Don't mind the wife's sparkle effects...
*only running the Winter Train this year, not using #10259 Station.
I made an extra cart and shoved everything in there; motor, battery box, receiver. I like it better this way, as I don't like the modified engine and the wires running through to the tender.
My wife and I are setting up a dedicated table for #10254 and #10259, and probably laying down some quilt padding to replicate snow. We will probably be purchasing a track pack to get 4 additional straight tracks to make an oval.
If we do choose to motorize it, chances are it would just be the standard way this year (and at that point we'd just go all in and also get #10263 to put on the table as well) and I'd work on creating a better way to hide the electronics next year.
For those that have motorized the set and expanded the tender, was the expanded tender built off the train motor and the battery box and receiver installed on that car, so that the motor is actually pushing and pulling as opposed to just pulling, or did you run wires from the engine to the battery box in the tender?
All this depends on our the dog reacts, we last had a train around the tree when our last dog was here , it did 1 lap and got killed, hopefully Millie will leave it alone :)
So a couple of questions if anybody can help.
As a new guy I don't have any extra bricks etc, I've seen bundles of 1kg on ebay , would this be a good way to start for playing around at any Mods?
I'd like to add lights to my Train etc as its a bit dark under the tree but have been reading about lego lights and got totally confused. Any suggestions on the best way to go about this ?
I was up way too late last night doing just that for my own Christmas project.
5mins on BrickLink in real time is a couple of hours.
A cheap few parts turns into a long expensive list.
But your modifications will be great!
Before I answer and as you are fairly new to the hobby I will post the disclaimer that the info you are about to receive can lead to a very deep and expensive rabbit hole.
You have been warned. :)
For bricks to do modifications to builds, because you will probably want parts that are specific to what you want to build, I personally wouldn't buy bulk lots off ebay as you may get some of what you want but will more than likely get numerous parts that are not suitable.
There are 4 main (online) places to buy parts of your choosing.
1, Lego website Pick a Brick - https://shop.lego.com/en-GB/Pick-a-Brick
Fairly generic bricks - can work out expensive per part but free shipping over £50
2, Lego website Bricks and pieces - https://www.lego.com/en-gb/service/replacementparts?ignorereferer=true
Bigger selection of the currently produced bricks - can also work out expensive on parts although for tiles and larger Technic bricks it can be cheaper than the two sites listed below.
(Unfortunately Bricks and Pieces is shut for the Christmas period, happens every year and usually opens again February time).
3, Bricklink - https://www.bricklink.com/v2/main.page
If it's been made in Lego, it can usually be found on this site - price per brick can be a lot cheaper than buying from Lego themselves but shipping and handling can work out expensive if you place lots of small orders (my best advice would be read any thread on this forum concerning Bricklink and spend a bit of time getting used to the site i.e. wishlists, auto buying and the differences in splash pages for shipping T & C's).
4, Brickowl - https://www.brickowl.com/
Brickowl has much the same concept as Bricklink (wishlists, auto buying etc) but can be easier to negotiate for newbie's to brick buying - There isn't the vast level of items available that there are on Bricklink but should be adequate for your needs starting out. Shipping is normally calculated at the buying stage (no waiting for invoices for shipping/handling to be calculated by the seller) and the parts are easier to search for from the category listing if your not sure about exact part numbers.
The rule of thumb for the last two sites is get as many of the parts you require from a single source as the biggest killer to price per part can be the shipping and handling. Also do some research on the parts your buying, the cheapest part price doesn't always mean the cheapest by the time it's been delivered to you.
As for the lighting of Lego displays, I recommend doing a Google search of 'Lego Lighting systems' and having a read through the various websites available as there are numerous systems out there and it will all depend on whether you are looking for set specific systems or do it yourself systems.
There are options for both and everything in between. :)
I've got an idea of making the engine bigger . I will take a look at the virtual design stuff whilst I'm off work over Christmas and hopefully get an idea of what i need.
All your help is much appreciated.
I'm thinking of using some little lights I found on a few sites and doing my own lighting but will see how it goes.
I'm sure there will be other questions but eventually I should have something to show you all .
But I’d second buying a second set!
@Kev80e if you were to use eBay, I’d look for a second-hand version of the whole set. Even cheaper if it was sold as incomplete (if you’re looking to ‘vulture’ certain parts from it).
Unfortunately, modifying the winter train so close to Christmas will be expensive!
If you’re really keen to modify it, plan ahead:
Some of you may have seen my version of Santa’s workshop in another thread. To get the parts for this I bought three copies of #10245 but I picked one up (incomplete) straight after Xmas when most people were putting their Xmas decorations in the loft and another in the summer (again, sold as incomplete) for a ridiculously low price.
But go for it - it’ll look amazing, I’m sure!
The Mouseketeer options are also excellent, but I'd start with the additional set when it's on sale again.
For lighting I'm thinking fibre optic might work but will experiment whilst I try to mod the set.
Thanks again for all the advice , everyone here has been really helpful.
Meanwhile I've made a start on my heavy lift helicopter so should keep me busy :)
Different train sets.
I bought TLR train when it was highly discounted, and modified it.
i bought the passenger train when it was highly discounted for the remote and power functions.
These buys, while they may not give you the pieces to modify a train, it will give you specialized pieces to build trains...
Between these two buys, the winter train and stealing the old Hogwarts Express passenger vehicle and then extra pieces from here. , I now have two different winter trains, with one of them motorized.
I got the bug and decided to order some lights from lightup blocks but the order has said pending for 2 days now and no answer to my message and email, does anybody have any experience buying from here?
We've purchased #10254 this year (it's yet to arrive), and I was just investigating how to motorise it when I came across this thread... Those four separate parts are quite expensive! And one of them is out of stock on [email protected]
I was trying to motorise a Hogwarts Express a few weeks ago. I started off trying to cram all the Power Function parts from #60051 into a passenger carriage. In the end I just gave up and instead put the two Powered Up elements from #60197 into the coal cart and it make life so much more simple.
The other thing to remember with Power functions is that you really need to have the infrared part protruding from the train as it works much more by line of sight.
Here's my completed Hogwarts if interested. Having everything in the coal cart also looks nice as originally you could see all the Power Functions through the windows of the passenger carriage.
@datsunrobbie Thanks, that's what I read above - and they may all be in stock at [email protected] in the US, but not in the UK ;-) the motor is "out of stock" and the battery box is "shipping by Jan 22nd".
How well does the IR remote work as the train goes behind the tree, for example?
I can't imagine that signal issues would be a concern behind a tree?
I've had no problems with the IR remote when the train is behind the tree, but I don't have much set up around the tree. It will need line of sight, so if it disappears behind a stack of presents or a building it won't work until line-of-sight is restored.
Bluetooth connection for Boost and Mindstorms works nicely, but seems to me to be a bit of overkill for trains, which really only need a speed control for a motor.
