How do you display minifigs?
12829303133
  • sid3windrsid3windr BelgiumMember Posts: 1,395
    ^ \o/ Cloud cuckoo land set!
    I'm going to convert all possible oldskool Unikitties to the new neck, I think.. then need to also think up a display thing.
  • stluxstlux LuxembourgMember Posts: 2,195
    I was also already thinking of "upgrading" the old Unikitties, however the parts are not available in all required colours:
    20482 Tile Round 1 x 1 with Pin is not available in
    • blue (Astro Kitty)
    • dark grey (yes, Apocalypseburg Unikitty still came with the old neck solution)
    35459 Tile Special 1 x 3 Inverted with Center Hole isn't available in
    • blue (Astro Kitty again)
    • bright light orange (Angry Kitty, Super Angry Kitty and Apocalypseburg Unikitty)
    • black (Unisithy)
    But yeah, probably should already convert those where it's possible, as the old neck is super fragile.
    sid3windr
  • 560Heliport560Heliport Twin Cities, MN, USAMember Posts: 873
    Kragle! just kidding...
    gmonkey76
  • mak0137mak0137 VirginiaMember Posts: 263
    edited September 2018
    stlux said:
    Assembled my SDCC Unikitties and expanded my Unikitty display a bit.
    Not sure whether Apocalypseburg Unikitty/Super Angry Kitty/Unisithy would win in a fight (or maybe Camouflage Unikitty would beat them with a surprise attack?), so appointed N-POP Girl to reign over them all.
    Now my daughter wants all this. (Should'nt be looking at the forum with her playing close by.)
    stluxBumblepantsThe_Studmithridate
  • kbwkbw NCMember Posts: 393
    R.I.P. your wallet
    SumoLegodavetheoxygenmanSwitchfoot55dmcc0FowlerBricksLEGOFan2
    @stlux Yeah Astro kitty came to mind as not having all the parts. Still 90% fixed is better than nothing :-) And who knows in the future those parts may pop up...
  • RakulRakul USAMember Posts: 176
    @kbw I have not tried that in specifically but I have ten or so other cases from that same company in for minifigs ,  shot glasses and baseballs.  All have worked great and good quality.  For the minifig ones I use 4x10 and 4x8 plates in reddish brown and they blend in great.
    kbw
    Very much appreciated. Thank you!
  • MaffyDMaffyD West YorkshireMember Posts: 2,532
    Can I derail slightly and just ask @stlux and @sid3windr what the solution is to the fragile neck on Unikittens? TIA!
    The 2018 Unikitty sets and blind bags introduced a new part for the bottom of the head, 1x3 reverse tile with a hole in the middle which fits a 1x1 round doohickey.
    More clutch power than the 1x1 round plate.
    mak0137kiki180703
  • SumoLegoSumoLego New YorkMember Posts: 11,917
    Historically, doohickeys have questionable clutch power.
    (Insert inappropriate Yakov Smirnoff cadence Clutch Power doohickey joke here.)
    sid3windrBumblepantskiki180703
    And I thought doohickey was an American term. Good use @sid3windr.
    sid3windr
  • JohnR80JohnR80 United KingdomMember Posts: 9
    sguser said:
    Just wondering if anyone here labels their minifig collection that is on display?
    Maybe something like the photo below that was mentioned in another post https://forum.brickset.com/discussion/25020/star-wars-mini-figure-display-labels  quite some time back?
    Unfortunately the original poster @Bromwich has not been active for the past 11 months.
    I'm thinking of embarking on enhancing my display in a similar way and hope that you can share your personal experience / suggestions on how to obtain / make the labels.
    I created my own labels based on the SDCC '14 pictures found online.  Excuse the poor quality photo
    kbwThe_Stud
    All_That_RocksstluxAllBrickTXLegoguymsandersmithridate
  • sgusersguser 3rd RockMember Posts: 17
    JohnR80 said:
    @JohnR80 Care to share how you got your labels printed?
    @sguser Yes mate, nothing fancy.  I use a drawing package to create a 16x32mm rectangle and apply my choice of text, so year, name and 'sw' number.  I have a Brady label printer with white vinyl labels which I then print onto.  It's a simple way of doing it, but the finish is fine for my needs and I can trim where necessary.  The label is pretty durable and can be removed two or three times without reducing the quality or leaving crease marks.
    I made some enquiries about printing directly onto the 2x4 tile and was quoted 2.00 GBP per one,  I have over 300 minifigs and have not won the lottery so i decided to do them myself.
    SumoLegodmcc0kiki180703
    I notice that your labels are white print on black background. How did you manage to do it on a white vinyl label?
    And what model is your Brady label printer? I'm thinking of buying one if it's not too expensive
    JohnR80
  • oldtodd33oldtodd33 Denver 4800 miles to BillundMember Posts: 2,416
    edited October 2018
    @stlux ; You ASSEMBLED your SDCC Unikitties? Noooooooooooooooooooooooo!
    mithridate
    @sguser
    I use a Brady BMP51 labelling machine and then the M-91-498 cartridge which has a roll of 120 labels, size of each label is 25.4mm x 38.1mm (1" x 1.5"). Not sure if you're in the UK but the cartridges retail at about 30-35GBP.
    The printer only prints black and white so you can't print colour. I just drew a 16x32mm box, filled it black then changed the font colour to white. Simple.  Printers don't see white as a colour so you can't print it, it just prints the black and sees the white as empty space. If you had the label under a microscope you'd see that the white it is the white of the label itself not white ink.
    Any more questions just ask. 😁
    SumoLego
    @JohnR80 ;
    Thanks for the details!
    Looks like other than having my labels commercially printed, the next best thing will be using the Brady label printer.
    I tried using my brother p-Touch labelling machine to  print the labels but the quality and resolution is quite pathetic compared to you labels using the Brady label printer
    SumoLegoJohnR80
    @sguser
    The only downside is you can only print one label at a time, but if you're using a design program you're only limited to the features of that program, all the fonts and styles to choose from. Get some pictures up when you're done.
  • FowlerBricksFowlerBricks USAMember Posts: 1,625
    ^Wow. That is impressive!
  • jnscoelhojnscoelho PortugalMember Posts: 348
    @TheOriginalSimonB wow, my daughters were delighted to see your collection, as they love Ninjago. Very impressive.
  • TheOriginalSimonBTheOriginalSimonB Felixstowe Member Posts: 1,306
    Thanks both. Of course now I have to do something similar for the bad guys...
  • jonboy2000jonboy2000 Member Posts: 222
    Anyone know anyone selling an acrylic display cases (similar to this one) in the UK or Europe (or maybe the US).  The person I purchased these from no longer makes them.
    PhonegalAllBrickdatsunrobbieLegopantsKLOKRIECHERwardmkiki180703mithridate
    My first homemade Batman frame is coming along nicely...
    Definitely, more Batman.
  • WatfordScottyMWatfordScottyM Member Posts: 392
    Many more Batmans/Batmen to be added!
    You're gonna need a bigger boat.
    jpeg07Switchfoot55obi_gkiki180703MynattWatfordScottyMOnebricktoomany
  • andheandhe UKMember Posts: 2,751
    @WatfordScottyM how did you get the bricks aligned? Always interested to hear people's techniques.
  • benbacardibenbacardi EnglandMember Posts: 367
    ^ For mine, I printed a template, used that to mark the corners of each brick with a tiny cut (I put the template on top and used a craft knife to piece each corner), and then stuck the bricks on using the tiny cuts as a guide.
    andhe
  • obi_gobi_g BlightyMember Posts: 503
    I made a couple of templates in ldd that I can then use to help build with a mix of technic and creator parts. I can size both ribba frames with a number of rows.
    andhe
    This was the first frame I've done, so it was pretty manual with a ruler and pencil.  I'm pleased how it came out, but if I do more I'm going to have to find an easier way.  Perhaps some kind of template.
    My biggest concern was the spacing and whether once the minifigures were in they'd actually look good.  I think it's worked ok though.
    andhe
  • KLOKRIECHERKLOKRIECHER GermanyMember Posts: 119
    My attempt on displaying minifigs:
    datsunrobbieSumoLegoFowlerBrickskiki180703
    I love that scene in Episode III when LEGO Bane teams up with the Wookies on Kashyyyk.
    KLOKRIECHERdmcc0brickventuresjpeg07kiki180703
  • GentlyBenevolentGentlyBenevolent Member Posts: 328
    Still some work to do:
    • Needs more pink/flowers/general fluffiness
    • Need to get parts to build Unikitties to display the alternate faces of the SDCC Unikitties
    • Put it all somewhere dust-free
    Nice collection you got there, I see you are missing Astro Kitty & original Unikitty LEDlite's & the Unikitty LEDlite night lite
    I'm still need to get #SDCC2018-3 Apocalypseburg Unikitty for my collection then it will be complete until the Lego Movie 2 sets come out.
    KLOKRIECHERSumoLegostlux
    Ho, Ho and, indeed, Ho!
    stlux
  • redarmyredarmy AberdeenMember Posts: 704
    Beat this...
    Switchfoot55pxchrisdmcc0andheKLOKRIECHERMynattmithridate
  • FrequencyFrequency Member Posts: 68
    I use display cases that hold 16 each. You can get them at Target.
  • flordflord CanadaMember Posts: 673
    Thinking thinking about changing up my displays and adding lights. How safe are LEDs? Will they cause minifigs to fade like sunlight?
  • CommanderRaabCommanderRaab Edinburgh, ScotlandMember Posts: 612
    #noexpert but is it to do with the UV content of light? In which case light sources that didnt have that should be OK?
