New parts discussion
18911131434
  • BumblepantsBumblepants Member Posts: 7,637
    edited May 2018
    Look at the higher quality picture on FBTB and you will see it is a standard size door and no new odd length parts.
     https://www.fbtb.net/lego/2018/05/17/preview-of-lego-city-fall-assortment/
    gmonkey76MattDawsonAstrobricksMynatt
  • CCCCCC Member Posts: 20,526
    If you look at the bottom of the door... it sure looks to be the same width as the brick or bricks next to it... and above that is the tall 1x2 brick, and the inverted windscreen, which is one stud deep on the bottom... I think we have a new 3-wide door AND a 1x5 tile!
    It would also require a x5 plate as well. So unlikely.
  • 560Heliport560Heliport Member Posts: 3,913
    I have a 4x5 plate. #383 Truck with Excavator. In fact, 3-wide doors from the same time period!
    Do you mean the 5x6 modified plate with hole? I cannot see them bring back parts from about 50 years ago.
    You're right, 5x6. But they do keep making parts in odd sizes- 3x3 plate, for instance.
  • FowlerBricksFowlerBricks Member Posts: 1,731
    Looks like there's a new Silverfish piece.
  • AstrobricksAstrobricks Member Posts: 5,481
    edited May 2018
    I think I see a couple other new parts in this:
    #60190 - the snowshoe on the back of the ice glider looks new.
    #60194 and #60195 - the snowmo-cycle chassis.
    #60195 and #60196 - the big saw blade with the bidirectional teeth.
    Also, why can’t TLG get people to follow directions when assembling demo displays? They put the rear wing on backwards in #60196, and they forgot the hook on the end of the string in #60193.
  • ShibShib Member Posts: 5,469
    On the subject of odd sized parts, I hadn't realised until I got one in hand but the unikitty figure bases are 5 x 3, which looks really odd against a lot of other LEGO parts but makes perfect sense against the figures.
    BrickByBrick
    Yes, very odd sets. In more ways than one!
  • MattDawsonMattDawson Member Posts: 1,490
    madforLEGOAanchirFowlerBricks
    ^ What set is that from?
  • madforLEGOmadforLEGO Member Posts: 10,793
    edited June 2018
    Whomping willow set, and Grand hall. Im sure others, but I know it is in those
    Astrobricks
  • LyichirLyichir Member Posts: 1,018
    Both summer Elves sets and Rapunzel's Traveling Caravan as well.
    madforLEGOAstrobricks
  • BrainsluggedBrainslugged Member Posts: 2,250
    ^And one of those new £3 accessory sets.
    madforLEGOMattDawsonAstrobricks
    Bingo! Give yourself a pat on the back :)
  • LostInTranslationLostInTranslation Member Posts: 5,572
    edited June 2018
    I called up Lego CS (UK) today about some parts missing from my last B&P order and the guy let me buy the new City eagle (6241730; £3.17) and sabretoothed tiger (6237743; £6.12) in case anyone's interested in the price and part numbers.
    The rest was mostly just new hairpieces as usual :-)
    omniumShibGothamConstructionCo
  • Mr_CrossMr_Cross Member Posts: 1,689
    Here's hoping for plates with (hollow) studs on both sides!
    dbrougeVorpalRyuomniumgmonkey76madforLEGOAstrobricks
    Heck I think many are just waiting for a standard plate with studs on both sides.
    Mr_Crossgmonkey76
  • 19741974 Member Posts: 141
    Both of those were made decades ago
  • Casper_vd_KorfCasper_vd_Korf Member Posts: 244
    Really? Do you have part numbers or pictures of them, because I do not remember ever seeing such pieces.
    Correct me if I'm wrong but wasn't it only the solid stud ones that LEGO made and weren't they only made in a test/short run capacity? I don't recall seeing hollow stud ones. I know MB had/have them but the studs are only half hollow on those.
    Mr_Cross
  • gmonkey76gmonkey76 Member Posts: 1,831
    ^Unless you have really small hands, those look like Duplo. But something like that in LEGO system is long overdue.
    edited June 2018
    Yes, those are they. I hadn't seen the hollow stud ones, so, their existence is now not in question, but, these are either prototypes or test pieces that have been acquired in some way. Right?
    If they aren't listed in the inventory of a set, or weren't generally available in a set or supplementary pack that was available to buy in a general sense then, I would like them to be generally available on a permanent basis. Not just in 2x4 either, but in as many variants as possible, including wedge plates and rounds.
    Those are my sons hands when he was about five, so they're regular sized 2x4 plates
    Yes, they're prototype parts that never made in any set. My guess is that it would either blow the SYSTEM or just generally confuse builders. Or maybe ol' Kirk got spooked by the upside down, who knows?
    But it is rather odd with the plethora of new wierd snotty things and thus much more advanced building techniques we have not seen anything like this at all. There are many tricks to invert but nothing as easy and neat as this. It's like TLG doesn't want to touch this kind of building with a ten foot pole
    I know MB have/had(?) a similar part (and I think also in a 2x2 format?) so perhaps that might be copyrighted? I do not know if my parts are made before, or after, MB's
    Scratch the ten foot pole comment ..
    Those plates resemble the early snot bricks (2434 from '90 & 6061 from '92 - I suspect those plates were made around the same time), but those parts only seemed to be used for attaching stuff on the side
    TLG have put out a lot of snot bricks, modified plates, bars, bows and arches so I wonder what he's thinking of?
    I wouldn’t mind seeing TLG release parts like these two. The blue one is definitely MB, and I assume the white one is too, but it has no markings.
    Switchfoot55madforLEGOmak0137
    A possible reason LEGO hasn't made similar pieces- it might be difficult to separate them from other parts. I think they'd need some kind of groove, like on the bottom edge of a tile, so you could use the sharp end of a brick separator.
    Astrobricks
    edited June 2018
    ^ Yes, the little edge cut-in, like on tiles and 2x2 jumper plates would be required for the non-studded piece. The studded piece would be more brick separator friendly.
    @Astrobricks If I remember correctly Tyco bricks had a piece like the tan one in black.
    Astrobricks
    It could be tyco. I found both in batches of used LEGO.
    edited June 2018
    Lots of new parts in the Wizarding World minifigures :-))
    Shib
  • ClassicsmileyClassicsmiley Member Posts: 77
    Including movable short legs, it looks like?  I'm surprised it's taken them this long to make those.
    BumblepantsfloridabrickIceCreamCloneMynattFowlerBricks
    ^I didn't notice that! Cool! I never minded using regular legs for children, i.e. early versions of Anakin Skywalker. Adults aren't all the same size either, and I kinda preferred bending legs for the kids, but this is definitely an improvement.
    Looking again, I think the height of the new legs is right in between the normal legs and short legs.
    Mr_CrossLyichir
    So now we'll have child, teenager, and adult legs!
    BrickByBrickpharmjodLyichirwardm
    Oh man the pearl silver tiles in Voltron! Yowza!
    Switchfoot55Mr_Cross
    ^ there are so many pieces in Voltron, without really looking too closely I can see a wealth of parts in new colours that I'm going to want, not least some of those silver parts, which may or may not all be new, but I want all the same. Looks to be ingots in the light orange (jungle yellow as I think of it)... need!
    BumblepantsLyichir
  • CaptainLegoCaptainLego Member Posts: 385
    Not into HP, but I think that’s a new tea cup mould+maybe a new plate mould.
  • The_RancorThe_Rancor Member Posts: 2,573
    I really like the new loudspeaker element. The classic space blaster is good and all, but with that you could potentially build a full on demo (or the lifeboat scene from Titanic)
    That is a lot of wands.
    davetheoxygenman
    https://brickset.com/parts/new-08-07-18
    New parts from the HP sets now in the Parts database.
    Shibomnium
  • wardmwardm Member Posts: 887
    Are these the new arched parts that were in white on the leaked Hogwarts Great hall set (they were still samples in white)? They look like 1x1 bricks with half stud arches on both sides. Or does anyone else know what parts these might be?
    AstrobricksPaperballparkBumblepantsMr_Cross
    Yes, I think those are the parts that we saw prototypes of before.  You can also see the corner version on the right side of this image: https://images.brickset.com/sets/AdditionalImages/71043-1/71043_Back_01.jpg
    wardmAstrobricks
    ^great !!! didn't notice these!
  • DadsAFOLDadsAFOL Member Posts: 617
    edited August 2018
    Almost a sure thing those new arches make an appearance in the next modular somehow.
    davetheoxygenmanAstrobricksMynattgmonkey76Jern92wardmLegoPegasister2015RogerKirk
