Tree of Creativity 4000026 Dimensions
justb1justb1 Member Posts: 28
hi all
just returned from the most wonderful trip to Billund and the Lego House. Was lucky to bag myself a Tree of Creativity Set. Was just wondering if anyone has this model and can tell me the dimensions. Only info I can find online is the box dimensions but want the actual model dimensions. Even Lego CS didn’t have these available. Only reason I’m asking is that before I build the model I want to buy a display case for it and obviously need to know the correct size to order from PureDisplay.
  • jumalichijumalichi Member Posts: 60
    I'll check that in a few hours after going back home and i'll let you know... A really cool model. I've put it on a shelf close to the Tree of Creativity 4000028 of the last year LEGO INSIDE TOUR. Both are very nice !!!
  • justb1justb1 Member Posts: 28
    That’s brilliant thank you
  • omniumomnium Brickenham, UKMember Posts: 813
    You could just build it, then order the case. But I happen to have mine right in front of me... next to the tape measure...
    23 studs at the widest point
    25 studs at the deepest point == 20cm
    44 studs high == 35cm
    So it would be a tight fit in a 20x20x35cm case. I'd recommend adding some more to each dimension.
    Let me know how much your case costs. Mine is getting dusty :-O
    I decided to have a look at their (new) website :-)
    I reckon it would fit nicely into the case for Krennic's shuttle
    Approximate Internal Size:
    260mm(L) x 250mm(W) x 430mm(H)
    As £40.80, I'm tempted!
    edited June 2018
    (Note, I said Krennic when I meant Kylo Ren. I gave the dimensions for and linked to the case for Kylo's shuttle. The case for Krennic's shuttle is 35cm high, the same as the tree. It would be too tight, IMO.)
    Thanks for all your help. Have you already got any of their cases. I’ve got about 30 to keep all my models completely dust free. I’m neurotic about my sets hence wanting a case before I build my model. I can highly recommend them. Always come beautifully packed.
    I don't have any cases for any of my sets. But most of the built ones are in the loft. I only currently have the Tree on display in the house. I used to have more, but as you say, dust is an issue.
  • FireheartFireheart Suffolk, UKMember Posts: 607
    Sorry the thread title might not be the right one to do this in but it’s the only one I could find on the LEGO House Tree of creativity.
    Whats this that the LEGO Tree of Creativity is no longer a limited 10k production run? Or I should say was never a limited run in the first place!
    omniumFizyx
    Well I never!
    Jan Beyer said:
    The set is not limited - it is a production run of 10.000 copies and as this is an exclusive to LEGO House set there might be more production runs if it sells well and potentially out.
  • CCCCCC UKMember Posts: 18,864
    Name
    LEGO® House Tree of Creativity
    Product number
    4000024
    4000026
    Amount of boxes produces
    175
    10.000
    Piece count
    1008
    837
    Release date
    1st of May 2017
    1st of March 2018
    Box size
    Length: 310 mm
    Width: 230 mm
    Depth: 72 mm
    Length: 382 mm
    Width: 262 mm
    Depth: 70,5 mm
    I find it interesting that the smaller (retail) model needs a bigger box!
  • Muftak1Muftak1 Somewhere cold, probably raining (aka Ireland)Member Posts: 511
    Anybody going to Lego House that could pick me up one? :-)
  • ShibShib UKMember Posts: 5,330
    The box is massive, really anyone picking one up for you would be justified in asking the going price on bricklink, unless you actually know someone who is going personally its a very big ask.
    I have a copy and frankly the cost of the trip and the difficulty in transporting it I wouldn't sell for any less than £120, and even then I'd worry about shipping it.
    If I were you I'd look at saving up for a trip to Billund to buy one yourself. Either that or just bite the bullet and pay the bricklink price if you just really want the set that much.
    Bumblepants
    edited June 2019
    I bought the Krennic Shuttle case a couple of weeks ago, and I'm quite pleased with how it looks, so figured I'd share a photo.
    The case is a wee bit tall, but I'm glad of a bit of headroom for it.
    I've noticed they now do some other cases with the same base dimensions, but slightly shorter. I can't remember which ones, though. Losing 3cm or so would work well, I think.
    pxchrisstluxDeMontesravendragonwingsid3windr
  • AstrobricksAstrobricks Minnesota, USMember Posts: 3,111
    ^ From whom did you buy the case?
  • Russell844Russell844 California, USAMember Posts: 1,942
    This might help you @ravendragonwing
    ravendragonwing
    Sorry. I should’ve read the whole thread :-/
    omnium
  • ravendragonwingravendragonwing Member Posts: 150
    Ouch, shipping to the US is very expensive ($45)......
    Yeah... won’t be buying any there.
    Yeah, sorry. I should have given more of a hint when reviving an old thread!
    Anyway, you worked it out...
    Astrobricks
