Tram from 8404 to monorail or motorise with PF?
zumazuma Member Posts: 17
edited March 2012 in Building and Techniques
Hi,
I wondering with the tram as to which would be better and leave the tram still looking nicely tram-like and functioning well and seeking advice:
Use a monorail base and motor and use on a monorail tracks.
Motorise with PF and run on train tracks.
Would changing the layout require substantially, and has anyone done both and found and issues?
Thanks
    I've done the PF on the tram - the central section needs a full rebuild and needs to be slightly longer - I've seen a build on the web that got it to 4 studs extra, and I got mine down to 2 studs extra. Looks great with the lights, and moves REALLY fast as it's so light.
  • madforLEGOmadforLEGO Chicagoland USMember Posts: 10,522
    Will the 8404, built the way it is out of the box, work with the new 'narrow' gauge track that resides in the temple of doom/funhouse sets, and soon to be mining set due out? Wondering if I can motorize it without changing its 'gauge'. Because I think for that the 'narrow' gauge track will be a straight piece in the mining set. (but not certain of this)
    no, its standard gauge
    Thanks.
    In which case I have a use for all of that old 80's train track.
    If Lego ever decided to build a rollercoaster - that narrow gauge track with vertical curves would be awesome to use.
