Please can someone measure the old fishing store for me? - Not exact height
PebblesPebbles Member Posts: 173
edited February 2018 in Everything else LEGO
I'm looking for a case to put my as yet unbuilt fishing store in, however i'm having trouble finding one which allows for the 32cm height.
It seems 30cm x 30cm is much easier to get hold of, so with this in mind I thought maybe I could leave the weather vane chicken off the roof.
Could someone with the set already built please measure it and let me know if it's below the 30cm height restriction.
Thank you in advance. :)
  • milambermilamber Member Posts: 637
    @Lego_Minon If you take of the chicken and the two parts underneath it it's just under 29.5cm, give or take a mm. That's including the grey top part to the roof, but nothing above which is the chicken and the mount for it. I make it just over 33cm to the top including the chicken. The bit below is what needs to come off to get under 30cm
    Pebblessnowhitiestluxricecake
  • PebblesPebbles Member Posts: 173
    Oww so it should, in theory, fit in a 30cm x 30cm case. That is excellent news. Thank you so much :) At least I have some wiggle room as I can remove the grey bit if required.
    Yep, will definitely fit with that bit taken off, just! Where are you looking at cases if you don't mind me asking. I'm getting fed up with dusting......
    Looking on ebay at the minute, will let you know about quality etc when it arrives if you like? :)
    Thanks
    Pebbles
  • HugeYellowBrickHugeYellowBrick Member Posts: 496
    Anyone know of a case that will take #10253 Big Ben?
    Thanks
