I also sent a request to brickbuildr and haven't heard from them either.
Did you get a response from wallofbricks?
My local store is Sheffield and I just post a video on the LUG YouTube channel every week. Its a lot easier!
https://m.youtube.com/channel/UCjeIMeChmDGPEoMi1h5wHZg
What's wrong with The Leg Ow All?
Should have just used this name and kept the original url. lol
Below is what they had last night:
PAB wall bins (10 bins by 5 bins )
yellow translucent , 1x1 circle plate
light grey, 1x1 brick with headlights
sand green, 2x1 plate
black, 2x1, tile with handle
white, 4x1 plate
tan, 3x2 plate
light grey, 2x2 plate
white, bracket 2x1 - 2x2 (down)
translucent clear, 45 degree slope 2x2
Black 2x1 brick plate
light grey, wheel 11mm D. 12mm
black, tire 21 mm x D. 12 mm - wide tread
green, 1x1, brick with headlights
clear translucent, 1x2 brick
1x1 joystick (grey base, black stick)
transparent clear, 1x2 block
translucent red, 1x1
black, 2x2 plate with 2 wheel holder-axles
light grey, 2x1 plate w small towball socket on the side
light green 2x2 plate
White, 1x1, circle tile with eye print
pink, 2x1 plate
light green, 1x1 circle plate
green, 1x2 slope
green, hinge plate
light grey, 1x2 plate w small towball on the side
green 2x6 plate
light green, 2x4 plate
green, 2x1 bracket 1x2 -1x2 inverted
tan, 2x2 tile with center stud
green, flower stems
tan 1x3 plate
aquamarine, 2x4 brick
tan 2x6 plate
yellow, 2x4 brick
white, 1x6x5 wall
pink, 2x4 brick
blue, 2x4 brick
white 2x4 wheel wells
dark transparent grey, 4w x 3L x 2h windshield
Red 2x6 plate
light orange, 4x2 brick
light orange, 2x4 bric
Red 2x6 brick
brown, 2x4 brick
yellows 1x6 brick
light green 2x4 brick
black, 2x6 brick
tan, 2x4 brick
light grey, 4x4 plate
orange, 2x4 brick
blue 2x4 brick
white, 2x4 brick
(9/28/[email protected])
HTH
Walter
Those part numbers and descriptions have been copied off Bricklink, so hopefully they make sense.
I'm not 100% on my shades of Pinks and Blues, but otherwise, I think I've got it all correct.
Cardiff was last updated last October, so that was probably me as per my previous post above this one...
Anyway, I think I have got it all correct for todays visit except for the following;
The bin with the eye in it has three different eye prints; 98138pb028 Tile, Round 1 x 1 with Black Eye Closed with Eyelashes Pattern, 98138pb027 Tile, Round 1 x 1 with Black Eye with Pupil Partially Closed Pattern, and 98138pb007 Tile, Round 1 x 1 with Black Eye with Pupil Pattern
Only that last one seems to be listed on Wallofbricks, so I couldn't add the other two.
Also the empty bin on the right hand side of the second row actually contains 99780 Bracket 1 x 2 - 1 x 2 Inverted in Green which also doesn't seem to be listed on Wallofbricks.
As in my previous post, those part numbers and descriptions have been copied off Bricklink, so hopefully they make sense.
Been to Cardiff this morning and many of the parts on the wall are the same as before, although there are a few changes.
As my previous post above, the bin with the eyes have three different eye prints with only the one able to be selected on Wallofbricks and the green 1 x 2 - 1 x 2 Inverted bracket isn't listed on Wallofbricks either.
I think I've got everything else on there correct.
Personally I find videos take too long to sit and watch to try and find out what's there and half the time it doesn't seem very clear to me what the parts are when it's an out of focus mass of a sinlge colour. Much prefer being able to glance at a grid of clear images. Personal opinion aside:
Links to parts missing from Wallofbricks that are currently at Cardiff
Eyes, all three of the following in one section;
https://brickset.com/parts/6097402/flat-tile-1x1-round-no-26
https://brickset.com/parts/6099548/flat-tile-1x1-round-no-27
https://brickset.com/parts/6001609/flat-tile-1x1-round-no-8
and the green brackets;
https://brickset.com/parts/6099243/angular-plate-1-5-bot-1x2-1-2
It's a nice idea, and shame it doesn't work.
I have often wondered whether it could be done just by the user looking up and inputing the LEGO part ID themselves, but via an ascii file for the whole wall at once so it is (reasonably) quick and easy. So not with the graphical side - that is the bit I found to be quite slow. Using element IDs is quite quick if you know how to look them up on brickset.
PS. I think I was the first to mention it here, I beat you by a day or so! I cannot remember where I first saw it online, maybe at BL.
http://bricksetforum.com/discussion/comment/198074#Comment_198074
IIRC, the biggest problem I had was certainly the UI, but more particularly, the inability to clear the entire wall. When I last went to update the London Westfield store, every bin was different as it had been so long since the previous update.
The wall layout didn't match the store, but I realised you really only need a list of items, you don't need to know the position on the wall.
Anyway, it's a moot point saying as you don't intend updating it :)
And you never did reply to my email to [email protected] asking how my email address (that I created specifically for use with your site) got into the hands of spammers... :O
When I go to the store and see new parts on the wall, I take a photo of each bin that's new and share that with my LUG mates. Also anything interesting in the Build a Mini bins.
One person posts a new element and others can chime in in the comments where else they've seen it.
https://github.com/dwalton76/wallofbricks
Some flowers and greenery, along with coral colors parts like 1x1 wedge tile, orange carrots, green carrot tops (leaf pieces), green bouquet stem pieces, curved coral tile, 2x2 blue flower petal parts, in the PaB walls (at least for Schaumburg IL LEGO store).
The minifig station had some solid new additions though - picked up the torso and hat for the CMF Series 11 "Bobby" Policeman, plus some 50s hairdos to go with the DD/CG
I hope it isn't here to stay.
While I like having a larger choice of elements, it's a pain picking them apart. Eg. from bricknation's photo, I'd like a tub of DBG 1 x 2 tiles, but I don't want to have to filter out pink 1x1 round plates. That's really tedious! :-O
