Hello all!
After having seen the 75192 Millennium Falcon in person (wowzers!), I was blown away by the "minifigure-scale" claim that goes along with it. I immediately started saving for the Slave I, which makes the same claim, as the idea of collecting sets that are truly the correct size according to minifigure height seems fascinating to me, and gives an awesome sense of the size of the ship.
That being said, I went on a spree and tried to find more sets that matched this criteria (compiled in a bricklist here: https://brickset.com/sets/list-22350)! Also below, to save your clicks. Minigure-scale is being defined classically as 1/45 regarding the minifigure's height, so the formula I have been using is:
(length of spacecraft) / 45
______________________ x 100
(length of Lego set)
For the Bricklist, models within 10% of perfectly to-scale qualify, and only the most to-scale version of each spacecraft is included.
If any of these need corrected, or if there are any you would like to add, reply in the comments, as I would love to know for my collection! I will continue to update the list as I continue to research as well.
75050 B-Wing Starfighter
665.35 / 45 = 14.79 (15.04)
98.34% to scale
length of ship scaled: 14.79 http://starwars.wikia.com/wiki/A/SF-01_B-wing_starfighter
length of Lego set: 15.03 https://brickset.com/sets/75050-1/B-Wing
75175 A-Wing Starfighter
377.953 / 45 = 8.40 (7.87)
93.69% to scale
length of ship scaled: 8.40 http://starwars.wikia.com/wiki/RZ-1_A-wing_interceptor
length of Lego set: 7.87 https://shop.lego.com/en-US/A-Wing-Starfighter-75175
75060 Slave I:
846.46 / 45 = 18.93 (17.72)
93.61% to scale
length of ship scaled: 18.93 http://starwars.wikia.com/wiki/Slave_I
length of Lego set: 17.72 https://shop.lego.com/en-US/Slave-I-75060
10212 Imperial Shuttle
956.69 / 45 = 21.26 (22.83)
93.12% to scale
height of ship scaled: 21.26 http://www.theforce.net/swtc/lambda.html
height of Lego set: 22.83 https://www.bricklink.com/v2/catalog/catalogitem.page?S=10212-1#T=S&O={"iconly":0}
75192 Millennium Falcon:
1368 / 45 = 30.4 (33)
92.12% to scale
length of ship scaled: 30.4 http://starwars.wikia.com/wiki/Millennium_Falcon
length of Lego set: 33 https://shop.lego.com/en-US/Millennium-Falcon-75192
9493 X-Wing Starfighter:
492 / 45 = 10.93 (12)
91.08% to scale
length of ship scaled: 10.93 http://starwars.wikia.com/wiki/T-65_X-wing_starfighter
length of Lego set: 12 https://shop.lego.com/en-US/X-Wing-Starfighter-9493
(Unless my math was wrong, I could not find any to-scale TIE Fighters or Y-Wings, which was disappointing).
@henrysunset did some calculations http://brickarchitect.com/scale/ and also had an article in Bricks about it. His scalings came out at 1:42 for height and 1:25 for width. As your results are about 92-93%, if you use his 1:42 instead, your results will be even better. But do the same calculations based on width, and you are a long way from minifigure scale.
This has the knock on effect that even if something is in scale with the height, it won't be with the width, meaning that if two people are meant to sit side by side, chances are they cannot. Also, for example, in the X-wing, R2-D2 has to go sideways rather than facing forward. Compromises always have to be made, for SW ships the dimensions of the ships need to be relatively correct using the same scale in each direction or they look odd. But this will mean that minifigures won't necessarily fit sideways even if the height works. Similarly quite a few City sets tend to have a single driver in a vehicle, centred rather than two people seated side by side, otherwise the vehicle needs to be very wide.
Luke’s Landspeeder
133.86 / 45 = 2.97 (7.09)
41.96% to scale
(It's much closer in regards to width, but still not scale, so wouldn't be quite right next to the MF)
edit: Granted, it would be nigh impossible to make small vehicles to scale and fit minifigures, they did the best they could
