Townhouse parts list from Pet Shop set 10218??
Mcook376Mcook376 Louisville, KYMember Posts: 3
Does anyone have a list or a link of the parts to build only the townhouse from this set?
  • madforLEGOmadforLEGO Chicagoland USMember Posts: 10,655
    If no one has it, you can use a copy of the instructions from LEGO's site and a bricklink parts list (or the parts list found on the back of the Pet Shop instructions) to make an inventory  (that is what I did with the #7747 Wind Turbine transport instructions to just make the Wind turbines). Sometimes people do not have it and you have to go the 'long' route in order to make half a set.
    rd1899Bumblepants
  • rd1899rd1899 U.S.A.Member Posts: 206
    edited December 2017
    Here's an AFOL-made Lego Digital Designer file (LXF format) for the #10218 (EuroBricks post).*
    If you open that file up in Lego Digital Designer,  the sections of the build are organized into groups, which can be selected and deleted, so that only the townhouse section is left.
    Then, you can save the modified file and use a parts list generator (LDD Manager, Brickulus.com) or create a new wishlist on Bricklink and upload the modified file to populate the wishlist.
    LDD can also create an HTML file with building instructions that has a parts list at the end, but that takes some time to compile and doesn't seem to give parts number.
    On Rebrickable, there's also a MOC version of the townhouse that uses parts from a few recent Creator sets, if you're not too particular about the color scheme or design accuracy.
    *FYI:  For additional LDD files of hundreds of official sets, see this EuroBricks thread.
