Set. 31050: Corner Deli plan to turn it in to a modular building MOC.
124»
  • pharmjodpharmjod 1,170 miles to Wall Drug, USAMember Posts: 2,916
    Corner Deli is $15 at amazon now. Limit 2. 62.5% off
    https://www.amazon.com/LEGO-Creator-Corner-Deli-31050/dp/B017B1BESC
    BillyBricks84khmellymelmadforLEGO
  • CCCCCC UKMember Posts: 19,772
    Nice price.
    ^back up to $29.99
  • RogerKirkRogerKirk BrightonMember Posts: 364
    I'm finally having a go a building a corner deli out of three sets. I've got most of the structure of the ground floor built on a 32x32 baseplate- 16 studs wide and 25 long.
    It's built to have the pavement on two sides and has space for another small building at the side.
    Only I'm having real difficulty doing the main door. I'm trying to build it at an angle, making it a proper corner building. But after several hours last night I still don't have anything that works. I've seen some ideas in videos that should work, but I'm going to have to introduce a couple of additional pieces, which I was trying to avoid :(
    I'll try and post some pictures later...
  • wardmwardm BelgiumMember Posts: 787
    Anyone allready made a modular compatible moc with the ‘park street’ set? Or with the new modular type creator houses?
  • paul_mertonpaul_merton UKMember Posts: 2,966
    For UK peeps, this set works out at £18 in Tesco's current 3-for-2 offer (if you buy a multiple of 3, obviously).
    I thought about reviving this thread because of the newer set #31097 Townhouse Pet Shop & Cafe
    Anyone planning on modding that one into a modular form?
    CaptainRogersBumblepants
  • CaptainRogersCaptainRogers Greensboro, NCMember Posts: 839
    @wardm I probably will. I've done with the previous Bike Shop & Cafe from a few years back and the Corner Deli. Some seem to really lend themselves to conversion with a copy or two and one's spare parts.
    wardm
  • BumblepantsBumblepants DFWMember Posts: 6,983
    I plan on modding it into a Ninjago City modular (or at least part of one). Hopefully some decent discounts will be found leading up to Christmas.
  • RecceRecce Tiny Little Red DotMember Posts: 923
    The City Creator 3-in-1 houses have always been good as a base to create bigger modular versions with multiple sets.
    Even some of the older Friends building sets can be upgraded as well.
    mak0137LittleLorichrisalddin
