2 - https://www.bricklink.com/v2/catalog/catalogitem.page?P=43712pb040&name=Wedge 6 x 4 Triple Curved with 7 Green Dots and Black and Silver Lines Pattern (Sticker) - Set 76003&category=[Wedge, Decorated]#T=P&C=85
6 - https://www.bricklink.com/v2/catalog/catalogitem.page?P=61678&name=Slope, Curved 4 x 1 No Studs&category=[Slope, Curved]#T=P
7 - https://www.bricklink.com/catalogItemIn.asp?P=44126pb002&in=S
7 is from #7668 Rebel Scout Speeder
4 is part 61406 in a few sets
(plus the link says it's 13" high)
I was playing through Lego Batman 2 recently, and one of he minikits at the end of the level used a part I cannot find. It's like part #13548 but inverted, or #3676 with the outside corner cut and only 3 studs on top. I've looked high and low and can't figure out if it's even a real part.
Here's a pic
As far as I'm aware, that part doesn't exist, so probably a developer's folly. Would be a useful part to have though...
Thanks for any info. And sorry if this is super easy, I am new to this.
Hope that helps.
https://brickset.com/sets/2518-1/Nuckal-s-ATV
(I have 2111, but not the spinner @Hanzo posted).
https://www.bricklink.com/v2/catalog/catalogitem.page?P=32281&name=Technic, Figure Accessory Impact Vest Type 2&category=[Technic, Figure Accessory]#T=S&C=24&O={"color":24,"ss":"UK"}
@bobflip looks to be from set #8305 Duel Bikes
Looks like a turtle shell a little.
From what I see, there appears to be at least a few Mega Blok items mixed in (among other non-brick toys). One other broken 2x8 in the top right corner.
I've identified a sticker from set #3182 (left middle). Also possibly a panel of glass from #6380 (upper middle).
Any other big red flags or parts that stick out as identifiable to a particular set? There is the boat in the bottom middle that could be from one of a few sets, some sort of blue sloped piece with a sticker on it in the middle of the tub, plus all the red/yellow frame pieces I can't seem to find a set for.
There is a closed stud minifig in the bottom right too, but can't quite make out what's on the torso.
Red door in yellow frame is in a bunch of "basic" sets, took me a bit of searching last week when I found them at the local thrift shop. Bricklink often has older parts that don't show up on Brickset, probably stuff that is no longer in production .
Some more details: it is an 18 gallon tote. Google says the dimensions are 26 x 18 x 25 (inches). Asking $50.
I'm committed to buying it. I think it'll be a good deal either way.
Last night I mainly worked on separating out any Mega Bloks I could find. So far it's pretty minimal. I also started sorting out anything with a sticker, number, or pattern on it for easier identification. I didn't have too many issues locating stuff. So far I've identified pieces from about 40 different sets.
I'll attempt to take fewer pictures with more items in them to help with the identification to avoid clogging up this thread.
Any ideas on these two? They’re part number 87748, but Bricklink only has 3 custom items for custom chromed versions - search comes up with nothing for the actual part.
Not sure what the main white chunk is, but there are a few bits that say Republic Gunship to me (pointy white bit at middle left, white and red bit below Slave I). But there have been 3 or 4 versions, so I couldn't say which!
I have attached photo's.
