Palm Trees
stickbug29stickbug29 United StatesMember Posts: 68
Hey all!
I was just wondering, as I'm new to this, what strategy would you use in building a Lego palm tree?  I liked the look in the photo, but realized when trying to buy that the official palm pieces are quite expensive and mostly sold from far-off countries.  I'm assuming this piece isn't as common as I thought it was, so what would y'all do?  Also, any other general tips to improve the model would be helpful!
  • kwkwkwkw USAMember Posts: 1,188
    Check out the most recent pirates chess set, there's a nice looking palm tree in it
  • carnage717carnage717 U.S.AMember Posts: 166
    Set 75171 battle of scarif has a nice palm tree
  • TheOriginalSimonBTheOriginalSimonB Felixstowe Member Posts: 1,621
    Or #70604 Tiger Widow Island.
  • madforLEGOmadforLEGO Chicagoland USMember Posts: 10,101
    What is a bit annoying is how many times I have seen both large and small palm leaves in PaB walls in stores.. Would love it to see them put the palm bases/trunks into a PaB wall at least once.. Sadly though it seems that PaB walls have gone somewhat 'basic' now, and I have not even seen any more PaB models to build (I wonder if LEGO quietly killed that feature of the PaB walls now?)
    What I think is worse is the apparent frustration of the LEGO stores to get any parts (let alone good ones)
  • davee123davee123 USAMember Posts: 814
    It's still expensive, and doesn't bend as nicely, but you can also use the "fez" pieces, which are available in brown:
    You need to be a little creative with how to attach things to the top and bottom, but it's feasible.
    DaveE
    LEGO_Dad77davetheoxygenmancatwranglerMynatt
  • Wiler1969Wiler1969 Seattle, WAMember Posts: 1
    Beauteafull job, i think u have worked a lot till u made it!
  • AllBrickAllBrick UKMember Posts: 1,477
    Part number 2536 on Bricklink for the trunk... It's articulated for easy curvature.
    I also use 3mm rigid hose threaded through brown 1x1 round bricks that are arranged close but not connected,  then you can add the topping and curve of your choice...
  • Glacierfalls265Glacierfalls265 USAMember Posts: 257
    I'd never seen these techniques before, but the first one looks so realistic! Now I'm going to have to try it lol
    DeMontesRogerKirk
  • sklambsklamb speaker of American EnglishMember Posts: 511
    Agreed, the Washingtonia is brilliant!
  • BillyBricks84BillyBricks84 United StatesMember Posts: 355
    Here is one made from buckets (it's not mine and can be found here):
    madforLEGOgmonkey76IstokgAllBrickLegogramLittleLoridavetheoxygenmancatwrangler
    So I ended up making the Washingtonia! It now proudly stands in the Winterfield Academy Greenhouse!
    AanchirLegogramRogerKirkLittleLoricatwranglerAllBrickCalv
