New parts discussion
13468923
  • CCCCCC UKMember Posts: 19,139
    Currently only in br. red-violet.
    Let's hope they make some in the greys.
    CM4S
  • FauchFauch FranceMember Posts: 2,492
    I expected the H fence to appear in temple of the ultimate weapon, but it uses prison bars instead. maybe the H fences are inside.
  • wardmwardm BelgiumMember Posts: 714
    golden banana in the new Ninjago Movie sets
  • thedoctor46thedoctor46 UKMember Posts: 206
    Light blue fish in the Ninjago sets, as well.
  • MynattMynatt OH/NYMember Posts: 594
    Is the brown piece new? (#70606)
    That's a backpack scabbard that holds two swords. I don't think it's new though
    madforLEGO
    I just don't recall it ever without the neck piece, always see it like this:
    https://brickset.com/parts/design-88290
  • SumoLegoSumoLego New YorkMember Posts: 13,279
    Minecraft gives us golden apples, Ninjago gives us golden bananas, I think the next logical step is a golden sausage
    Platinum! Platinum!
    Shorter hose piece?
  • CM4SCM4S United StatesMember Posts: 1,363
    Mynatt said:
    Shorter hose piece?
    The one used for TLBM Bane and Freeze in silver ?
    Mynattgmonkey76
    CM4S said:
    Mynatt said:
    Shorter hose piece?
    Ah I see, didn't pick up either of them but yep, never mind about them being new with the ninjago movie. Don't recall them having been mentioned here yet.
  • AanchirAanchir United StatesMember Posts: 2,886
    It was in the TMNT sets.
    CCC
    It's definitely in the Ninjago City set
    !!!!! YES! That'll be useful!
  • PaperballparkPaperballpark UK / KLMember Posts: 3,872
    Ooooh...
    But now we need a 2x2 tile with a single stud in the corner so they can run seamlessly around the corner of a wall.
    BumblepantsCM4SJudgeChuckIceCreamClonecatwrangler
    It's also in Black and LBG in the Ninjago City set.
    The artist's palette is new in green, used as lily pads.
    Is the flower stem new in Dark Brown? It's on the bonsai tree bit.
    CM4S
    sounds like a 2x2 corner tile + a 1x1 plate
    Not if you want an overhang. The corner tile will fall off.
  • datsunrobbiedatsunrobbie West Haven , CTMember Posts: 1,583
    a regular 2x2 plate will work as a corner if attached from below the plate. If only attached from above then a new corner piece will be needed
  • VorpalRyuVorpalRyu AustraliaMember Posts: 2,315
    Surprised that no-one has mentioned about that part that looks like a 1×1 round plate with a side stud in one of the Ninjago Movie sets?
    xiahna
  • Coolguy5000Coolguy5000 Ireland Member Posts: 1,541
    edited June 2017
    @VorpalRyu I think someone did in the ninjago thread. I actually think it has a bar ( not a stud) protruding from it which is why the gold 1 x 1 polo stud can attach.
    Edit: from this angle you can see its a bar entering the gold polo stud.
    VorpalRyu
    Could be one of the tool parts, but it does look like a possible new element.
    VorpalRyu
    In that case, the new tile is also unnecessary though. You could just use a 2x2 plate with a 2x1 tile and a 2x1 plate on top.
  • NeilCrosbyNeilCrosby United KingdomMember Posts: 77
    I didn't have a wrench to hand to try in real life, but in stud.io looks a bit longer than what we can see in the picture above. I'm not sure whether that's just down to the picture or real world tolerances though.
    I have at least 40 of them at home, I'll try to remember to have a go this evening.
    Looking more closely though, I do think it's a new element. It's certainly an odd one.
  • LyichirLyichir United StatesMember Posts: 875
    The part is also visible on the bridge, holding the life rings on. From that picture it seems to have a hole in the center of the bar, though I can't quite tell if it's the right size to fit Friends-style accessories.
    It's a new piece, guys!
    I'm nearly positive there is/was a similar MegaB**** piece for many years.  1x1 round plate with a bar out one side.  I remember sorting that out of used bulk because I knew it was "Flego".
    @DadsAFOL, similar, yet different... M*gaBl*ks piece has the bar in line with the stud, while the TLG version looks to be offset slightly.
    xiahna
  • AstrobricksAstrobricks Minnesota, USMember Posts: 3,487
    Whooooooaaaaahhhhhh!
    edited July 2017
    I'm sure some of us will be pleased ... I just hope for LBG ones
    LostInTranslationgmonkey76stluxVorpalRyucatwranglerBumblepantsmadforLEGOomniumCM4S
    Oh yes, I'm very pleased about it! It's one part which I consistently think 'I wish we had that'. I'd have used at very least a dozen in my Palace of Westminster, and possibly hundreds (I used a lot of 1x2 jumpers).
    CM4SmadforLEGO
    I'm still hoping it has the new style underside, so that you can centrally place a 1x1, a 2x1 and a 3x1 part underneath.
    catwranglerNeilCrosbyVorpalRyuLyichir
    edited July 2017
    Beyond the crazy new transparent pieces in the 2018 DC sets, thought these were some cool new pieces, or at least don't recall seeing them before.
    Besides that, not seeing anything much else that is new in these sets.
    CM4SomniumIceCreamClone
    Why oh why is that part needed. Really? Sigh.
    CM4S
  • Mr_CrossMr_Cross East Anglia (UK)Member Posts: 1,336
    If those are open studs, I could see them being useful... wouldn't have been my first choice of new part though.
  • ShibShib UKMember Posts: 5,349
    Given that it's pictured with the spare stud shooter pieces I'd imagine it's a play feature thing, shoots out of something which would explain the need for the rounded edges
  • AleyditaAleydita BelgiumMember Posts: 877
    Isn't it just a 1x2 Technic plate?
  • Matt89190Matt89190 UKMember Posts: 307
    I suppose it could be useful in the way 6157554 is, in that the round edges mean it can rotate slightly....
    BumblepantsMynatt
    I'm actually curious as to why they're both sat on their own, rather than being part of the model. It suggests they're used for some function, like the 1x1 round plates are in the stud shooters. The only reason I can think of is that it's some kind of minifig stand.
    Not being a superheroes fan, do any of those characters fly? For example, in #76097, the plate could be used on the bottom of Wonderwoman(?)'s feet, to attach those two flame things to when the character flies. Similarly in #76098, the black plate could be used on the strange blue character's feet, to hold the trans-blue flames that are shown on the car.
    Just a wild guess.
    wardmAanchir
    @Paperballpark Had actually not looked at what the part's purpose was within the set and I am as well stumped. I like the idea of them being there for the feet to give a flying feature but at the same time would have figured that 1x1 round plates with holes would have worked. Would also give the additional boost of being able to move the legs. Nevertheless, having it on the feet does seem like the most reasonable option as I have no idea what else they would be there for.
    I originally thought it was just a smooth connection to the transparent backpack piece thing on batman but now realizing that makes no sense now that it wouldn't work with the color scheme or in the 3rd set.
    Also for the third set, I'm curious why there are two white spare 1x1 round hollow studs. As I recall, hollowed out studs don't to well with stud shooters so I wonder why they are there.
  • Penkid11Penkid11 Member Posts: 788
    The round edged 1x2 plate goes on the feet of the characters. The weird energy prices fit in the open studs giving the ilusion of fire (or other energy stuff) shooting from their feet.
    CM4SAanchir
    I think that's what I just posited...
    They'd be brilliant for building round towers. If you stagger them in rows, you'd be able to bend a wall into just about any shape.
    Tkattgmonkey76SirBenvizzitorcatwrangler
  • TkattTkatt MNMember Posts: 429
    ^Exactly what I was thinking. I'll just need a few thousand in shades of grey.
    Mr_Crossgmonkey76SirBenvizzitor
