Looking for a specific part.
PaperballparkPaperballpark Near ManchesterMember Posts: 4,248
edited March 2017 in Building and Techniques
Hi all, I'm wondering if you can help me find a part. It's not a conventional part, in that it won't appear listed on Brickset or Bricklink. What I'm looking for is a sprue. A sprue is a 'waste' part joining two elements together - typically minifig weapons, utensils, or flower heads, such as the middle part of this:
The thing is, I'm sure there's a sprue for a part where the sprue is small and round, and (coincidentally or not) the same size as a stud.
That's the specific sprue that I'm looking for. It's not the flower sprue, and it's not from any weapon or utensil I can think of.
Does anyone know what it's from? Or am I mis-remembering?
  • BumblepantsBumblepants DFW/BGMember Posts: 7,439
    Maybe that weird diamondy circlely one that came between 1x1 round plates in the old days?
    All I can think of is the spruce for flippers which also happens to be the same sprue used for studs in the 80's. I don't know if it connects to anti studs though...
    From memory, coins also came with a round sprue.
  • SprinkleOtterSprinkleOtter Member Posts: 2,764
    Shuriken?
    AllBrick
  • PaperballparkPaperballpark Near ManchesterMember Posts: 4,248
    Shuriken?
    Bless you. Seriously, what?
    SprinkleOtter
    They do, but it's about the same size as the coin, and larger than a stud.
    Nah, it definitely wasn't that, and it'd be too big anyway.
    Shuriken?
    Japanese Throwing Stars? From Ninjago? Also sometimes known as Ninja Stars. Sometimes explosive.
    AllBrick
    bandit778 said:
    I think @SprinkleOtter is referring to these.
    Yep. Someone wrote an article on how they were a happy mistake.
    Lego_Starbandit778
    Hmm that might be what I was misremembering then. What I need is something to attach on the underside. Oh well.
  • Sven_FSven_F CroatiaMember Posts: 17
    Can't you use minifig rollerskates?  They would attach to the underside,  look similar to this sprue and come in gold too.
    The thing was that if it was a sprue of that size, I could have attached plates both on top and underneath it. I can't do that with rollerskates.
  • TyresOFlahertyTyresOFlaherty USAMember Posts: 345
    Those are the best kind of mistakes.
    catwranglerdavetheoxygenmanSprinkleOttergmonkey76Mynatt
    Missed a stroke? Instant bird!
    edited March 2017
    I'm still intruiged by what you're actually trying to achieve and whether it's mechanical or cosmetic?  Is it opposing studs within a two plate thickness and, if so, must it be within a single stud width?
    SprinkleOtter
    Cosmetic, opposing studs within a two-plate thickness, and yes, must be within a single stud width.
    I can put a plate inbetween to do it, but having no plate would look better. Oh well.
     could these parts work for your need?  4276, and 4275.
  • datsunrobbiedatsunrobbie West Haven , CTMember Posts: 1,795
    http://thebrickblogger.com/2014/11/reversing-studs-on-lego-bricks-plates/
    If I understand what you're looking for, these guys have a few ways to pull it off.
    @GallardoLU - the opposed finger hinge option is only a single plate thickness (and I'm pretty sure @Paperballpark only has a 1x1 stud width to play with?)
      SURELY a reheated blob of glue from a glued end box could still be considered pure?
    Switchfoot55
    edited March 2017
    No, I've already got them reversed with a plate inbetween. I'd like them reversed with no plate inbetween. It's not plates I'm reversing, it's cheese slopes.
    Basically, I want them back to back, with no plates inbetween. I thought a small sprue might do it, but I'm now thinking it's probably not possible.
  • AllBrickAllBrick UKMember Posts: 1,490
    edited March 2017
    The part you want is something I requested in the "what parts do you wish TLG would make" thread.
    I suggested that the Technic 1/2 pin 4274 should have a version that is short on both ends.
    Could be quite useful and would probably work with your application, shame it's a dream
  • CCCCCC UKMember Posts: 20,483
    Are they 1x1 cheese slopes or 2x1, and if 2x1 are they aligned (cannot attach to anything else) or offset so as to form a chain like structure.
  • gmonkey76gmonkey76 ChicagoMember Posts: 1,813
    We need a 4081 plate modified with clip light with the clip 90 degrees from what it is now.
  • BobflipBobflip Member Posts: 691
    Or these handy things that that other company make...
  • madforLEGOmadforLEGO Chicagoland USMember Posts: 10,655
    What? Poorly fitting parts with even worse coloring than LEGO? No thanks
    gmonkey76MynattThe_Mad_Vulcan
    So, you want a zero-width studs out snot connection?
    ^ Pretty much, yes. I thought there was a sprue that would do that, but it appears I was mistaken. Oh well, I've moved past that point in the build now anyway.
    I saw a build once where the builder admited to folding a lego sticker back on itself to make, essentially, double-sided adhesive tape.... is that still purist enough for you?
    MAGNINOMINISUMBRA
    I'm liking these purist leaps of faith. If you get hold of some of the actual glue they use to hold the models together at the parks would it still be legit?
    No, because it won't be made by LEGO. There's really no excuse for using competitor bricks though. None at all.
    SprinkleOtter
  • TechnicRCRacerTechnicRCRacer USMember Posts: 2
    @Bobflip on a previous comment, you mentioned the 2 x 2 inverted tiles from another company. I recently got one from a Mighty Micros set that is an official LEGO piece! Here is the set number: 76065
  • FauchFauch FranceMember Posts: 2,633
    but it's not a tile, it has studs on top and bottom
    Fauch is correct, but I didn't know about the inverted tile piece either!
    https://www.bricklink.com/v2/catalog/catalogitem.page?P=11203&idColor=11#T=C&C=11
    it's not new, but I haven't seen a lot of them. I think first time was on samurai mech from 2012
    MrShinyAndNew said: moll
    Damaging parts is normally not purist, so no.
