looks like it was in 3 sets.
Hope that helps.
Toa Inika Matau.
Couple Bionicle buildable figures (2005).
http://brickset.com/parts/design-58088
There looks to be 3 sizes of 18mm, 36mm and 56mm. The link above is for the 56mm version.
^appreciate it @GallardoLU. - I was wondering if that was even Lego. Now I know!
My boys are avid Lego heads (mortified when Chima was discontinued)
Can anyone point me in the right direction identifying stickers that are still on their backing sheets? Twin 1 rushes to complete the set and the stickers get shelved. I know there is a set of numbers on each sheet but I can't work it out.
set number 70143 uses sticker sheet marked with: 11704/6075178
to find the set from the sheet I searched "Sticker 11704"
alternatively you can search by set number, and match the sticker sheet to the set as it will be listed as a part.
lastly if you have a list of set numbers, or sticker sheet numbers I'm sure one of us can run through bricklink for you pretty quick.
Can someone point me towards the item that this clip is designed for please?
Thanks for expanding @datsunrobbie .
I am not familiar with the names and types, so please be kind and help out and identify what you see!
Thanks in advance!
I usually track down Bionicle by browsing by color on Brickset and narrowing it down by looking at the Constraction parts. For instance, There's a lime green part in the upper right of picture#2. I started with "Bright Yellowish Green", then started looking at just Constraction parts and spotted it on the Body Shells Page. #7165 is the only set listed with that part. The head from #8910 is in the last picture.
That was an easy one to track down. Just like the System sets, lots of parts get used in multiple sets, then there are oddball parts that only come in a few sets. Look for the oddball parts first, then pull all the parts to build that set out of the pile, then repeat. And don't hesitate to post pics of both the assembled sets and any more parts left unidentified.
i actually found three Hero Factory torsos so they'll help me with this search.
#7165 Natalie Breez
#7167 William Furno
#8535 Lewa
#8901 Hakann
#8913 Toa Nuparu
#8975 Berix
#8981 Tarix
Thank you for your assistance!
Appears in two sets
#1389 Onepu
#1390 Maku
#1391 Jala
#7116 Tahu
#7117 Gresh
#8534 Tahu
#8977 Zesk
The yellow part is 6178 - Tile Modified 6x12 with studs on edges. Appears in yellow in 4 sets (3826, 5846, 7685 and 4404).
Maybe others can assist on the white and grey parts, but I suspect they are not Lego brand.
Any thoughts?
Picture isn't the best, but it's what I was given. Based on the purple, I'm pretty sure I see most/all of $41553 Vaka-Waka Mixel. What about all those tan pieces strewn about? Some of the green look like another Mixel too.
There are obviously some non-Lego in the mix with the minion-esque figs in the top center. I'm hoping that means not a lot of other off-brand.
The guy I'm buying from buys storage lockers and sells the contents. I'm his exclusive Lego buyer, so even if the lot isn't great, I feel like I have to buy to keep the relationship in a good place. He only wants $2, which I figure the Mixel alone is worth. Plus I'm looking for a lot of tan currently.
Looks like a Mega Bloks Dino Ride with a few LEGO parts thrown in
https://shop.megabrands.com/en-us/shop/construction-toys/despicable-me-
minions/dino-ride-cpc51
I guess the idea of being a purist is understandable to me (I'm a purist in other things I collect). But due to the fact that 95% of my Lego purchases are for my son, I have to be realistic and just know that he doesn't care if they are Lego, MB, or some other non-pirated generic brand. ...though, would he really care if there were some Lepin bricks?
I see bits of quite a few Mixels in there. It looks like they were buying Mixels mostly from series 6.
41546: Forx - I see the upper jaw, a leg, and an eyebrow.
41545: Kramm - I see the drill arm and both legs.
41548: Dribbal - Main build of head.
41550: Slusho - Bottom of head and a wing.
41553: Vaka-waka - lots of the parts, as mentioned.
41552: Berp - two arms.
Pretty small bits
Anyone look familiar? Minus the SpongeBob figs of course.
What stinking winter set is this from!? It's driving me nuts.
I have other pics, but will stop out of fear of breaking the page.
It's set #10229-1 Winter Village Cottage, this is the side of the wood shed.
The Police ATV is from set #4437. Still 2012.
I see a few CMFs from 2012: the Bandit #8827, the Flamenco Dancer #8827 x 2, the Jungle Boy #8831 x 2.
Then going back a year to the 2011 CMFs: Space Alien #8803
The figs are a whole mish-mash of parts but there is also the dino-tracker cmf http://brickset.com/sets/71007-10/Dino-Tracker a ninjago snake dude and a couple of SW snowtroopers.
