1535456585994
  • Jackad7Jackad7 Wisconsin Member Posts: 532
    Jssoncole said:
    Can someone help identify this set please
    I think that is from an educational mindstorm challenge kit. I have seen a lot on eBay that had some of the parts in your set and it was part of challenge where they had to create a vehicle to drive over obstacles. The lot i saw had the obstacles which looked more like a bridge and had a width about the perfect size to fit your vehicle. I looked for two hours and couldn't find the set anywhere.
  • BlueflashBlueflash UKMember Posts: 1
    Ok so have joined this forum after seeing the Lego 4D Movie and Wildstyles Rollercoaster.
    Wondering are those parts real lego parts or just created for movie? I would have thought they would only use valid lego pieces.
    In the movie the rollercoaster looks like a Kynex type coaster, or is the best we got so far the Friends Amusement park.
    Thanks for excepting me to the site
    1x1 cones with rigid hose?
  • SprinkleOtterSprinkleOtter Member Posts: 2,743
    ^^ Brickworld, ye say???
  • BrikingBriking Dorset, UKMember Posts: 759
    I'm trying to identify this "plant" piece.  It's in "The LEGO Neighbourhood book", in the Canal Ring House instructions (step 12 on page 199).  I can't find it on Bricklink.  Any thoughts?
  • catwranglercatwrangler Northern IrelandMember Posts: 1,854
    edited February 2017
    @Briking I would look for it under headgear accessories; I don't think it's a plant originally, but one of those things that fits into the clip on some of the hairpieces or headgear on the Islander characters...
    EDIT: Yep, here it is: http://rebrickable.com/parts/87696/
    BumblepantsMooreFXstluxAllBrickgmonkey76
    @catwrangler you're a star!  Thank you so much!
  • pasat14pasat14 AustraliaMember Posts: 44
    So I have been searching bricklink for ages trying to find which set (or sets) this came out of....with zero luck...very frustrated....any help would be super greatly appreciated!! Thank you!!
  • davetheoxygenmandavetheoxygenman Colorado, USAMember Posts: 202
    @pasat14 - looks to be this one:  http://www.bricklink.com/catalogItemIn.asp?P=3068bp66&in=S
    looks like it was in 3 sets.
    Hope that helps.
    stluxAllBrick
    Super helpful! Thanks heaps!
    davetheoxygenman
  • CaptainRogersCaptainRogers Greensboro, NCMember Posts: 806
    Picked up a used lot... Time to ask for help!
    Oh, and there's this big thing...
    Toa Ignika.
    Visorak (red one).
    Toa Inika Matau.
    Couple Bionicle buildable figures (2005).
    X-Wing (2005), Professor Quirrel (torso, head, and turbin), Mcdonalds Racers, Chamber of Secrets, ball socket probably from Dume and Nivawk, hubcap from Speed Champions, Sandtrooper Pauldrons, Gringots safe, Bohrok Krana holder, 2006 minifigure scale Bionicle Hahli/Vezok torso and legs.
    Thanks man! Helps a lot. I never got into Harry Potter or the original run of Bionicle as a kid. As for the hubcap, I don't think it is Speed Champions... It is way too big, plus I have all the SC sets and it doesn't show up there. Of course, it might not even be lego - I got quite a mixed bag of stuff.
    SprinkleOtter
  • oldtodd33oldtodd33 Denver 4800 miles to BillundMember Posts: 2,525
    The yellow sticker-ed parts are from http://www.bricklink.com/v2/catalog/catalogitem.page?S=8143-1#T=I along with the hub cap.
    @CaptainRogers - could it be this one?
    http://brickset.com/parts/design-58088
    There looks to be 3 sizes of  18mm, 36mm and 56mm.  The link above is for the 56mm version.
    Sorry, I meant Speed Racers (awful theme...)
    ^Thanks all! The Lego Ferrari set - that's what the mystery pieces are from.
    davetheoxygenman
    little blue piece is part of a minifig car jack (didn't see that identified yet)
    ^appreciate it @GallardoLU. - I was wondering if that was even Lego. Now I know!
  • twin_boys_mumtwin_boys_mum Member Posts: 2
    1st post so please shift this if I've done this wrong.
    My boys are avid Lego heads (mortified when Chima was discontinued)
    Can anyone point me in the right direction identifying stickers that are still on their backing sheets?  Twin 1 rushes to complete the set and the stickers get shelved.  I know there is a set of numbers on each sheet but I can't work it out.
    @twin_boys_mum  Go to Bricklink, on the sticker sheet at the bottom is a printed number. Enter the number into the search area and you'll find what you're looking for.
    if you head over to bricklink you can search for the numbers on the sticker sheets (long one like the below example)
    set number 70143 uses sticker sheet marked with: 11704/6075178
    to find the set from the sheet I searched "Sticker 11704"
    alternatively you can search by set number, and match the sticker sheet to the set as it will be listed as a part.
    lastly if you have a list of set numbers, or sticker sheet numbers I'm sure one of us can run through bricklink for you pretty quick.
    twin_boys_mum
    Fab.  It looked like the numbers were too long to relate to sets.  I think I understand now.  Cheers.
  • AllBrickAllBrick UKMember Posts: 1,424
    Found a boat hull from #7207 . There is a clip on the bottom, I'm guessing it's for a ballast weight.
    Can someone point me towards the item that this clip is designed for please?
    ^ A boat motor.
    AllBrick
  • datsunrobbiedatsunrobbie West Haven , CTMember Posts: 1,574
    I've got that #7207 hull around here somewhere, never built it because mine is missing the grey insert. The instructions don't show any parts connecting to the bottom of the hull, but you could probably use the motor from #7906 with the #7207 hull.
    AllBrick
    Just acquired a Bionicle lot.
    I am not familiar with the names and types, so please be kind and help out and identify what you see!
    Thanks in advance!
    That's quite a jumble of parts :)
    I usually track down Bionicle by browsing by color on Brickset and narrowing it down by looking at the Constraction parts. For instance, There's a lime green part in the upper right of picture#2. I started with "Bright Yellowish Green", then started looking at just Constraction parts and spotted it on the Body Shells Page. #7165 is the only set listed with that part. The head from #8910 is in the last picture.
    That was an easy one to track down. Just like the System sets, lots of parts get used in multiple sets, then there are oddball parts that only come in a few sets. Look for the oddball parts first, then pull all the parts to build that set out of the pile, then repeat. And don't hesitate to post pics of both the assembled sets and any more parts left unidentified.
    77ncaachampskiki180703
    Thanks, @datsunrobbie.
    i actually found three Hero Factory torsos so they'll help me with this search.
  • BobflipBobflip Member Posts: 545
    I can see an 8901 in there, but a lot of the part/colour combinations only end up in a handful of sets. Blades, masks and arm/leg pieces are good to start with.
    Also check out #8913 and #8943. There's a fairly large silver part, #4504965, in one pic that seems to only be in those two sets.
  • AstrobricksAstrobricks Minnesota, USMember Posts: 3,311
    Visorak (red one).
    Toa Inika Matau.
    Thanks for leading me to the identity of that little yellow axle with the hex end. I have one lone one and was almost sure it wasn't Lego.
    Was able to find some key pieces (swords or weapons) and these were the sets that I was able to identify (though they may be incomplete):
    #7165 Natalie Breez
    #7167 William Furno
    #8535 Lewa
    #8901 Hakann
    #8913 Toa Nuparu
    #8975 Berix
    #8981 Tarix
    Thank you for your assistance!
  • MarksimonsMarksimons UK Member Posts: 0
    Hello I have just been given a job lot but unsure about the mini figure any ideas?
    http://brickset.com/sets/containing-minifig-sw452
    Appears in two sets
    Found out more of the Bionicles/Hero Factory figures:
    #1389 Onepu
    #1390 Maku
    #1391 Jala
    #7116 Tahu
    #7117 Gresh
    #8534 Tahu
    #8977 Zesk
  • gt7319cgt7319c Atlanta, GAMember Posts: 26
    Hello, I'm considering purchasing a tub of Legos being sold online, but I'm curious what sets might be included in it.  There are three plates in the attached picture that should be easy to identify because of missing studs, but I can't find them via a search of BrickLink.  The three plates are the (1) the white one towards the left that is partially concelled by a multi-colored house construction, (2) the half-concealed yellow 6x? plate in the middle that looks like it may have studs only around the edge of one corner, and (3) the large gray plate to the right that is missing almost half of its studs on one side.  Thanks in advance.
    Superheroes for your little crime fighter
  • sdetskysdetsky Member Posts: 35
    The yellow part is 6178 - Tile Modified 6x12 with studs on edges.  Appears in yellow in 4 sets (3826, 5846, 7685 and 4404).
    Maybe others can assist on the white and grey parts, but I suspect they are not Lego brand.
    The yellow tile looks like it's this one.  http://www.bricklink.com/catalogItemIn.asp?P=6178&in=S
  • Switchfoot55Switchfoot55 The Northwest, USAMember Posts: 1,973
    That large dark gray baseplate has me a bit confused. I count that it's 36 x 26 studs? That seems potentially like Mega Bloks dimensions? However, I'm not a longstanding expert like so many here, so I could be completely wrong.
    I know we have some identifying already in the works with the above photo, but I'll throw some more in.
    Any thoughts?
    Picture isn't the best, but it's what I was given. Based on the purple, I'm pretty sure I see most/all of $41553 Vaka-Waka Mixel. What about all those tan pieces strewn about? Some of the green look like another Mixel too.
    There are obviously some non-Lego in the mix with the minion-esque figs in the top center. I'm hoping that means not a lot of other off-brand.
    The guy I'm buying from buys storage lockers and sells the contents. I'm his exclusive Lego buyer, so even if the lot isn't great, I feel like I have to buy to keep the relationship in a good place. He only wants $2, which I figure the Mixel alone is worth. Plus I'm looking for a lot of tan currently.
    The doubts of Lego origins expressed by sdetsky and Switchfoot55 prodded me to do a Google image search for large gray Mega Bloks bases, and I believe I've confirmed the Mega Bloks origins of the plate in my picture.  See here:  https://shop.megabrands.com/en-us/shop/construction-toys/blok-squad/build-plate
    Any thoughts?
    Looks like a Mega Bloks Dino Ride with a few LEGO parts thrown in
    https://shop.megabrands.com/en-us/shop/construction-toys/despicable-me-
    minions/dino-ride-cpc51
    ^The most I looked and searched BL, the more I feared it was Mega Bloks. For $2, I'll probably still pull the trigger for the 1 or 2 mixels that are likely there.
    ^If I saw it at the local thrift store for $2, I'd certainly buy it - I already have several of the related Minions sets, and I'm happy with them.
    The build itself looks fun. I know my son would LOVE to add a dinosaur to his city, be it Lego or Mega Blok.
    I guess the idea of being a purist is understandable to me (I'm a purist in other things I collect). But due to the fact that 95% of my Lego purchases are for my son, I have to be realistic and just know that he doesn't care if they are Lego, MB, or some other non-pirated generic brand. ...though, would he really care if there were some Lepin bricks?
