Lego Digital Designer Part Wrong [6151349: Design Shape W/ Tube, Crosshole]
So, there's a cool new curved tube part that's in a few sets and also in LDD. You're supposed to be able to make things like this:
http://imgur.com/a/MOfAH
According to this article on Brickset, you should be able to use standard 2M cross axles to connect them:
http://brickset.com/article/24162/the-new-macaroni-tube
Looks great. However, in LDD, this doesn't work. The axle won't insert fully and you end up with a gap between the parts:
http://imgur.com/a/yCnjz
This is a major bummer. Any ideas on how this could be resolved or worked around? Thanks!
  • BumblepantsBumblepants DFW/BGMember Posts: 7,340
    I suspect that it is the old design for that part in ldd from the '90s. The recent version is much improved for connection but I don't think they added it yet.
  • ziebeljeziebelje USAMember Posts: 3
    It's definitely in there and the part I'm using is the new one.
    http://imgur.com/a/ODxQO
    http://brickset.com/parts/design-25214
    edited January 2017
    Well, I just figured out how to force the tubes to be next to each other. This will be a bit cumbersome but I believe it should work. They're not technically connected but oh well.
    If you connect one of them to a shaft you can move it along the shaft to butt it right up where you want it.
    http://imgur.com/a/33C9F
