avro brothers alien project
I seen one of these on display at steam at the start of October, build by @legoboy sadly I couldn't speak with him. So my question to the forum is this model able to be possed etc.. and does it need to be on the stand.
Cheers
  • ScatterbugScatterbug WalesMember Posts: 109
    Yes, it can be posed to a degree. See my build photos here:
    http://bricksetforum.com/discussion/comment/408537#Comment_408537
    It comes with a base (the design of which draws inspiration from the interior of the Nostromo) but because the figure is top-heavy and is only secured by two technic pins in the feet it has to be balanced carefully.
    palmers9grbstluxkiki180703
  • CCCCCC UKMember Posts: 18,141
    It doesn't have to be on the "official" stand. I did away with it due to expense, and used a couple of pins inserted into a nice wooden board. It gives a nice display stand and stability.
  • DeMontesDeMontes North YorkshireMember Posts: 582
    the model can be posed although some poses are more stable than others.  The bottom of the feet have a pin that inserts into the stand.  Any stand.  You can build the Arvo Bros stand or design and build your own but I would say that it does need a stand to maintain stability.  @Legoboy has built his particularly unstable, he denies this but I have seen it sway! ;-)
    bandit778iso3200palmers9grb
