http://www.eurobricks.com/forum/index.php?/forums/topic/41226-key-topic-official-lego-sets-made-in-ldd/&do=findComment&comment=2681611
http://www.eurobricks.com/forum/index.php?/forums/topic/41226-key-topic-official-lego-sets-made-in-ldd/&do=findComment&comment=2680708
I would suggest that you pick a favourite set or two, grab the instructions and replicate them in LDD.
But I can't find a manual to...hey you know what? I'm being a bitch...I want a lot of this too fast. That's my problem if I really sit here and do some introspection. I'm older, and I'm good at some things in life. So I want to be good at something else and am not used to learning. I gotta suck it up and get used to it. Thanks for the info Judge!
When i first started playing about on LDD, I suffered a lot of the same problems.
It is really a patience thing. The one tip i can offer that i found helped a lot when placing bricks in an existing build is make full use of the movement you have on screen to view the build.
Parts that wouldn't connect from one point of view, most of the time would connect if the build was tilted or spun round to another point of view.
You are right though, that there are some oddities with regard to how the bricks behave and how to learn to rotate them or get them to attach to other bricks in some circumstances, but I'm not sure a lot of that is easily taught.
It really didn't take me very long to pick up the fundamentals though.
One thing I would recommend is to get used to manipulating groups and templates, as these can speed up your building no-end.
Also, learn to work by creating bricks, colouring them and then simply copy'n'pasting as much as you can. I suppose this is obvious, but you'll save a lot of time, if you do this, rather than creating bricks from scratch each time.
@blogzilly Honestly, just dive in. You'll soon be wondering what your frustrations were. Well, almost! ;-):-)
multiple selection and copying are very useful. you can just copy bricks you already placed without having to search for them and pick a color.
flexible parts and chains, I have no idea how to use them. I think some people manage to flex them successfully but it just doesn't work for me.
technic builds seem like a pita.
Recently on New Elementary there was a fantastic exploration of new elements. If there was a site, series of books, something that showcased parts like that, parts both old and new, I would scoop that up like a banana float.
In addition to the Brickset parts pages it would also help to get to know the in's and out's of Rebrickable if you are building older sets.
Due to the nature of where Brickset gets set part listings from, sometimes parts are missing from the database if they are no longer in production.
Rebrickable should give the whole inventory of a set and will offer up newer alternatives if they are available.
It's also really handy for keeping your own inventory of loose parts for when you start buying parts and building. Also has the added bonus of being able to sync with Brickset if you want to split sets to build.
