Please use our links:
LEGO.com •
Amazon
Hover Scout Instructions - Free Download
At the end of 2014 I put a MOC up on Lego ideas. Some of you may recognise it as
@Huw kindly did a review of it shortly after :-)
It further developed two revisions, but it has now run it's course and expired last week, so for those who supported it or for anyone else vaguely interested I thought I'd share the instructions. There is also a Brickstore file - though there may be the odd brick missing from it as I had a terrible time getting files to export correctly.
If you'd like it, you can grab the Mk3 revision files from:-
https://www.dropbox.com/sh/cdq2flrknxsw427/AACB8dpRTlxyF4txftWcIiM5a?dl=0
26
Recent discussions •
Categories •
Privacy Policy •
Brickset.com
Quick Links
But again, thanks for this and I'll have to start getting pieces together when I come back from holiday;
I'm a graphic designer/photographer by trade, so I use Quark Xpress for my page layout. The compilation of the instruction steps, the PovRay renders, the photographs and typesetting are all done within that to produce the final PDF booklet.
It took me ages! But at the time I needed something to occupy my mind so was well worth it.
http://mecabricks.com/en/models/X1k2qx4baE0
Only obvious thing I can see is all the Green elements (except for the minifigs) should be Dark Green instead of Green. Other than that, pretty good with the substitutions :-) Could you recolour the greens at some stage?
If anyone does decide to build, feel free to leave any feedback here. Likewise, if you find any errors in the Brickstore file, please fire me a PM and I'll try and fix so people aren't hunting for bits that don't exist, or find they're a few parts short of a model.
Couldn't see where these went?
Slope 30 1 x 1 x 2/3 Dark purple
Needed to be a third grey base/black lever
Lever Small Base with Yellow Lever
I used these on the base of the two probes on the red studs as there were not enough grey ones
Plate, Round 1 x 1 Straight Side Dark purple
The piece of pipe between the data station and recharge dock doesn't appear in the kit list.
However, its looks amazing, really fits in well with the Exo-Suit and with a little realigning of the station and dock by 4 studs, fits on the gap on my shelf just perfectly.
Thanks so mush @iso3200 for making the instructions available.
There's no purple in the set at all. Looks like something has not ported across correctly - the purple elements should be metallic silver - but they look fine as those feet I think anyway.
I did have a tough time with brickstore, and for some reason I can't seem to update the Bricklink catalogue or see any images. I'm not sure if this is due to Brickinks revamp or some other reason.
Anyway, I will try and address the issue in the next day or so and correct. The piece of pipe I can't add to the brickstore file. I might have to redo as a Bricklink XML file.
The pipe is part 14301
As you're the first builder, PM me your address and I'll send you one of my spares.
