I analyzed 67 years of LEGO data
  • bobabricksbobabricks Member Posts: 1,842
    Very interesting. Looks like the first set to break 1,000 pieces was a teacher resource set, ha ha.
    Very cool!
  • chuckpchuckp Member Posts: 684
    Nice work! The color palette by theme was very interesting. Gray is really taking over, even the Friends line wasn't spared.
  • LusiferSamLusiferSam Member Posts: 571
    I believe it is correct that first to break 1,000 pieces was an educational set, but the not the one shown here.  7100 is more twice as large as 1034 and predates it by 20+ years.
    Very interesting overall.  The graying trend is interesting.  The minor color increase is pretty self evident, but is fun to have a visual of.  I like the color palette by theme.  Maybe the top five colors should be shown as three seems like it might be too few.  The node network is the most interesting to me.  There must be something about the methodology I don't understand because the results look slightly odd.
    I'm going to be critical of the use of Rebrickable as the set database.  They are one the worst databases when it comes to pre-1972 sets.  They basically have no Samsonite sets, which would have a major impact on what you see in the 60's.  Set inventories from this period are notoriously incorrect or incomplete, as such I'm not sure they really be relied on.  I'm not even going to get into regional and year differences of the 50's sets.  And one finally nitpicking thought, 2016-1950=66, not 67.  Where are the 1949 sets?
    2016 - 2015 = 1, but includes 2 years' worth of data (2015, 2016), then extrapolate.
    If you are including the endpoints, then the number of items in a range is (end - start + 1).
    KingAlanI
    That's what I get for writing too quick, very red faced.  Yes, you're quite correct.  But the point still reminds:  Where are the 1949 sets?
  • KingAlanIKingAlanI Member Posts: 2,335
    It's called a fencepost error, because a fence with X sections needs X+1 fenceposts.
    the article is both pretty and insightful.
    ricecake
  • IstokgIstokg Member Posts: 2,362
    I have to second what @LusiferSam said.... the input data to this very interesting research for sets prior to 1972 is incomplete.  From 1954-72 the majority of sets had parts in white and red... pretty equally divided.  No idea why there was a spike for 1960... maybe because only a few sets were introduced that year.  1964 never had blue as the predominant color... that was still mainly a red/white year.  Also black was not introduced as a set color until 1961 (only available as very rare PAB colors from 1950-56).   Ditto for Gray.... which was introduced as plates in 1962 and bricks in 1974 (only 1 set... 1650).
    @Istokg I think the 1960 spike is pretty easy to explain.  It has to do with both the small number of sets released and the fact that there is a single very large set in the data (700K).
