What is the largest single Lego piece ever?
happyskunkyhappyskunky Michigan Member Posts: 133
So the biggest piece I have is the boat  from set 60085. I got this last night and was amazed. Now it has me curious :-D
  • thedoctor46thedoctor46 UKMember Posts: 213
    The scoop from the remote controlled Technic Volvo?
  • CM4SCM4S United StatesMember Posts: 1,368
    48x48 baseplate?
    Legopassion8
  • AllBrickAllBrick UKMember Posts: 1,490
    I think the OP may mean largest building element? Not sure though.
    Biggest piece OS maybe?
    CM4S said:
    48x48 baseplate?
    As there was a 50 x 50, no.
    Depending on what is meant by "large", the sports stadium base must be up the there (47 x 72), but there's a boat hull that's a bit longer.
  • AdeelZubairAdeelZubair London, UKMember Posts: 2,701
    4638602 - Wing 54X20X2/3
    http://brickset.com/parts/4638602
    #60062 among others are larger hulled boats in one larger piece.
  • Lego_Lord_MayorcaLego_Lord_Mayorca H-Town, USAMember Posts: 614
    For sheer volume, the main body of the TDN Module (or whatever it was called) from the Galidor line has to be the largest. And while I don't own it (the horror!), I'm fairly certain it is one huge piece, aside from the landing legs and winglets.
  • ShibShib UKMember Posts: 5,452
    edited July 2016
    If you're counting Galidor then you have to count all the primo type stuff which had random push along stuff that is much bigger.actual system stuff will definitely depend on definition of large - volume, surface area etc
  • BumblepantsBumblepants DFW/BGMember Posts: 7,427
    Once got a huge Bionicle mask thing in a bulk lot. I think it was this:
    Not the biggest probably but still surprisingly large. Scala and Belleville have a bunch of weird giant parts too.
  • IstokgIstokg MichiganMember Posts: 2,351
    The largest single (non-flexible) LEGO item I can think of is this 1956-62 Masonite 1950s style LEGO Town Plan board that goes by the numbers 200M or sometimes 200A.  It measures 21 inches by  31 1/2 inches (53 1/2 cm X 80 cm), and was only sold in continental Europe.
    oldtodd33Dedgeckocatwrangler
  • KingAlanIKingAlanI Rochester, NYMember Posts: 2,313
    A stud is 0.3125 (5/16) inches, so that's 67.2 by 100.8 in studs
    The boat hull in #7994 is larger than the one in #60062 and #4645
