MOC millennium falcon
landolando Member Posts: 106
Thinking of moc a millennium falcon but the 10179 would be to big and most of all very expensive so I'm looking at something Inbetween set 75105 falcon and 10179 falcon. Has anybody done this ? Am I able to buy a few sets of the 75105 and use the parts or how would you go about it. I guess I'm looking for the look of 10179 but big bigger than 75105
  • GIR3691GIR3691 Member Posts: 659
    To do a double-sized 75105, you'd need at least four copies of the stock set. I would figure out what diameter you want for the main saucer, and then work around that. Look at both the instructions for 75105 and 10179 to see if there are build techniques you want to utilize. Maybe you want to use elements of the 10179 frame but the outer shell of 75105 with additional sections.
  • landolando Member Posts: 106
    I have seen one on eurobricks what somebody has done looks awesome and exactly what I'm after I'm not to good at moc this would be my first
    It's not a moc if you're copying someone...
  • Legopassion8Legopassion8 North CarolinaMember Posts: 1,180
    ^are you mocking him?
    canon03Jackad7
    ^ Of course not!
    I'm mocing him :P
    bobabricksBumblepants
  • flordflord CanadaMember Posts: 683
    Only if you came up with joke yourself and didn't get it from someone else.
  • RecceRecce Tiny Little Red DotMember Posts: 898
    Here's mine, using 7965 as base model, about 60cm in length.
    richlbobabricksGoldchains
    2 identical sets would be enough to upsize I guess, though for mine I use 7965 with extra grey plates and other bricks.
