Please use our links:
LEGO.com • Amazon
Building without instructions
I recently started building dimensions sets that I order on amazon without instructions. I usually open the sets with the rest of the mail and built the minifigs. By about the third or forth set, I began attempting to build the vehicles/accessories using nothing but the pictures. I start by dumping all of the pieces onto the table but then set one of each 1x1 aside since those are most certainly extras. When I eventually play the game, I compare my build to the official build. In a few cases I did everything exactly correct. Most of the time there are a few mistakes but they are always in portions not visible in the picture.
I recall doing this at least one before one a starwars polybag or planet set. I generally buy/build larger sets but this type of building might prompt me to buy more polybags and small sets.
Does anyone else do this? If so, what is the largest set you have attempted? What is the largest set you have successfully build without instructions?
0
Recent discussions •
Categories •
Privacy Policy •
Brickset.com
I love doing it with dimensions, but it is frustrating when there are parts you just cannot see!
Architecture sets are nice ones due to the repetition meaning you can work out what is going on at the back (although the insides are still a challenge), I can't imagine doing it with a 250 piece 'traditional' set.
Next up, in a sealed polybag without instructions using only the picture on the polybag!
Several years ago when I built the UCS Falcon, a non-AFOL coworker asked if I used the instructions to built it. I'm pretty sure he wasn't joking =o
Thanks @ricecake for sharing my work!
The largest set I completed in this way with only a couple superficial mistakes was #21024 / Louvre which has 694 pieces.
I made a few more mistakes on #21020 / Trevi Fountain, and #21018 / UN Headquarters.
While I could get the exterior about right, I was stumped by the interior structure of both #21021 / Marina Bay Sands and #21023 / Flatiron.
(I'm almost done building #21028 / New York City, but I'm not sure if I built the interior of One WTC correctly per the instructions.)
