I was starting from the premise that it's a known colour of the brick. I know it doesn't have to be, but it's a reasonable place to start. I run with two monitors, with different colour settings - one says yes, the other not, so Bright Purple is possible.
It's why I questioned the pedigree of the reference bracelet parts. Guessing again, but it seems likely that they've been identified through Bricklink, and therefore it's quite possible they're wrong. Once the reference colours go out of the window, anything's possible - that Bright Red doesn't look very red to me.
Sorry to take so long... had internet connection issues.....
Here is a 322 Samsonite Educational Gear Set, and although I don't have a better image, you can just make out the string in the lower right of the image.
So yes, that is original to this set. Now whether or not that was the same one used in the European Pull Toy, I doubt it. Most non-specialized LEGO parts were produced at their Samsonite Loveland Colorado plant. I don't think this intertwined string would qualify as a specialty LEGO part. Samsonite did make other toys (non LEGO)... so they could have used this same type of string in one of those as well... such as seen in this 1972 Samsonite Catalog image....
So, all the colors I mentioned, and the colors of the reference flowers, are from Bricklink. The flowers were purchased from other sellers, so if I listed an incorrect color for one, then it is a mistake in what I was sent vs. what I thought I ordered. :-)
I must agree that it looks like that Bright Reddish Lilac color shown in that linked pic (color 198). Alas, Bricklink doesn't have a color by that name in their system, so it is difficult to list these bricks correctly. Argh... :-(
People "guess" at a colour; perhaps it's an educated guess based on some hard evidence; perhaps not. Then they forget that they've guessed, and use it as definitive. to make an badly-educated guess for something else. And so it goes on.
Once upon a time, things were relatively simple - there were few colours and the fact that TLG used one set of names and the AFOL community used another was largely irrelevant. Then we got similar colours where the real thing cannot be determined by comparison with a set of picture - and essentially different people thought the same description applied to different real colours. These were then used in the inventories on Peeron and Bricklink - and not necessarily in the same way!
In an ideal world, the colours for reference pieces come from a known, and relatively recent, set. We KNOW what colours are used for them, because TLG now make the information available. There can be significant variations for something that has the same description, but they are (hopefully?) known
Be very careful comparing a real object with a photograph. The latter can vary tremendously giving totally the wrong impression. You've taken your photographs under various lighting conditions, but it also depends on the colour settings on the device on which your viewing it - different colour temperatures, brightness, contrast, phase of the moon (maybe not)...
As I understand it, you have now decided you have a brick in a colour that was never sold. Whilst such things do exist, considering the type of colour involved, I'd personally want to do a lot more checking, brick against brick, to verify that.
Bricklink's name for Bright Reddish Lilac is "Light Purple". 2x4 bricks did come in this color in these two sets, and here's the Bricklink price guide for that color. So I'm pretty confident that's what you have. :)
The photostream I linked to, Brick Colorstream, is one of the best LEGO color resources I know of. They list both BrickLink names and official LEGO color names with handy pictorial reference. Keep them bookmarked!
As I said, that seam suggests that it's not a LEGO part. TLG don't do things like that - it's one of the reasons it's expensive.
You didn't give us any idea of scale. Have you tried putting anything in the hole? Like a Technic pin - when it's worth remembering that they'll always "click" home, otherwise they pin's left stressed and that makes it illegal.
However, as you say, if you keep it, you can throw it away later; it doesn't work the other way around!
Thanks for the reply and the photo. I don't believe the part is the same one used in the pull toy either, I just noticed the string looked similar. I am glad to see that this was a LEGO / Samsonite part, I almost discounted it as a homemade piece.
You do not happen to have a part count for this set?
Thanks Again
Joey
Na, doesn't fit lego at all and to be honest....its in the bin now! Thanks again.
Thanks so much...
Does anyone know if these Shell bricks are from the same set, or different ones?
If you look at the undersides, you'll see that one has two supports (on pillars 2 and 4, flush with the bottom edge) and one has a central support (which stops short of the bottom edge.)
Looking at the pieces I have left over, it's impossible to tell where they're from - I got a load of Lego from my big cousin in the very early 80s, but it seems to be a lot of incomplete sets.
Any help with id or set
The two yellow heads are old castle heads. http://alpha.bricklink.com/pages/clone/catalogitem.page?P=3626bpx120&idColor=3#T=S&C=3&O={"color":3}
http://alpha.bricklink.com/pages/clone/catalogitem.page?P=3626bpx122&idColor=3#T=S&C=3&O={"color":3}
Is that post-it an existing part? I can't find it on casual looking so I thought I would throw it out to you knowledgable lot.
Edit for clarification: not from a set photo, this is an image from lego club email.
Some background info:
I purchased this piece from a wonderful Lego shop called AA Place in Hong Kong. In addition to a great selection of new and retired sets they have a wall of individual elements available for purchase and that's where I found this one. The store is very reputable and I do not believe they would knowingly sell any knock off elements. It has "Lego" moulded at the bottom of the slope on the top of the brick. I could not find an element ID anywhere but the bottom has what looks like "2-03" moulded next to one of the tubes.
Thanks in advance to anyone who can help!
This one? If not, a picture from a different angle might be helpful, too.
it looked like a Halo Mega Bloks piece but I couldn't find one that matched.
