Minifig linked to set twice
CsaboCsabo Member Posts: 7
edited December 2011 in The Database
Hey Huw,
The minifig "pop006 Setam - Claw Hassansin" is linked to the set "7569-1: Desert Attack" twice by mistake. Should be trivial to correct. It would be great if you could correct this whenever you get a chance. I'm assuming that once it's done, the total minifig count for people who marked "I own X of this set" will automatically decrease.
Best regards,
Csabo
  • HuwHuw Brickset Towers, Hampshire, UKAdministrator Posts: 6,914
    Thanks, now sorted.
  • plasmodiumplasmodium UKMember Posts: 1,942
    On a similar note, the old Clone Turbo Tank from 2003 says it has both Mace Windu with a light up lightsaber and a standard Mace Windu. Is this because they re-released it with the non-light-up version after they realised it was a flop, or because it really did come with 2?
    We should probably have two versions of the set in the database, one with light up and one without.
    I'll sort it later...
