75827 - Ghostbusters HQ (Coming In January 2016?)
1235717
  • CCCCCC UKMember Posts: 19,917
    And on the French site it had GB in the name too.
    ^ A webpage, that could have been a product idea that was cancelled. For all we know, someone accidentally clicked the wrong box & instead of deleting the page, made it active. With the current addition to the rumour of a Stay-Puft brick-built figure, I'm filing this in the circular file until I see something official from TLG, because it's sounding more & more, like someone's dream set & less like an actual TLG planned set...
    xiahna
    Yes, although it is still a rumour with some factual backing as opposed to "I heard it from someone who overheard it from a store assistant."
    VorpalRyuSumoLegokiki180703
  • BobflipBobflip Member Posts: 636
    CCC said:
    Bobflip said:
    It *would* be odd if it didn't come with the main 4 Ghostbusters minifigs, though I'd guess they would have to be exclusives, as per the Simpsons House vs the CMFs.
    Arm printing (and the new hair) would be a way of making them different to the Ecto-1 minifigs.
    I thought arm printing actually! Would be nice, seeing as NACM have sold out.
    Would LEGO assign a set number and make a database entry on their shop site for something that was still an idea? My guess is no.
    Also, keep in mind we just saw official photos of several sets (e.g. Creator) that were initially discovered using the same method.
    The info on LEGO's website was nothing but the set number and name. If someone has since rumored it will include Mr. Stay-Puft, I don't see how that affects the validity of the original rumor.
    Paperballparkkiki180703
  • CM4SCM4S United StatesMember Posts: 1,366
    ^ you mean the rumour that was corroborated by Lego.com having a URL link that stated '75827 Firehouse Headquarters'? A URL that has since been removed, unsurprisingly.
    If that URL was there, I believe it 100%.
  • PaperballparkPaperballpark Near ManchesterMember Posts: 4,133
    It was there. Indeed, Huw thought it newsworthy enough for a front-page article.
  • roxioroxio UKMember Posts: 1,362
    "Recreate iconic Ghostbusters scenes with the 2-story Firehouse Headquarters, featuring laboratory, living quarters, containment unit and much more. Capture the ghosts with the proton packs and restore order, or solve other supernatural cases! Includes 9 minifigures: Peter Venkman, Raymond Stantz, Egon Spengler, Winston Zeddemore, Janine Melnitz, Dana Barrett, Louis Tully, Library Ghost and Zombie Driver."
    • Includes 9 minifigures: Peter Venkman, Raymond Stantz, Egon Spengler, Winston Zeddemore, Janine Melnitz, Dana Barrett, Louis Tully, Zombie Driver and Library Ghost. Also comes with Slimer, Pink Ghost and Blue Ghost.
    • Slide the Ghostbusters heroes down the fire pole into action. Chase the ghosts and secure them in the containment unit.
    • Turn the librarian old lady into a scary ghost with the double-sided face and extra wig! Run tests on Louis in the lab to see if he's possessed!
    • Suspend ghosts around the building's exterior with attachable transparent arms. Dodge the slime oozing up through cracks in the pavement.
    • Measures over 14" (36cm) high, 9" (25cm) wide and 14" (38cm) deep.
    WatfordScottyMcheshirecatprevereAleyditabrickupdateTXLegoguykiki180703
  • Captain_EyebrowCaptain_Eyebrow Test Valley, somewhere between Brickset Towers and Narnia . . . .Member Posts: 159
    Just needs a Walter Peck, a Mersk blue hat for a Con Ed engineer to turn off the containment grid and a police officer and it'll be ready for a ghost escape!
    edited October 2015
    All we need now is a proton pack photo...
  • alldarkeralldarker NetherlandsMember Posts: 225
    roxio said:
    Looks like TRU either already changed the weight to a more reasonable 4 lbs, or you read it wrong :)
    Good find either way!
    ^Might be a typo but it's still showing under Additional Information as 14lb product weight
  • AdeelZubairAdeelZubair London, UKMember Posts: 2,698
    Judging by the dimensions listed in the description the Firehouse it will be on a 32x32 baseplate (25.5x25.5cm) as well as a 16x32 baseplate (12.25x25.5.)
  • HangedSanchezHangedSanchez United KingdomMember Posts: 310
    For comparison, that's an inch narrower but 4 inches deeper than a modular. About an inch shorter than the Grand Emporium.
    ^^48x32 studs is the same as the Swiss Ghostbusters design. And the dimensions are similar too... height: 38cm - length: 33,6cm - width: 17,5cm
    http://www.swissgb.ch/lego-gb/
  • blades_ladblades_lad Nottingham, UKMember Posts: 37
    Odd... But under Additional Info, I'm still getting 4 lbs, and not 14 lbs!
  • LegoTTLegoTT Member Posts: 483
    $400?! I bet there's not even a place to park the car...
    That might be a problem. If it doesn't include Ecto-1, will they care if it doesn't fit? It is a completely different set after all.
  • ChubblesChubbles USAMember Posts: 459
    What's the Zombie driver going to be driving if not the Ecto-1?
    A taxi?
    pharmjodSumoLegographiteGothamConstructionCokiki180703AdeelZubair
    edited October 2015
    The taxi cab, maybe?  It isn't explicitly listed as being included, but that was a memorable funny stinger of a scene, and Lego does love taxis, nearly as much as helicopters.
    SumoLegoandhe
  • dragon114dragon114 United StatesMember Posts: 640
    That most likely ca price and not us price.
    bobabricks
    I guess there will be stuff included that wasn't listed
    I want a Vigo poster on the wall, or maybe a dancing toaster.  Sorry, I watched GB2 again this weekend.
  • piratemania7piratemania7 New EnglandMember Posts: 2,145
    Sounds like this is real!
    Between this and the rerelease of the winter toy shop it looks like TLG is not afraid to repurpose and retool old sets and ideas.
    A great jab at resellers me thinks!
  • SumoLegoSumoLego New YorkMember Posts: 14,356
    Did someone say helicopter?!?
    And by the way, I don't think an actual helicopter appeared in either one of the Ghostbusters films.  (My guess is that it was too expensive...)
    Also... zombie cab driver!
    TheLoneTensorYodaliciousGothamConstructionCoMynattkiki180703gmonkey76andheAdeelZubair
    edited October 2015
    How do you see this as being a jab at resellers?
    SumoLegoChang405BumblepantsmadforLEGOFollowsCloselykiki180703
  • nexandernexander Glasgow Member Posts: 906
    ^^ That brings back memories! Had totally forgotten about that
    edited October 2015
    ^^ Unless I missed something, I'm pretty sure there wasn't a $349.99 GBHQ set previously released.
    But... I did lose my car keys this morning.  So it is possible...
    Sethro3Xefankiki180703AdeelZubairbobabricks
  • William_TownsleyWilliam_Townsley Perth, Scotland Member Posts: 880
    Hello I tweeted TRU Canada this morning asking when it will be available to buy and they have responded.
    "We can't give you information for this as yet. Please check back in two weeks. Thanks"
    So possible The Lego Group will announce this in the next coming weeks?
  • Sethro3Sethro3 United StatesMember Posts: 822
    Or you could check back and they will give you another generic response with another 2 week timeframe.
    It was said on EB that it didn't have Ecto-1 ages ago. So this isn't surprising, but I'd suspect there is a lot more than that little description. This isn't wowing me as it stands, although I will wait until pictures..
    @SumoLego I had that Ecto-2. Come to think of it, it's probably in my dad's attic somewhere with the firehouse and Ecto-1. And a really, REALLY old jar of slime.
    andhe
    No carcinogens in that slime... perfectly safe for kids...
    ^ There was a play feature with the firehouse where you would pour the slime into the top and it would flow through to the bottom floor and "slime" one of the Ghostbusters. The big problem was that if you didn't clean it off almost immediately it would harden and get very weird very quick. Let's just say a 10-year-old isn't going to clean it off immediately.
    ^ And things are always "weird" when you slime someone without cleaning it off.
    LegoTTSumoLegomatticus_brickskiki180703ricecakebobabricks
  • Jern92Jern92 MalaysiaMember Posts: 860
    Or we might not even get a baseplate. Lego doesn't seem very generous with those nowadays. Look at the Haunted House, Simpsons House, and Kwik-E-Mart. And the GB Headquarters probably swings open like those do.
    FollowsClosely
    edited October 2015
    Looking at that fig line up, this guy from my CMF collection just became a lot more interesting:
    edited October 2015
    ^ Grrrr. Should've been image of this guy:
    http://brickset.com/minifigs/col134/Policeman-Minifig-only-Entry
    (My browser keeps screwing up the dropbox and i can't remember the code to manually input an image).
    I do not want it to swing open I want it to come off like modulars. And it better be on a baseplate
    1 out of 2 aint bad hey?
    From the dimensions its clearly on a baseplate (well 2) and I expect it will swing open (which in my experience is far better for play than the modular system).
  • bluedragonbluedragon United StatesMember Posts: 505
    My kids kids also prefer buildings that swing open. It is better play wise when you can see the whole interior as opposed to one level.
    It will be interesting to see how much playability they bake into this set.
    I would imagine this would be closer to the Helicarrier or the landmark Creator sets, but given the scale this is clearly geared toward the modular market.
    Maybe the Airjitsu Temple is most similar?  Some play features, but really a static display piece...
    My guess is full on dolls house. The Swiss ghostbusters v2 moc is sugnificantly more pieces but there's a lot of 2x2s and 1x1s that can be swapped by TLG for bigger parts to pull it closer. Lego don't seem to like fully tiled floors either so save more there and you're in the ballpark.
    ^6 minutes and it's already gone.  What did it look like?
    They deleted that tweet for some reason. Here it is again:
    MattsWhatpharmjodkiki180703
  • ShibShib UKMember Posts: 5,442
    I think there must have been a mistake on the tweet, they took down the first one and reposted it a minute later
