Me
@Sir_Gareth
@CapnRex101
@Huw
@Matthew
@Matthew
@TheOneVeyronian
@CapnRex101
example being, Motorcycle, it was pointed out there were several different spellings used for the same thing in the first tag wave. so if a person adding a tag wants to add Motor Cycle, or even Motor Bike. it would find "Motor" in the name and display a list of tags containing "Motor" one of which likely being Motorcycle. this if possible would limit some of the moderation needed for duplicated tags.
like I said just a thought (I'm no programmer so I've no clue how hard that might be)
I'd like to suggest the inclusion of tags that would include packaging types. Right now you can't search for Polybags or other non-box items and there are no options for packaging when Browsing.
I don't feel the need to include Box as a tag, but do think it would be useful to include:
> Polybag
> Blister (pack)
> Foil (pack)
etc...
So "motorcycle" "cycle" "motor" "bike" etc are all valid if there is a motorcycle in the set instead of trying to decide on a pre-set list of terms to use and fixing them all to only use that term. This would fix the "Gresh" issue as it would be fine to have it as a tag also. Then to make the search easier the default search would search everything but add an additional search selection in the drop down (or a checkbox or something) for title only so if you want helicopter sets that actually have helicopter in the title and not any that have anything to do with a helicopter you can find them easier.
This is tagged as electric. I'm fairly sure its a diesel. All other lego electric trains have a pantograph, as you can see in all the other sets with the tag. The loco looks like a small shunting diesel. I am not a train expert though so could be wrong.
Maybe those type of tags need to be worded differently:
Locomotive, Electric
Locomotive, Diesel
Locomotive, Steam
Something different for power source...
Motor, 9 volt
Motor, 12 volt
Etc
Train, freight
Train, passenger
would also be logical.
Tag groups is something we may need to look at at some point, otherwise sets could end up with too many. Maybe it could be done automatically if tags are formatted like this, with a comma separating the more generic term from the specific one. I'll give it some thought...
Why does this have 2 forklift tags? Its also picked up a diesel tag along with
http://brickset.com/sets/7939-1/Cargo-Train
Both of these have pantographs which is why they have the electric loco tag, not sure where they've picked up diesel from.
Train, or Trains seems to be very messed up.
A search for Train will reveal the Trains (Theme) in the drop-down menu.
There is also a Train (Tag), but nothing is listed if you select it.
Random examples...
Hogwarts Express has various incarnations. They are all trains. There seem to be various sub-theme for trains within various themes, but the sub-theme is not all-inclusive, and does not exist within the Harry Potter theme. Also Hogwarts Express is not tagged as a train or trains (because there is no simple "train" tag).
Logically, I would think that all trains should show up under an all inclusive sub-theme of trains, or there should be a tag for trains.
Same goes for 31015-1: Emerald Express.
There are too many ways to look for various trains, but no one single way.
Do I make any sense?
I couldn't find it, even after ending up looking at the Aircraft tag based on comments. I noticed when looking it up directly by set# that the Aircraft tag is not on it.
Probably I will invite people to apply to be able to add them and vet them on application, to try and keep kids away :-)
- Contributors can add them, and delete their own
- Moderators can add, delete and manage them.
If you'd like to be a tag contributor please drop me a PM with your Brickset username and explain briefly why you'd like to do it and what you're an expert in. I don't expect I'll refuse anyone who asks but the last bit is just to keep some sort of control on who's adding them to avoid it getting in a mess again.
Chris, myself and a couple of others are moderating but if it become arduous I'll ask for volunteers for that role too.
I look forward to receiving your applications!
Things like:
-use singular nouns for basic/generic items (train not trains, plane on planes) For consistency more than search ability assuming a 'plane' search would find tags of 'planes' just makes it nicer if the terms used are consistent.
-addressing some of the Power (12v, PF) and locomotive type concerns in this thread
-using single terms that will actually provide results and not multi-term strings that someone might not know to search for, assuming a full term needs to match (the "locomotive, diesel" etc example would be one that shouldn't be multiple words if it wont find it without both. Plus it should already have 'train' as a tag so just 'diesel' would be fine. And '12V' '9V' 'Power Functions' should suffice for powered options instead of a 'category, type' tag like 'motor, 9V')
-whether proper names of things in the set or related to the set should be included (i think there was discussion on having bionicle names in the tag even though the set was named with it
'Watercraft' is another one, and where to draw the line between ship and boat is still a mystery...
Taking it to extremes, we don't want to have a tag 'vehicle' to cover every moving thing, I would suggest.
Good point about the train tags. We can make changes globally to them they could be changed easily enough.
I disagree about Aircraft for planes and not helicopters. They are in fact both aircraft (helicopter/plane) just as watercraft covers ship/boat. These are the type of things that need to be laid out a head of time and should also be in a Sticky/FAQ for people to know how to better search.
I think having both tags, even though superfluous, isn't a bad idea. You could have aircraft with secondary terms helicopter, aeroplane, blimp, balloon etc and watercraft with secondary terms boat, ship, etc.
Or if not then just designate terms up front fixed wing = aeroplane, rotor = helicopter, anything else = aircraft. Using the generalized term as the catch all for the rest.
It only ends up being confusing if there is no manual. If there are no guidlines then you get opinions from all sorts of angles that things like pirate ships are sail boats and not ships in the same class as the Maersk cargo ship etc. People that want to search for "ship" and have the 2 results they feel fit it are just going to have to live with the fact that LEGO puts out too many sets that fit the bill for them to get easy searches =)
We certainly don't want both tags.
As for "Flagship Set", its intended use is for the biggest and best Technic set of the year, as in "Over the years, the term "flagship" has been borrowed in metaphorical form by industries such as broadcasting, automobiles, cell phones, education, national airlines, breweries and retailing to refer to their highest profile or most expensive products and outlets." rather than its literal meaning so I will remove it from the pirate ship.
(Both quotes from Wikipedia)
Regarding the "aeroplane/airplain" debacle, is there any way you can group tags and he de them under a general header, in this example have the tag that shows as plane but searching for "aeroplane" or "airplane" still link to the same tag, or is that going to far.
It's one that I'm fairly unlikely to search myself, but I would be more likely to search helicopter or plane than aircraft. I get that you want to keep the number of tags down to keep the clutter down but in terms of usability more tags generally makes searching easier - until things get to the silly point to of having parts listed. Perhaps a tags tab would be better than having them to the side of the page to keep the clutter down?
like you said before Huw, it is a bit of a minefield!
Also, if searching for 'plane' will bring up results with the tag 'planes' (partial searching), using only tags in their plural for will result in more/better searchable 'categories'.
One thing that stands out, right off the bat, is the special event promotional Microfighters... While all the SW Microfighters are categorised as Microfighters, there is one set I know is not listed, the Marvel set Rocket Raccoon's Warbird #COMCON034. In the GotG movie, Rocket's ship is a more heavily armed, but fractionally smaller version of Quill's M-ship, the Milano. Comparing the Warbird to the SW Microfighters & the Milano from set #76021, I think that most would agree that the Warbird fits the criteria of a Microfighter.
Of the CMFs, the tags for these should be able to be kept to five tags or less. Below is a small sample of how I'd tag the CMFs, if anyone wants, I can give further explanation;
Aztec Warrior (8831-2) - Historical, Male, South America, Warrior
Cowgirl (8833-4) - Female, Historical, Wild West
Hard Hat Emmet (71004-3) - Construction, Male
Marsha (71004-16) - Female, Mythical, Royalty
Ocean King (8831-5) - Classical, Male, Mythical, Royalty
Pharaoh (8684-16) - Classical, Egypt, Male, Royalty
Pilot (8803-2) - Aviation, Historical, Male
Policeman (71000-6) - Law Enforcement, Male
Sheriff (71008-2) - Historical, Law Enforcement, Male, Wild West
Space Miner (71007-6) - Male, Mining, Space
Wild West Wildstyle (71004-4) - Female, Wild West
I would do that by myself, but it seems I have no ability to. :)
