Please use our links:
LEGO.com •
Amazon
Buying Pieces and Elements for MOC's & Tips for Displaying at LEGO Conventions?
I plan to display some creations at Brick 2015 in the UK. This will probably be the first display at a LEGO convention as well as purchasing specific parts for MOC's. I normally build on LEGO Digital Designer and occasionally build with actual bricks, examples can be seen here:
https://www.flickr.com/photos/[email protected]/sets/72157645785522606/Now for your help! I need to know what is the best way to purchase parts for LEGO MOC's, I plan to display some of my best creations that you guys have already seen as well as some new secret projects. What is the best option or cheapest way to build LEGO MOC's? Pick-A-Brick, buying multiple sets, Bricklink/Brickowl etc. How do you guys plan in advance?
Any other tips and ideas you guys have to help me with your past experiences of LEGO conventions and building MOC's?
Thanks,
Adeel
0
Recent discussions •
Categories •
Privacy Policy •
Brickset.com
Bottom line either sets or lots will beat PAB/bricklink/brickowl prices. However it will also take more time to get the bricks you want this way, which is why if you MOC for competition for example you would normally use bricklink and similar - more expensive, but way quicker.
If you MOC, like to MOC and plan to MOC in the future, there won't be many "unwanted" parts (even the most "unwanted" bits are routinely get used in foundations, people even use Duplo there!). Worst case scenario you can always put the stuff you don't need back into lot and sell it, making your other bricks even cheaper.
All it takes is time. This is the only aspect where buying sets/lots is at disadvantage over specific bits on bricklink. But the OP asked about planning in advance, which is the wisest way to go about it, and with this in mind you aim at building your collection over time, not in the last minute when you have to produce a MOC.
One of my LUGmates often plans what he will use in builds based on what's available in the local PaB wall at the time. It's kind of random, but it works for him. I live too far from the closest LEGO store to let that really be a consideration though.
Outside of parts drafts with my LUG, I seldom buy sets just to part-out on my own. That said, I did initially build up some of my collection by buying newly released licensed sets with good parts, then selling off the figs. Even after fees, I usually ended up with the bricks for under 10% of the cost of the set.
The way I've always done it is to only buy the parts I need. I don't like buying sets for parts. I think part of the reason is because, building on LDD, it's easier to just use any random piece, rather than what you actually have physically. I like the freedom of using any piece I want. Someone more creative than I would probably be able to churn out awesome MOCs using a very limited range of pieces. I would end up with a lot of unused pieces and wasted money if I parted out sets for my LDD MOCs.
I buy parts from Bricklink. When I build, I always check Bricklink to make sure that the pieces I want aren't super rare or nonexistent, and to make sure they aren't really expensive. I like using this program called LDD Manager: http://www.eurobricks.com/forum/index.php?showtopic=41993
LDD manager is great because it can convert an LDD model into a BL wanted list, and it can tell you whether a part exists or not. It isn't perfect though. It sometimes misses newer parts, rare parts, or "decorated" parts, so you might have to add those to the wanted list manually. I always go through the wanted list and cross reference with the LDD file to double check and make sure everything gets transferred over. The easiest way to do that is to use the "color & shape" selection tool and just (temporarily) delete pieces from your LDD file as you go through the wanted list. If there is anything left, then the program missed them, and you add them manually.
Once I have the wanted list for the parts I need, I just go through and see which stores sell the quantity I need for the cheapest, and try to order from as few stores as possible. I always quadruple check everything to make sure that I'm not missing anything from the LDD file. There is a program out there called brickficiency that figures out the best BL stores to buy from, but I have had issues with the program, so I just find the stores manually.
I used to buy parts from PAB a few years ago, but I've found BL to be cheaper (plus PAB has a limited variety of parts). I have no clue what Brickowl is like, but I will probably try it out sooner or later.
For displaying at conventions, I haven't really done anything special. I've only been to BrickCon twice. The first time I only brought one small spaceship MOC. The second year I brought a few more MOCs. I didn't take this picture, but these are my sci-fi MOCs from BrickCon 2014. The red/black/white ones in the front belong to me. I had the main models, but I also had some crates, boarding ramps, and even a janitor to make things a bit more interesting
I think for next year, I will make a few UCS style display plaques to go with some of my bigger movie based MOCs.
Sorry for the super long post. I hope I was to help you figure things out a bit! A lot of this is still pretty new to me too, but hopefully you found some of this information useful. ;)
Besides... I like building my MOCs "right now!". :stuck_out_tongue_winking_eye:
If it's an option, try to get some experience with exhibiting at a smaller public show before jumping head-first into a large event like 'Brick 2015'
Have a *very* serious think about how you're going to present your models to the public. A bunch of models lined up on a tablecloth with some labels is fine, but you might want to 'jazz' it up a little if you want to get the public's attention. Maybe add a bit of landscaping, or a hangar, or something else to place your models within. Start small-ish with your first show.
Think about how you're going to get the models to/from the venue, and how long setup/breakdown is going to take. If you design your display from the outset to be easy to assemble/disassemble & to be able to be packed up into a couple of mid-sized 'Really Useful Boxes' that can easily be carried in the boot of a car, then it'll make your life a lot less difficult on the day. Having as few boxes to shift into/out of the venue will speed things up, especially if you're on your own. If the boxes are too big/heavy to carry easily by hand think about getting a folding trolly, but one that's large enough to carry the boxes without fear of them falling off (and get some bungee cords to give the boxes a bit more stability).
If it takes a bit of effort to put your display together, try to practice it at home a few time before the day of the show.
Label any personal stuff that you plan to leave on site during the show (e.g. boxes, trolly, bungee cords, etc.).
Kids, and the public in general, are attracted to motion & lights; I think that's one of the reasons that train & monorail displays are always popular with visitors. Think about how you might give your models an extra something. If you're building something specific to the show (rather than showing existing models) think about building something that's related to something 'of the moment' - a film, TV series, high profile book, important public anniversary, etc. - that way you're sure to get some extra attention. It goes without saying, but avoid controversial topics.
If you're using some interesting building techniques, maybe consider having some pics of the build whilst it was in-progress to hand in case anyone is interested; maybe keep some example test-build prototypes handy. If the model is based on a interesting real-word thing then keep some reference pics close. This will be useful when talking to fellow exhibitors as well as the public.
The most important advice though is to relax and have a good time, interacting with the public & your fellow exhibitors.
(a) LEGO's online Pick-A-Brick service - http://shop.lego.com/en-GB/Pick-A-Brick-ByTheme
(b) LEGO's 'Bricks and Pieces' service - https://service.lego.com/en-gb/replacementparts#IssueType - bigger selection than on-line PaB, but sometimes cheaper, though often more expensive (but this is off-line for regular brick purchases until the end of Jan);
(c) LEGO's 'LUG Bulk' programme - https://lan.lego.com/blogs/1-blog/post/7 - long lead times (~9 months for the last one), and lots of constraints, but an option if you're a member of a LUG;
(d) reverse Bricklink - buy sets to part out; keep the parts you want & sell the bits you don't in your own Bricklink store (this can be a lot of effort on your part);
(e) trading/buying within a LUG - another advantage of being part of LUG is trading with other members, especially if you need something at short notice. My LUG doesn't do it, but I know a few of the US/Can LUGs have regular 'parts drafts', where they chuck some money together, buy a bunch of sets at discount (e.g. Argos 3-for-2), part them out & divide up the 'spoils'.
There's bound to be others I've forgotten. Personally, I use a combination of the above (including approaches mentioned by others) depending on the situation; there isn't a 'one size fits all' solution. 'Bricks and Pieces' is great for getting new parts in bulk, Bricklink is great for getting specific parts when you need them, buying sets at retail is good when you need something quick, LUGbulk is good for basic brick & plate in quantity when it isn't urgent, etc.
The balance between the above will depend on what you build, how you build, etc. For me, where my main builds are planned in advance, Bricklink is my go-to place. For casual, free-form building, I'm always on the look-out for sets with a large proportion of usable pieces (Creator sets are pretty good for me; the Mixels have been superb for this, and I'll likely buy multiples of 2015's 'Future Flyer' set ( http://brickset.com/sets/31034-1/Future-Flyer ))
Ian
One big problem I've come across is budget. I have acsses to just over £1100 from now until October. Should I spent all of it on creating MOC's for Brick2015 or should I mix it up and buy a few sets? Is it worth taking apart sets for specific parts, I own many LEGO Super Heroes sets as well as LEGO Ideas and D2C sets?
I've been to Brick last year and saw many large layouts. What is the best size to build at? I would like to build some of my best MOC's I have already shown on Flickr. Any tips for smaller builds in similar sizes to offical LEGO sets?
I'm currently thinking of doing a large layout as the center piece to attract attention and have smaller builds on the side. What do you think?
Any feedback and suggestions are welcome. @bluemoose I think your the right person to answer this :)
Adeel
