orange bricks (UK)
it seems that orange bricks are hard to find? (in the UK)
the "pick a brick" section on lego website has some orange bricks but not all.
went into lego shop and their orange selection was even more sparse.
i'm trying to source these parts (see attached image), to build a pumpkin.
is there a one stop shop to get all of these, or will i end up having to buy bits from various places?
  • CCCCCC Member Posts: 20,526
    The 2x8 will be a problem, it's not been in a set for about ten years.
  • chenkschenks Member Posts: 9
    i can find the 2x8 on ebay, which solves that problem.
    what are the other parts on the second row called (14x and 6x) ?
  • iso3200iso3200 Member Posts: 2,065
    edited October 2014
    All of the parts are available from Lego direct using the Replacement Parts section of the website, with the exception of the 2x8 as @CCC has pointed out already. Most of the bricks would likely be cheaper sourcing on bricklink, but if you have to make multiple orders to get bricks from different sellers the postage soon starts to mount up, and at least you're guaranteeing brand new parts with a good colour match if bought from Lego.
    In a valiant attempt to avoid the real work that I should be doing today, I went on to the replacement parts section of Lego and worked it out for you. All the parts come to £18.99 - without the 2x8's. I'm not sure of your build instructions/plan, but of course the 2x8's could be switched out for more 2x4 bricks.
    The replacement parts service have a flat rate of £2 shipping in the UK.
    Hope that helps you.
    david325carlqandhe
  • PaperballparkPaperballpark Member Posts: 4,268
    ^ 2x2 inverted slope and 2x3 inverted slope.
    that's great... now i just need to work out the element or design number of each part so i can use the bricks and pieces order page
    3003
    3002
    3001
    3039
    3660
    3298
    3747
    3004
    excellent.... i'll check and see if i can get away with using multiple 2x4's.
    if not i'll get them on ebay.
    I'd advise buying all parts new if you can. If you buy used on ebay, you will notice the scratches on the old parts, and possibly a slightly different coloured orange.
    PS. A real pumpkin is considerably cheaper :-)
    PPS. And tastier.
    carlq
    If you're building #3731 there is a seller in Hungary with a brand new sealed poly. By the time you've factored in postage it looks like it'll be about £23 all in, so similar to sourcing the parts elsewhere.
    http://www.bricklink.com/store.asp?p=leoone&itemID=46900482
    Might be worth a look.
    PM'ing you with some more info...
  • cheshirecatcheshirecat Member Posts: 5,331
    edited October 2014
    ^ That is an alternate build for #3731. You could buy both for about £32 inc delivery and probably find someone to buy the spare off you for £16. - Hell I might!
    is it? as 3731 looks like a flat design, whereas the one i linked to is 3 dimensional.
    Yes - look at the parts list on brickset.
    It looks like all except one of the 2x8s can be replaced with two 2x4s, though replacing the one above the mouth may make that area somewhat fragile. The one that can't be replaced, which goes across the top and is supported at either end by 2x3 inverted slopes, looks to be inside and could be any color.
  • darthdcdarthdc Member Posts: 228
    I'm surprised at how even the most basic bricks and beams are being ignored in certain colours. Orange is a widely used colour in real buildings, so why make it a rare colour in Lego? Closest to terracotta, we have.
