LEGO Freeway System
Hello everyone, I need some advice for something I'm trying to build. I am working on a LEGO freeway interchange through my city, and I need some help on designing those long, overhead bridges and ramps. I really want to get the curved, arc shape of the real freeway bridges/ramps but I don't know how to do it with LEGO. I want to avoid using those hinged pieces since they won't look smooth, and that's something I'm looking for. Any suggestions would be appreciated!
    edited May 2014
    You should try this technique:
    Sure, it's not the greatest looking thing in the world, but it should do the trick.
  • epikfilmz11epikfilmz11 Member Posts: 3
    That will work fine, but I have no idea how to attach them to the plates and how to have the plates bend with them...
  • madforLEGOmadforLEGO Chicagoland USMember Posts: 10,575
    edited May 2014
    1x2 tile with 1 stud on top http://www.bricklink.com/catalogItem.asp?P=3794 to hold the structure onto the plate in certain places, and 1x2 tiles to fill out the rest of the base to make it look solid. There are also a bunch of smaller curved panels that should help with smaller posts needed
  • CCCCCC UKMember Posts: 20,422
    If you want really smooth, then the half cylinders may work, although the diameter may be too small. http://www.bricklink.com/catalogItem.asp?P=85941
  • timttimt Member Posts: 33
    I'd love to see this when its done! Although I'd imagine an interchange would take a significant amount of real estate to look realistic. How big are you planning on making it?
    Thanks for the suggestions. I'll figure something out. I'm planning on making it pretty large and I'll definitely post it when I'm done!
  • blade_guyblade_guy ManchesterMember Posts: 219
    edited May 2014
    Have you thought about using plates from the #6600 set?
    #6600-2....#6600-1 is a small police car
    Take a look at this: http://mocpages.com/moc.php/257825
    It gives amazingly smooth surfaces but depends on lots and lots of 2x2 tiles with grooves - the grooves are important apparently.
    edited July 2014
    Kinda pricey though, and only two lanes
    Wow, That takes a lot of commitment, maybe not a lot of money, but then again buying 100's of 2x2 tile added up if you cannot find them at a store PaB.
    I just wish LEGO would have made the highway plates for the masses to buy: http://www.peeron.com/scans/200-4/14 ; http://www.peeron.com/scans/200-4/23
    Experimenting with my "downtown" city roads. Initially, I wanted to use the mason profile bricks on their side for the road...but that was getting too expensive. So now I'm think a mix of profile bricks and regular bricks to create a used, rough-looking road, with pot holes and blacktop filled spots might even look cooler.
    Bumblepants
    I thought about using Masonry brick for the crosswalks like some downtown cities have it. If you can find them at a LEGO store PaB I would say you could do it, but if you have to pay about 20 cents per brick I can see that getting really expensive real quick
