Please use our links:
LEGO.com •
Amazon
Hi. I'm new here mostly because my parents just gave me a few ice cream buckets of Legos that I had when I was a kid. I have instructions for the following: 6876, 6850, 6884, 6875. I was hoping to find some help determining what other sets I may have in this pile. Any help is greatly appreciated.
0
Recent discussions •
Categories •
Privacy Policy •
Brickset.com
Quick Links
I do see one piece that appears to be from either #6929 Star Fleet Voyager or #6952 Solar Power Transporter
It looks like you've also got #6941.
http://www.bricklink.com/catalogItemIn.asp?P=4858pb08&in=S
So start with the instructions and pull those pieces out. If you find that there is a set that has very few or no pieces for it ignore that set. Next look for unique or rare elements. Unique are the best because you know for sure what set that is. But there aren't a lot of unique elements out there, particularly with older sets. With rare or uncommon pieces you need to look at inventories. It's a judgment call as to what best fits. Don't be a afraid to change you mind. I something find I've made the wrong call and find a better fit after looking a little more.
Once you've identified a set pull those out and start again with the rare or uncommon pieces. At some point you will either run out of brick or have only common bricks left. Sometimes you might find unusual combinations that make a set, but once you have only common bricks I normally stop.
Having an era can help narrow the search down. Rare pieces or combinations in one decade might be common in another. If you're really detail orientated things like PIP location or the brick type (ie Pat Pent, void, ID, etc) can help narrow things down.
A brief word on inventories. General rule of thumb is older the set the less accurate the inventory is likely to be. Most within the last 15 years are pretty good and the most accurate. Stuff going back to the mid 70's is fairly good, but could have errors particularity if it's a rare set. Most things older than 1972 I generally don't trust do to poor documentation.
The other parts I'd start to focus on are the green canopies, they're rare. I'm not seeing other parts of 6952 though, but who knows.
I think you have brickset.com/sets/6928-1/Uranium-Search-Vehicle to explain the extra Yellow Canopy, the white and black classic Space minifigs (you have at least two black, which is a bit rare), the blue 1x2 with the classic space icon, the clear yellow panel, and the gray radar dishes.
You also have brickset.com/sets/6850-1/Auxiliary-Patroller which is the only set that has the white canopy piece with the black stripes. That explains at least one Yellow Futuron minifig.
You seem to have one of every color of Classic space minifig, Blue and Yellow Futuron, a couple Space Police and a Blacktron I guy.
I think that your other Blacktron set could be http://brickset.com/sets/6954-1/Renegade, I see the large black wings and the landing gear, but there are a lot of key pieces that I don't see - like the black castle walls and the large yellow cones.
Incidentally, has anyone ever tried adding parts, rather than sets, to a list on Rebrickable to figure out what they've received in a bulk lot? It seems like it may be more trouble than it's worth if you have a lot of parts, but if none of them are unique I could see it being a useful tool. Maybe even just adding the most unique parts or figs to a list could be helpful, or even a date range. Just work from general descriptions to more specific ones so as not to accidentally filter out the part for which you're looking.
Either way, good luck and happy hunting!
