It is the very model of a modern major building brand
(I'll have to make do with:
Follow the Lego brick road... we're off to see the wizard, the wonderful wizard of ABS)
Now put mechanical legs Darth Maul in the CMF Chicken Guy's suit and start a line of Star Wars chicken products! ;-)
Looking at the size of the sails, and where they are, the front one seems to sit 3 studs forward of ideal, as the front sail should be inline with the front of the top deck and you could get away with setting the back one 3 studs further back than the front one. All in there's scope to lengthen the deck by 6 studs without spoiling the spacing/overlap of the sails provided, and widen the deck (and therefore the whole kit) by 2 studs. The hull itself already about 2 studs short. Might have a tinker with it tomorrow.
https://www.flickr.com/photos/capnrex101/13169690885/
It is very simple, but captures the scene quite nicely I think!
Just wanna share what I built using brickset.com/sets/6866-1 .
Using the helicopter only, I made this:
https://www.dropbox.com/s/mdn22nixwbzep57/BloodRaiderPhoto1.jpg
I also wanted to make an instruction booklet on this model. I found out about Lego Digital Designer, and made this with it:
https://www.dropbox.com/s/2hfsosgocsqpd5s/BloodRaiderLDD1.jpg
The next step would be to figure out how to work the Instructions Booklet section. I haven't tried it yet. Wish me luck o.o;
I'm currently building http://brickset.com/sets/70709-1/Galactic-Titan
When I'm done, I'll deconstruct it and make my own thing from the pieces :D
-Tommy
The center body with the side armor platings are really nice too. Great work :D
;o)
Looks great!
As always, more photos on my Flickr, here's the link: http://www.flickr.com/photos/theoneveyronian/sets/72157642549607945/ Start with WIP 1 and flick through. The captions are quite important for some pics ;-)
In case you ask, Wyldstyle's a special guest ;-)
The modulars like the Pet Shop, Fire Station, etc and the Mini versions of these...what are the comparisons like?
I mean has anyone got a photo of a normal sized one with the mini one next to it?
Thanks
Here's a photo of mini Café Corner next to the real thing:
http://www.eurobricks.com/forum/index.php?showtopic=64333&st=25#entry1189185
Thanks again
It does stand up at the moment but may need slight tweaking once the rest is built up to balance it as I'm not sure how much it will weigh yet as its pretty big.
I need some help with my Technic Logo 42009 Mobile Crane MK II. I am working on the "cabin" section of the vehicle. I will refer to Book 4 (of 6) here.
Everything is good through Step 17 on Page 8.
(see first picture)
Take a look at the tan bevel gear attached to the long black rod. At this point I am saying things are "good" because rotating the black rod with my fingers freely rotates the bevel gear - which freely rotates the black spur gear. Excellent..
Moving on to Step 18 we make a separate assembly. The black "T" shaped piece will begin the problem.
(second picture)
After mating the two assemblies (see below) the gears no longer turn without significant friction.
(third picture)
I thought the problem would just go away so I proceeded. Notice how the black rod is now under so much pressure it tilts up significantly (fourth picture). Game over.
I took it apart put it back together three times. I cannot figure out what I am doing wrong. Any ideas out there? Anyone else run into this?
Thanks
Brad
