Heres what was in mine
7x #1 bags
5x #2 bags
1x #3 bag
3x #4 bags
3x misc. bags for the battery box, motor and pneumatic pieces
Plus the 4 tires and rims.
Let me know if you need any additional info.
2x #1 bags
3x #2 bags
3x #3 bags
3x #4 bags
3x #5 bags
2x #6 bags
3x #7 bags
plus 1 unnumbered bag with the bigger plates in it.
x 2 manuals. ..x 1 sticker sheet...x 4 sealed bags numbered 1 - 4 and x 3 loose plates ( x2 tan x1 green).
Id be very grateful for your help in this matter..ps is anyone aware of any sites that might hold this information on any data base rather than piece count..
Thanks in advance
2 instruction books and one sticker sheet.
4 large bags each containing 2 smaller bags.
1/ Bilbo i/ head and feet ii/ hair and other small peices.
2/ i/ bottle and trans orange brick ii/ window grills.
3/ Balin and Bofur i/flowers and tools ii/carrots and cherries.
4/ i/ Bombur ii/ Dwalin. I managed to find this set on sale at argos ..uk but the box was open..I have everything as mentioned except there's no mention of 3 plates ( x2 tan and x1 green ) is this correct or should there be more or less..many thanks for advice in advane
I don't have any specific answers to hand, but don't the instructions tell you which bag to open at each stage? If you flick backwards through booklet 2, you should eventually come to a numbered bag illustration, which would be the final bag for the final stage.
http://cache.lego.com/bigdownloads/buildinginstructions/6036617.pdf
Seeing the parts in the flesh I have discovered that I might have another 7783, although definitely incomplete, in a bulk lot I get recently and am still sorting :-)
Cheers
2 Instruction Booklets
8 Loose Hull Pieces
19 Mylar Plastic Bags
3 Soft Plastic Bags (Sails, Masts, Rope Ladders)
Just bought a used Ewok set from a local garage sale. Inside the box, there are bags opened and some are still sealed. Quite a few pieces are zip bags. Can't figure out how many pieces are missing here.
Please help? Thanks a lot in advance.
2x bag 1
3x bag 2
3x bag 3
4x bag 1
2x bag 2
2x bag 3
1x bag 4
2x bag 5
1x bag 6
2x bag 7
1x bag 8
1x bag 9
1x bag 10
1x bag 11
1 8x16 tile
6 tires
If i recall correctly (i'll double check later, and repost if i'm wrong).
Mine came with:
1 cardboard-supported instruction booklet, with 1 small sticker sheet.
6 numbered bags (1 to 6).
2 loose-in-the-box rock pieces,
Smaug split across four(?) unnumbered clear baggies (Head/mouth, some Tail, Wings, Body).
Asking as my box appeared to have popped/tampered with seals (though nothing seems to be missing). Can anyone confirm inventory?
Yep. I really only bought it for the dragon (I can't have a hobbit display with no smaug), but otherwise will build once, then probably demolish for parts too.
7 bags total, numbered 1 through 7.
Cardboard-backed bag of stickers/manuals
#10232 Palace Cinema
8x bag 1
6x bag 2
5x bag 3
1x 32x32 red baseplate
2x 16x16 tan plate
1x 16x8 tan plate
Instructions + sticker sheet
